New to Tundras--how well do they tow?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Lugerford, May 3, 2021.
  1. May 3, 2021 at 9:48 AM
    Lugerford
    Lugerford [OP] New Member
    2014 Limited Brown
    Hi all, I'm on the fence about a 2014 Tundra Limited with 85K miles (5.7L). I have a 25' bumper pull travel trailer that weighs about 5500 lbs when loaded.
    Honestly, how well will a Tundra tow a trailer like mine? I will be using a hitch leveler and sway bar. I'm not worried about fuel mileage, because I know it won't be great--I'm more concerned about ride stability and climbing power (but I won't be climbing anything too crazy).
    I just haven't owned a bumper pull trailer for years and before I pull the trigger on this truck, I'd like to hear your opinion.
    Answer fast, before someone else buys the truck!! Thanks!
    Metro14536 likes this.
  2. May 3, 2021 at 9:53 AM
    Welcome from NY.
    Hurry up and buy it!
    I tow my Camaro with no issues.
    ColoradoTJ and Metro14536 like this.
  3. May 3, 2021 at 9:55 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    It has more than enough power for that load, and it looks like you'll be within your payload ratings.
    The Tundra is a heavy truck compared to other half tons. It will be more stable than these super lightweight half tons towing the same load.
  4. May 3, 2021 at 10:12 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! That is about 60% of the typical Tundra towing capacity. You really should not have any issues with it.
  5. May 3, 2021 at 10:14 AM
    RRR1C0
    RRR1C0 New Member
    2014 SR5 TRD CrewMax
    Riding on 275/70R18 Toyo AT3s w/ 1.75” RC leveling kit.
    They can tow a spaceship ;)
  6. May 3, 2021 at 10:21 AM
    Lugerford
    2014 Limited Brown
    Thank you for quick replies! Follow up question for all of you: the owner has taken really good care of this truck and kept up with oil changes, but I don't think he's kept up on the transfer case or differential fluids. Is that a huge deal in your opinion?
  7. May 3, 2021 at 10:23 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome
  8. May 3, 2021 at 10:24 AM
    Jim the Jarhead
    Jim the Jarhead New Member
    2017 SR5 4X4
    Night and day difference with my old Taco. That Taco would cry when hooked up. I now like going the speed limit up hill. 5000lbs total, single axel trailer.
  9. May 3, 2021 at 10:43 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    OP has a 2014 so hes in good shape.
    If he had a 2019+ I would have responded with:
    :annoyed:
  10. May 3, 2021 at 10:58 AM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I believe the transfer case and differentials are supposed to be every 30k. Do you know for sure that it hasn’t been done? Was he doing the maintenance himself or was he taking it somewhere? If he happened to use the dealer for maintenance you could stop by any Toyota dealership with the VIN# and get the records.
  11. May 3, 2021 at 11:09 AM
    Lugerford
    2014 Limited Brown
    Yeah, he had the dealership do all of the work while it was under warranty or part of free maintenance agreement. If we get serious, I'll get the VIN and do just that.
  12. May 3, 2021 at 11:15 AM
    A-A-Ron
    Aaron
    Seattle
    When I bought my Tundra it had 20k on it and no maintenance on the Carfax report. Went to my local dealer and got the report showing all of the on-time oil changes. Since the dealership was doing the maintenance it would seem likely to be close to the required intervals.
  13. May 3, 2021 at 11:17 AM
    A-A-Ron
    Aaron
    Seattle
    In my opinion this is the perfect sized trailer for a Tundra. Get much bigger you will start to run into payload overage issues.
    ColoradoTJ and Cpl_Punishment like this.
  14. May 3, 2021 at 11:18 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Surprised no one has mentioned how nice the 4.30 rear end is for towing.
    Alex38 and Bigboitundra like this.
  15. May 3, 2021 at 11:18 AM
    Welcome. With that weight, you will be in the sweet spot for towing.
    Cpl_Punishment likes this.
  16. May 3, 2021 at 11:23 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Towed the space shuttle just fine. :)
  17. May 3, 2021 at 11:26 AM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    My trailer is the exact size as yours and it tows great! Get it!
  18. May 3, 2021 at 11:28 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Tows and climbs with power to spare. I tow about 6500-7k with mine and I love it! Avg about 9mpg @65mph
  19. May 3, 2021 at 12:18 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I would not worry about it. When I owned Fords the recommended mileage was 100k. My Fords did not have drain plugs only fill. I changed T case fluid on my last Tacoma at 50k and it looked brand new. I change diff fluids on Tundra but will not mess with the T case. I might have a 500 miles on it with 4wd engaged.
  20. May 3, 2021 at 7:15 PM
    mibpf
    mibpf 2021 TRD Pro Lunar Rock
    Tundra’s tow great. I can’t even tell when towing my boat.
    Bigboitundra likes this.
  21. May 3, 2021 at 8:53 PM
    1/68AR Ventre A Terra
    1/68AR Ventre A Terra New Member
    2019 Platinum
    Viking Heaven Cat Shields and SR5 Rims
    They tow great and I don’t watch the mileage gauge as towing our Rpod is the Tundra’s mission. The Rpod weighs 4,500 loaded and the hitch weight is around 560/570. Pulled it 900 miles without a stabilizer hitch and one is not needed. Had Chevy Z71 half tons before and I like how the Tundra is not front heavy.
  22. May 4, 2021 at 11:01 AM
    BulldogDan
    BulldogDan New Member
    Cement…Tundra #9
    My Lance 2285 weighs about the same as yours OP and no issues.....even without a transmission cooler. But there again I have only towed in Ohio...no mountains here. I am sure you will be fine.
