Rubbing issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Elfine, Apr 29, 2021.
  1. Apr 29, 2021 at 6:05 PM
    Elfine
    Elfine [OP] Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
    Alright internet geniuses. I just bought some 17" Method 305s (0 offset) and 35x12.5 tires and I am rubbing on both my body mount (bmc has already been done) AND the body beside it. I also have a 2.5" lift on the front. What do I need to do to fix this? I have read a bit about castor adjustment, but I don't understand what that does or how far to go. Thanks in advance.
  2. Apr 29, 2021 at 6:21 PM
    Stock control arms I assume? You may need to lift a little higher....:notsure:
  3. Apr 29, 2021 at 6:26 PM
    Elfine
    Pensacola, FL
    No, I am running Icon tube uppers, with a Stage 5 kit. Everything should work, I have seen others do it, but mine is not. I am stumped.
  4. Apr 29, 2021 at 6:28 PM
    You're not running wheel spacers any longer are you?
  5. Apr 29, 2021 at 6:30 PM
    Elfine
    Pensacola, FL
    Not with the new setup no.
  6. Apr 29, 2021 at 6:36 PM
    Sunnier
    Sunny
    San Diego, CA
    Caster moves your wheels (and tires) forward = away from the cab mount. So if you get it aligned someplace that has a computer and only can get it to “factory specs” you’ll rub. Go to place that uses a laser... or old fashioned experience... get caster as close to +4 as possible, then work to get the camber and toe as close to spec as can be done, keeping caster high.
    Elfine[OP], 15whtrd and Tundra234 like this.
  7. Apr 29, 2021 at 6:36 PM
    Damn. I'm trying to think of what could cause it to still rub after the mount chop.
    Elfine[QUOTED][OP] likes this.
  8. Apr 29, 2021 at 6:45 PM
    Elfine
    Pensacola, FL
    I will do that, thank you for the advice!
    Sunnier[QUOTED] likes this.
  9. Apr 29, 2021 at 6:45 PM
    Elfine
    Pensacola, FL
    Yeah same. All the research says it should clear. And I definitely shouldn't be rubbing the body itself with 35s
