  1. Apr 30, 2021 at 9:21 AM
    #6301
    Taco-Spike
    Two Trucks
    Hadn't thought of that. I'll look into it
  2. Apr 30, 2021 at 9:26 AM
    #6302
    Taco-Spike
    Two Trucks
    Agreed.
    My lady has been going for a rustic / industrial look of Dark wood with black metal accents (To match some of the furniture) So I thought black screw heads might not look too bad?
  3. Apr 30, 2021 at 9:31 AM
    #6303
    Taco-Spike
    Two Trucks
    Very valid point.
    Maybe I could use a piece of scrap wood as a template for pilot holes. Might be a pain but better results in the end.
  4. Apr 30, 2021 at 9:52 AM
    #6304
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Pencil marks and a square work well and a damp rag will typically get rid of the marks.
  5. Apr 30, 2021 at 10:45 AM
    #6305
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Are you looking for a functional slat-wall like they use in retail or garages where you can hang things from the slots, or just for appearance? If you want rustic, then I'd say you want to avoid having everything look uniform - the more you introduce some randomness to it, the more rustic it will look. No need to attach at every stud if you aren't using the slats for hanging things, and finish nails (pneumatic driven 16GA or 18GA would work well) would be essentially hidden with a little filler.
    If you plan to use it as a hanging/racking system, you might also consider looking at some washer-head style screws as opposed to just regular wood screws - make sure you have enough length to go through your slats, the 1/2" sheetrock, and at least 1" into the stud (but no more than 1-1/2"). And I would definitely pre-drill OR use screws that have self-drilling tips (but would still pre-drill anything within 6" of the end of a board).
    TaquitoBandito likes this.
  6. Apr 30, 2021 at 10:55 AM
    #6306
    Taco-Spike
    Two Trucks
    aesthetics mainly. Wouldn't hang anything more than some canvas art work or similar
    Yeah, definitely going pre-drill now.
  7. Apr 30, 2021 at 2:00 PM
    #6307
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Only took 3 tries to get it to not leak :)
    Thanks for your help!
    KjBQSs6TZ7k5Jvl5YNNFF6VrEfJ_FmDIvKX7WUVT_9bc08e8da3c475411adfe3908063eb0bfa3bbc9f.jpg
  8. Apr 30, 2021 at 5:12 PM
    #6308
    RainMan_PNW
    Casey
    Clark County, WA
    Now you gotta get the ice made and have a celebratory cocktail!
  9. Apr 30, 2021 at 6:35 PM
    #6309
    Danimal86
    Daniel
    Sacramento, CA
    :cheers:
  10. Apr 30, 2021 at 6:54 PM
    #6310
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    I have a Client Redoing the Kitchen and at the last minute changed his mind and had to have a TV in there.
    They run a slide show of family photos,watch TV and I thought could also use it to see who is at the front and back doors when they ring too.
    The problem is that there is no space at all for a TV in there and she does not want anything on the counters at all so I mounted this Baby Samsung Frame on the only unused wall in the entire Kitchen and you can see it easily from everywhere in there too somehow too!
    When it is turned off it can display Art or the Slide Show or Family Photos.
    They LOVE it!
    Sometimes just have to think outside the box.
  11. May 1, 2021 at 6:02 AM
    #6311
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    The framing here is a little atypical.
  12. May 1, 2021 at 9:09 AM
    #6312
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    :monocle:
  13. May 1, 2021 at 12:55 PM
    #6313
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Assuming he means because there are no vertical studs
  14. May 1, 2021 at 4:18 PM
    #6314
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    You may want to do an online search for Clavos screws or nails. You can get them in square or round shapes. Just an idea.
    F61E721A-CE83-4504-9856-5C49A2E063B8.jpg 33B0793B-5793-4B89-9214-2AF4862DCE00.jpg 2768C55D-AAAB-4C50-B3A2-CD713B56C9A8.jpg 09411F61-4D33-4A2A-BC62-B336C4789A33.jpg
    CodyP, AZTundra, Fotnot and 3 others like this.
  15. May 1, 2021 at 4:25 PM
    #6315
    1UPPER
    TEXAS
    Flux capacitor!
    I took one of our lower 14” base cabinets and removed the upper draw and removed the lower two doors and shelf. I then installed a Rev-A-Shelf knife and utensils storage organizer. I reattached the upper draw front and the two lower doors over the organizer to match all of our cabinets. It helped eliminate the knifes on the counter top and organize all our cooking utensils. My wife is very happy!
    Before:
    After:
    ACB8355C-729E-4AB5-8448-7EEBC0321479.jpg 94274994-30D0-4EAA-BB67-0167B3665816.jpg
  16. May 1, 2021 at 4:53 PM
    #6316
    Taco-Spike
    Two Trucks
    Oh snap!
    I really like that! Definitely going to look into that. Really like that studded look, definitely what I think she and I would like. thank you, this is a excellent detail finish look
    1UPPER[QUOTED] and RainMan_PNW like this.
  17. May 1, 2021 at 5:16 PM
    #6317
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    finished pulling the pine hedges and roots out (4WD would have been nice :anonymous:) but we managed
    prepped the soil and planted the hydrangeas and rhododendron
    mulched 80% of the hedges with neighbors 3" chipper, will finish tomorrow.
    Have some Iris' to plant now
    about 40 sweet pea sprouts, a handful of beets and some self seeded buckwheat growing in garden. Should have high numbers next couple weeks
    Will try to get some pics of the hedges we pulled out
    Fotnot, JMB and RainMan_PNW like this.
  18. May 1, 2021 at 6:31 PM
    #6318
    TaquitoBandito
    Joel (AKA Bif)
    Okay, that's pretty freakin' awesome. I need to talk to my wife.
  19. May 1, 2021 at 6:47 PM
    #6319
    ZPhilip
    Philip
    West Chester, PA
    Yes, no vertical studs on left and right walls aside from outer edges of shower.
  20. May 1, 2021 at 7:06 PM
    #6320
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Does this count? Added a adult beverage fridge outside...2021-05-01 13.52.28.jpg 2021-05-01 13.52.13.jpg
    aperezsh, drobb, Baja Mike and 7 others like this.
  21. May 1, 2021 at 7:11 PM
    #6321
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    For thr way you're using it....yes sir!
  22. May 1, 2021 at 8:17 PM
    #6322
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Built out a niche, which is why it looks like that...
    I_Am_Thee_Walrus likes this.
  23. May 1, 2021 at 10:11 PM
    #6323
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    If anything in this thread counts, this one absolutely does.
    CodyP likes this.
  24. May 3, 2021 at 6:48 AM
    #6324
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Two niches for shower - done. Now I’ve got the plumbing for the other side.
    Any tips I should know about using PEX and shark bites?
    It seems straight forward from the YouTube guy: renovision
    Also... cutting 24x48 tiles... score and snap or wet tile saw? I’ve been seeing people use bridge saws, but man those are expensive and don’t think my local HD carries a rental.
  25. May 3, 2021 at 6:59 AM
    #6325
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I’ve done pex with sharkbites plenty. It’s super easy, and they push to connect just as aggressively as with copper. Just make sure you get any plastic burrs off the end of the pex and make sure the cuts are straight across before pushing the sharkbite on.
    You might be able to get a half decent price on a scoring board that can handle that size tile. Or, believe it or not the $350 harbor freight “tile and brick” saw can handle it but you’ll need a helper to hold the other end of the tile to help feed it through. If your local Home Depot rents the 10” dewalt tile saw, it’s the same design as the harbor freight one so it would work too. You’ll also want an angle grinder with a nice porcelain blade as a pinch hitter.
    Also, make sure you hit those cement board seams with alkaline resistant fiber tape and a polymer modified cement mortar before you waterproof the walls.
    I hope that helps!
  26. May 3, 2021 at 7:03 AM
    #6326
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Awesome! Thanks for the tips!!
    Would drywall mesh tape be the same as the one you're suggesting? As for waterproofing, I'm hearing either redgard or mapei, but I think I may go towards mapei aquadefense for the waterproofing.
  27. May 3, 2021 at 7:06 AM
    #6327
    Squatting Pigeon
    Holden
    North Texas
    No the drywall tape will break down in wet environments, and the high alkalinity of the mortar will also affect it. They sell special tape for cement board in the tile tool section at Lowe’s and HD. it’s only a few bucks and well worth it.
    Full disclosure, I work for MAPEI so that’s gonna be my suggestion :rofl:
    Also make sure you do at least two coats on everything, not just the cement board seams like they do on YouTube :rolleyes:
  28. May 3, 2021 at 7:22 AM
    #6328
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    HAH! Great to know that Mapei Aquadefense is going to be an absolutely amazing product :rofl:
    Copy that on the alkaline specific tape. Thanks!
  29. May 3, 2021 at 10:58 AM
    #6329
    Squatting Pigeon
    Holden
    North Texas
    Happy to help :D
    TaquitoBandito and RobertD like this.
  30. May 3, 2021 at 11:32 AM
    #6330
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Yea, I am a girl, so I thought any wood you were putting on, in, or near the ground had to be pressure treated regardless of paint etc. I learned something new...
    It's actually getting used for a non edible garden/grave (the two cats) area, so no worries about the chemicals.
    Thanks for the info!
    -T
    CodyP[QUOTED] likes this.
