CEL Codes p0441, p0446, p0455 and can't fill up with gas
Discussion in '1st Gen Tundras (2000-2006)' started by nickniebuhr, Apr 25, 2021.
  1. Apr 25, 2021 at 9:19 PM
    nickniebuhr
    nickniebuhr [OP] New Member
    2004 Limited 4WD
    Hey everyone,
    I just bought a 2004 Tundra a few weeks ago and have been chipping away at little things to get it up to my standards. A couple bigger problems I've been having are the Check Engine Light turned on, throwing the p0441, p0446 and p0455 codes, and since I bought it it won't fill up with gas. Like it clicks off immediately, and I have to fill it super slow with the plunger pulled back by hand. It's like filling through a small funnel. Are these issues most likely related? To my understanding it sounds like I have a clogged vent hose somewhere, but there are so many hoses down around the gas tank I'm having a hard time figuring out which ones to focus on.
  2. Apr 25, 2021 at 9:41 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Try swinging it gangsta style... then look at possibly replacing the evap emissions canister, or something like that.. relieves pressure when you're filling up gas.
  3. Apr 25, 2021 at 9:44 PM
    nickniebuhr
    2004 Limited 4WD
    Ok so to confirm, a full/clogged evap canister can back up the gas filling? Anything cheaper I can check/replace first before the evap canister?
  4. Apr 25, 2021 at 10:06 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    How many miles do you have on your truck? I had my CEL come on a while back for a faulty canister. I changed the valve on the canister and I haven’t had an issue since. Been about a year now.
  5. Apr 26, 2021 at 3:24 AM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    My 04 had the same issue filling up with gas...I got my pressure washer out and sprayed everything off underneath the truck around the gas tank and it must have dislodged something. Every once in a while I hit it with the hose while washing. Never happened again.
    nickniebuhr[OP] likes this.
  6. Apr 26, 2021 at 4:06 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  7. Apr 26, 2021 at 4:12 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Thats a great video explanation. Thankfully the 2000-2002 don’t have these Gas Vapor near gas tank box thingys. Toyota started that in 2003 iirc.
    NewImprovedRon and tvpierce like this.
  8. Apr 26, 2021 at 11:38 AM
    I have te p0441 code and can fill up fine, so you can eliminate that as the culprit.
  9. Apr 26, 2021 at 6:15 PM
    nickniebuhr
    2004 Limited 4WD
    That video was very helpful, thanks for sharing. I've ordered the valve for now, and I'm gonna start by testing both of those vent hoses tonight by loosening them and filling up, hoping that that's where the block up is happening. We'll see.
    BubbaW[QUOTED] likes this.
  10. Apr 26, 2021 at 7:01 PM
    terrward
    terrward New Member
    2004 DC SR5
    For anyone looking to replace one, the cheapest canister vent valve I found that was OEM is the WVE one from rock auto.
  11. Apr 27, 2021 at 6:25 AM
    nickniebuhr
    2004 Limited 4WD
    Ok rookie question: how do you remove the hose going into the purge valve?? The one with the weird plastic clip
  12. Apr 27, 2021 at 7:35 AM
    terrward
    terrward New Member
    2004 DC SR5
    Two picks on either side to lift up the tabs. Took me a good 5-10 minutes to get that sucker off
  13. Apr 28, 2021 at 12:37 AM
    sr52000
    sr52000 New Member
    2000 Toyota Tundra SR5
    I'd start with simple stuff first . I had codes for evap system and decided to take a look at my vacuum hoses in the engine bay before I start throwing parts at it . Got myselt 10ft of rubber hose and replaced all those vacuum lines , problem fixed .received_833963564136411.jpg received_833963564136411.jpg received_536190804044004.jpg received_842902386575023.jpg
  14. Jul 13, 2021 at 3:06 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I hopped in my truck to go drop off some scrap metal and I got p0441 and p0455. I remembered this thread and hopped out to tighten my 6 month old oem gas cap. It was not snug. should I clear these codes? What should I do next?
  15. Jul 13, 2021 at 3:13 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    doesn’t ever hurt to clear codes especially if you possibly found problem
    onesojourner likes this.
  16. Aug 26, 2023 at 11:30 AM
    PresidentsDad
    PresidentsDad New Member
    Marcus
    2010 Silver Sky Metallic Double Cab SR5 4x4 5.7L
    New accelerator pedal
    Which hose was this one?? I too have the p0441 and p0455 and have already replaced the gas cap and purge solenoid. The hoses *seem* to be in good working order, but it's hard to tell.
  17. Aug 26, 2023 at 11:34 AM
    Note: You're replying to a thread in the subforum for 2000-2006 Tundras, and it looks like you've got a 2010. Our part numbers are not the same as yours. The member you're replying to hasn't logged in since January, also.
    FrenchToasty and TX-TRD1stGEN like this.
  18. Aug 27, 2023 at 7:39 PM
    PresidentsDad
    Marcus
    My bad...thanks for settin' me straight.
  19. Aug 28, 2023 at 5:07 AM
    Not setting straight, just giving a heads-up, in case nobody answers. :thumbsup:
