subwoofer enclosure measurements
Discussion in 'Audio & Video' started by jimg, Apr 16, 2021.
  1. Apr 16, 2021 at 12:33 PM
    jimg
    jimg [OP] New Member
    2016 Tundra Limited 4x4
    I have been looking for a while and have not been able to find it
    on a 2016 crewmax limited non JBL radio
    I plan on replacing the head unit with a JVC z1000w
    for an enclosure build
    what is the max bottom depth
    max height on the back of the enclosure
    max top height of the enclosure
    that can be put behind the rear seat.
    I have seen some enclosures that say max mounting depth to be less than 4 inches on the subwoofer
    I have seen some others that you can buy be at 5.7 inches max depth for aa subwoofer.
    I would like to build the enclosure myself.
  2. Apr 16, 2021 at 12:39 PM
    InTheRough
    InTheRough New Member
    Kolt
    Gig Harbor, Washington
    2020 Platinum
    AR Headers DirtyDeeds Exhaust UpTop Racks Rock Warrior wheels
    I can get some measurements later. I never finished my sub box but I did get far enough to help out with the measurements your looking for.
    The deepest measurement between the back wall and seat is at the bottom - at about 6"- and only smaller from there.
  3. Apr 16, 2021 at 12:41 PM
    jimg
    cool deal thanks
    did you take off the back padding behind the enclosure to get some extra space?
  4. Apr 16, 2021 at 12:44 PM
    InTheRough
    Kolt
    2020 Platinum
    I did remove the padding but I replaced it with sound deadening. The padding is just a piece of fabric/foam material.
  5. Apr 20, 2021 at 3:21 PM
    jimg
    anyone able to post measurements of
    total max wide
    total max height
    total max bottom depth
    total max top depth
    that we have in building a box
    BlueRibbon4x4 likes this.
  6. Apr 28, 2021 at 10:18 PM
    !Marauder
    !Marauder New Member
    2019 white tundra
    ToyoElmer and TheBlackPearl like this.
  7. May 2, 2021 at 6:45 AM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    • Outside dimensions with 3/4” mdf. 16 h x 50 1/2 L x 7 1/8 bottom depth 2 3/4” top depth for 1.41 cu ft of interior air. I could fit (2) JL Audio 10w1v3’s. They call for .55 cuft per woofer for a sealed enclosure. I added .1 for each sub displacement and I did some bracing. Subs with grilles are just hitting the seat frame. I did remove that ridiculous rubbery curtain and did an interior sound deadening. The enclosure has the indent of the window motor and the two openings for the hold downs. AE797588-F985-47BD-AF8F-CEF72C4A2D6D.jpg E2D57B9D-01D9-4599-A8B8-11B8D3E470A5.jpg 2BD5BD69-EF85-49E2-9684-F20F49E8F9AB.jpg
    TheBlackPearl likes this.
