  1. May 1, 2021 at 7:03 PM
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Experimented (unfortunately) with "cheap" ebay GM style tow mirrors. Well 5 fuses later, the mirrors still wouldn't adjust. So started a return, patiently waiting for the Boost Auto manual fold's to come back in stock. After checking everyday for 3 weeks, I finally reached out to Boost's sales staff. 36 hours later, I received an email that they had no ETA for when they'd be back in stock. Well 3 hours after I received that email, I received the notification they were indeed back!!! I couldn't order them fast enough. These are upgraded from the OEM style. I don't know what the normal mirrors are like on these, so I have no comparison to the OEM style. But upgrading from the OEM tows to the Boost tows is night and day. No more passenger side deadly blind spot. The (high output) back up spots are amazing. Did I mention no blind spot on the passenger side. The 2 upgrades I got was the high output spots, and signal/marker 1.0. Not cheap, but worth the peace of mind and safety factor.
    3xYOTA, WFD473, Rgross2112 and 23 others like this.
  2. May 1, 2021 at 7:06 PM
    Javelin
    Javelin New Member
    2021 Limited Cement
    Stock for now...
    Powder coated OEM Wheels
  3. May 1, 2021 at 7:17 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Finally ordered and installed the driver’s side grab handle today. Like everyone says, about 20 minutes. Cutting the notch for the wire bundle was the longest part of the whole thing, and that was 5 minutes. Sparks delivered the kit with the extra bolt, washer and flange nut that you need. My local dealer parts guy couldn’t even find it as an option for my truck.
    whodini12, 3xYOTA, WFD473 and 22 others like this.
  4. May 1, 2021 at 7:32 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    They’re designed and made for this truck.
  5. May 1, 2021 at 7:44 PM
    Classy63
    Classy63 Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    Installed my TRD replacement dirty deeds exhaust and tail pipes. I cut them so they both dump after the rear axle. Welded on some exhaust tips and damn I am happy. After I installed the JBA long tubes and 3 inch after market cats, the truck was noisy and sounded like a cherry bombed 80’s camaro, now it isn’t loud, but still sounds bad ass. Cruising at about 75 mph, the tires noise on my ridge grapplers is actually alittle louder than the exhaust.
  6. May 1, 2021 at 8:40 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    DIY 2.5 / 1 lift/level using bilstein 5100 mid setting+ 2 CB shims each side and 1 in rear shackle. Next weekend is pay to play wheel/tire day staring ICON rebounds in titanium and cooper XLT in 305/70 17 followed by an alignment.
    Before and after;
  7. May 1, 2021 at 8:47 PM
    Yungtech86
    Yungtech86 New Member
    2020 Platinum
  8. May 1, 2021 at 8:47 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    If your keeping the nerf bars I suggest painting them black.
    carsonhudson likes this.
  9. May 1, 2021 at 9:08 PM
    Lightning_Lad
    Lightning_Lad New Member
    Tom
    Orange CA
    2017 Silver Sky Platinum Pro
    Line x Bed liner Trifold Tonneau cover TRD PRO Dual exhaust TRD PRO sway bar TRD PRO air intake TRD PRO suspension TRD PRO LED 2019 Headlight conversion TRD 2020 Wireless charging tray TRD shift knob TRD PRO Grille TRD red anodized dust caps (+25 hp per wheel) Matt black mirror caps and door handles Tesla style Headunit KTJO 4x4 tail gate pop n lock upgrade Driver side grab handle Viper Remote start Viper alarm system 18” Method NV’s 33.5” Toyo R/T ESP Long box underseat storage 3M ceramic tint
    Paid.
    It.
    Off.
    Which feels great, now just waiting to see what happens with my annual walk thru with landlord in 2 weeks.
    That is... If she’s gonna work something out legally for me to buy it.
    Which will seal the fate of my Tunny...(quietly sobs inside).
  10. May 1, 2021 at 9:21 PM
    IndianaGeologist
    IndianaGeologist New Member
    I didn't know you had left any time for yourself?! :rofl:
    Sounds like you've got it dialed in man!
    Classy63[QUOTED] likes this.
  11. May 1, 2021 at 11:28 PM
    Bikeordie1
    Bikeordie1 New Member
    Jeremy
    Ferndale, WA
    2015 MGM Doublecab SR5 5.7
    Motegi 17x8.5, Wildpeak 285/70R17
    Spent all afternoon cutting a crazy amount of shitty wiring/harnesses out from around my battery and behind the grille and everywhere else. Previous owner had bargain LED headlights with drivers, and must have had light bars and lots of accessory crap, and then just cut it all out before trading it in. It was all so shoddy. Ripped it all out and replaced the corroded battery terminals with commerical grade ones. Plus did the "ultimate headlight upgrade" with osram bulbs and a Headlight Services custom harness. The harness is such high quality, would definitely recommend it! Here's the mess I removed
    While I had the grille off I noticed these 2 wires hanging around ... Anyone know what they're for?
    pvn.beluga, GAknight, WILLINH and 2 others like this.
  12. May 1, 2021 at 11:36 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    In your second picture it looks like the wire and connector for the second horn based on how it splits. Do you have only one horn behind your grill?
    mgm16trdpro and NewImprovedRon like this.
  13. May 2, 2021 at 12:51 AM
    kleiker0303
    kleiker0303 New Member
    Kyler
    Kansas City
    ‘16 Platinum
    Bilstein 6112 @ 1.9" Bilstein 5100's in rear Afe drop in filter Afe intake tube Afe throttle body spacer Afe catback with vibrant resonator added Stubby antenna TRD front grill Paint matched door handles Paint match mirror caps RCI skid plate All LED bulbs Undercover flex cover 20% tint all around Husky floor liners ESP under seat storage 2018 headlight mod Baja designs fog light kit 275/60/r20 falken wildpeak at3w 20x9 fuel ripper
    what size tire? Looks good!
  14. May 2, 2021 at 7:16 AM
    EricD
    EricD And so it begins.
    Eric
    North Carolina
    2021 Toyota Tundra
    Installed a BedRug and a Tyger Trifold bed cover on the same day I took delivery of the new ride. And so it begins.Screen Shot 2021-05-02 at 10.04.12 AM.jpg Screen Shot 2021-05-02 at 10.04.58 AM.jpg Screen Shot 2021-05-02 at 10.05.23 AM.jpg Screen Shot 2021-05-02 at 10.07.14 AM.jpg Screen Shot 2021-05-02 at 10.07.15 AM.HEIC.jpg
    3xYOTA, EN2TUNDRA, WFD473 and 27 others like this.
  15. May 2, 2021 at 7:16 AM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Thanks for the compliments. I bought the headlight harness from @iHacker. Quality guy / part and plug and play to the ‘19 TRD Pro black headlights afterwards. The Rigid fogs were plug and play but you’ll also need new bezels. I bought the ‘21 Rigid fogs from a good member here, but you can get new from Sparksparts, McGeorge online, or other.
  16. May 2, 2021 at 7:21 AM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    Looks legit! Which one did you order? And you ordered 2?
  17. May 2, 2021 at 7:23 AM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    Nice!! How was the install?
  18. May 2, 2021 at 7:25 AM
    EricD
    Eric
    North Carolina
    2021 Toyota Tundra
    What size Tire, Wheel and Offset? It looks perfect.
  19. May 2, 2021 at 7:41 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    TE37s?
  20. May 2, 2021 at 7:46 AM
    ChrisLopez
    ChrisLopez New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    Just installed this bad boy yesterday. It’s the kenwood DMX7706S. Got a good price for it being an open box item and the mic was missing so took a couple bucks off it from Best Buy. They even do free installation and the tech there was very detailed with what I needed to keep factory things like steering wheel controls and usb. The job came out really professional as well. Couldn’t be happier. Will be looking to get a wireless adapter for wireless CarPlay.
  21. May 2, 2021 at 7:56 AM
    16MagSR5
    16MagSR5 New Member
    Buffalo
    Install was pretty easy, but I'm also getting pretty good at pulling my door panels and replacing mirrors:rolleyes: Boost provides detailed instructions(if needed) and also the location to hook up the reverse lights to. I already had my drivers side fished into the cab from the E-bay lights. So I just had to fish the wires in the passenger side. If I had to guess, total time would be about 2-3 hours, with fishing the 2 doors and hooking up the reverse lights. I'm going to change that wiring in the future to a double pole switch. That way I can have them on with reverse, off completely, and on anytime. Figured those options would be good for camping.
  22. May 2, 2021 at 8:01 AM
    carsonhudson
    carsonhudson New Member
    Thanks! 295/60/20
  23. May 2, 2021 at 8:22 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Put my stock exhaust back on. Took off the DD 10”. Will be for sale soon enough.
  24. May 2, 2021 at 8:29 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Finally installed air bags and cradles...
    GAknight, BlueRibbon4x4 and Fotnot like this.
  25. May 2, 2021 at 9:02 AM
    jb04
    jb04 New Member
    2019 Tundra Limited double cab
    Great looking truck!What size tires you running?
  26. May 2, 2021 at 9:08 AM
    Bigkitchens
    Bigkitchens New Member
    Alabama
    2014 1794 crewmax 4x4
    Front and back trd sway bars, 14 inch magnaflow dual in dual out exhaust, undercover bedcover, rough country 2 inch leveling coilovers and rear shocks, 285/60/20 nitto ridge grapplers, wireless charger, driver grab handle, tech12volt 10 inch sub and enclosure upgrade , and stillen cold air intake .
    Man that looks awesome
    Javelin[QUOTED] likes this.
  27. May 2, 2021 at 10:05 AM
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Agri-Cover,RCI skid,ADARAC,Fox 2.0,TruDuals
    That looks great! Trendsetter for sure.
  28. May 2, 2021 at 10:12 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Can I ask why?
    NewImprovedRon likes this.
  29. May 2, 2021 at 10:19 AM
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    No Flares please. Truck Looks Bad Ass as it sits now.
    AggiePhil, Seffagus and Blkdmax like this.
  30. May 2, 2021 at 11:00 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I am replacing my head unit, speakers, a sub,sound insulation and the more I drove it the more I wanted quiet. Seemed like it got louder and wore on me. I do have a 75-80 mile commute. I will sell it and get Trd Pro headlights.
