Bilstein 5160 or shackles?
Discussion in 'Suspension' started by jscerbo13, Apr 26, 2021.
  1. Apr 26, 2021 at 9:05 AM
    jscerbo13
    jscerbo13 [OP] New Member
    I just put the 6112s up front at 2.5. Looks like it’s squatting in the rear just a bit. The bilstein 5160 and shackles are the same price. Which options do you guys prefer for the rear? Thanks in advance 9F16EEC4-5ACF-464C-983D-78FDD2726456.jpg62E88F52-B3A2-4E9E-8DDB-5EA66076FF9F.jpg
    Astom22 likes this.
  2. Apr 26, 2021 at 9:11 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    2021 Cement CrewMax 4x4
    They are two different things. The shocks provide no lift. You’ll need both. I recommend toytec shackles and whatever rear shock you want.
  3. Apr 26, 2021 at 9:16 AM
    jscerbo13
    the description on website says 0-1.5” for 5160. Or am I reading that wrong and it’s for trucks that are already lifted up to 1.5”?
  4. Apr 26, 2021 at 9:17 AM
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    The 5160 is just the shock, it will provide no lift, so you want the shackle. However new shocks in the rear are not a bad idea. You can save some money and just get a set of 5100 shocks. They will allow for a little extra lift and still provide a nice ride.
    Toytec and Boss-offroad shackles are both a good place to start. Both are adjustable to 1" or 1.5" of lift. Lots of people like Coachbuilder too, but the other ones are rock solid as well. I have the Boss-offroad ones and they are super beefy. Replacement bushings are also only $20 extra bucks which is definitely worth it. The old bushing will be a bitch to get out, but still, it'll be worth it.
    diablodalton and TRDFerguson like this.
  5. Apr 26, 2021 at 9:18 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The shocks are designed to handle a lift of up to 1.5". As others have already pointed out, the shocks themselves provide no lift.
    diablodalton, The Dude and Elduder like this.
  6. Apr 26, 2021 at 9:18 AM
    Elduder
    Elduder New Member
    5160 has enough additional travel to accommodate up to a 1.5" lift before it tops out. As the others stated, it provides no lift.
  7. Apr 26, 2021 at 9:19 AM
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    They are suitable for trucks with 0-1.5" lift, i.e. they are a bit longer to accommodate the lift. So whether you lift with block, shackle, or new leaf springs, the shocks just help with the extra droop required.
    TRDFerguson likes this.
  8. Apr 26, 2021 at 9:19 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    That’s just the range of lift the shock is rated for.
  9. Apr 26, 2021 at 9:27 AM
    jscerbo13
    Nice ok makes sense now. Just ordered the toytec shackles
    Hugemoose likes this.
  10. Apr 26, 2021 at 10:15 AM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    You will not regret it. Shackles with the 5160's. Best way to set it up. This is my rear setup: Coachbuilder +2 (1.25" lift) and Bilstein 5160.
    After it settled: Rear is 1" higher than the front. Exactly how I wanted it.
    Post your truck before and after. Thanks.
  11. Apr 26, 2021 at 11:09 AM
    jscerbo13
    hell yea looks great. Love that color. Will post pics once it comes in and I install
    Kawboykev likes this.
  12. Apr 26, 2021 at 11:14 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Make sure you replace the oem leaf bushings with the Polys that come with the shackles. Makes a world of difference in the ride.
  13. Aug 30, 2021 at 4:14 AM
    Kawboykev
    Kawboykev New Member
    21 tundra mgm
    XB headlights
    Did you ever finish up putting your shackles on the rear to lift it i wanted to see the before and after pics to see how everything leveled out thanks.
  14. Nov 30, 2021 at 3:03 PM
    EZDoes It
    EZDoes It New Member
    Ed
    LSD (Lower Slower Delaware)
    2020 MGM CM SR5 TRD exhaust, TRD wheels
    Tint, tow mirrors, remote start, Razormotor taillights, Genuine trans cooler, tailgate light strip, Extang tonneau, TRD rear sway bar, trans cooler…(thanks TRD)
    Okay, I really want to pull the trigger on 5160’s. Someone mentioned they rust quickly. Can anyone confirm/deny this info? I’m hoping it’s something they’ve resolved. Thanks for your help.
  15. Nov 30, 2021 at 3:38 PM
    AZBoatHauler
    So.Arizona
    From what I’ve seen personally and on the forum, it will depend on your climate/environment. I’ve had mine nearly 3 years and they still look new. I’ve seen pictures posted demonstrating if they use salt in the winter where you live, they’ll look like garbage in no time.
  16. Nov 30, 2021 at 3:39 PM
    EZDoes It
    Ed
    I wonder if it will help if I clear-coat them first?
  17. Nov 30, 2021 at 3:43 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I don’t have them, but it looked to me like it was the hose clamps that hold the resis to the shock body that rust first. There might be other clamping options or you could mount them remote.
    EZDoes It[QUOTED] likes this.
  18. Nov 30, 2021 at 3:52 PM
    ArdnuT trd
    ArdnuT trd New Member
    Blake
    2021 Tundra MGM TRD 4x4 CM limited
    Hey guys I have similar questions to OP. HOPE I CAN ASK as I'm new to 21 tundra. I bought 6112. They are at 1.9. Now I read the ride at 2.5 was rough, is this true? I'm after a little more lift and came across a 21 trd pro suspension for under 2k with 15k miles on the set. All I want is a little more stocky tire than factory bc the michelins are like a lifter who skips leg day. What do you guys recommend? Take out my 6112's and get trd shocks or preload more like OP and get shackles and shocks? I don't want to chop anything have trd sway bar in the garage. My truck is a dad wagon won't see anything of what I'd call serious off road but I want the best ride. Wish I could've just got a pro with grey leather
  19. Nov 30, 2021 at 4:00 PM
    EZDoes It
    Ed
    Anyone know if these shackles will work with TRD dual exhaust? I thought I remembered seeing there’s interference with this set up.
  20. Nov 30, 2021 at 4:11 PM
    ArdnuT trd
    Blake
    I have trd dual exhaust I was planning on running this setup
  21. Nov 30, 2021 at 4:12 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Note that you can run coachbuilder +3 shackes with the 5160, per dave at coachbuilder. The tundras suspension will limit the articulation enough so it would not cause issue running 1.75" lift on the 5160s.
    edgewardoe and EZDoes It like this.
  22. Nov 30, 2021 at 5:32 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The shackles themselves won’t interfere, it’s the lift from the shackles that can cause issues though. Some have had to chop the tail pipes because the leaf springs will hit the pipes at full droop. This will be with shackle lifts over 2” - a block lift won’t change where the leaf is relative to the exhaust. But also, don’t run block lifts lol.
    AZBoatHauler likes this.
  23. Dec 1, 2021 at 7:59 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    I live in New England (s. Maine). I have 6112 and 5160.
    1) you can buy a clamp that holds the reservoir to the shock body instead of the hose clamps. Its aluminum and doesn't rust.
    2) the 5160 and the 6112 are carbon steel bodies. In Southern Maine my shocks looked great over the summer installed in May, Come may the following year they look like they lived at the bottom of the ocean. This is true for the front 6112 and the rear 5160. I fluid filmed them when i installed, however, it didn't help.
    The shafts are chrome and still look okay, just the shock bodies that have surface rust. I don't think it effects them. Just looks terrible.
    Also the cap on my driver side (dust cover) is hanging up off the shock on the 6112.
    Not sure I'd recommend them for Rust belt areas. They ride is good and they seem to work fine. I read the manual, that called them aluminized steel bodies and misunderstood that to mean they had aluminum shock bodies.
    I strongly recommend you clear coat them or install some sort of a clear sticker as the area under the clear part of the Bilstein sticker is looks clean underneath. Unfortunately i don't have any good pictures as I'm not near my truck.
    I really like the look of the falcons, they look like they are not carbon steel but aluminum bodies? I'm not sure if anybody has had them long enough to know if they rust.
    Hope this helps
    I realize a picture would drive the point better.
    TRDFerguson and EZDoes It like this.
  24. Dec 1, 2021 at 8:07 AM
    EZDoes It
    Ed
    Thanks for the info. I think I will have someone clear coat them before installing.
  25. Dec 1, 2021 at 8:45 AM
    MadMaxCanon
    Would spraying them with Barricade once in a while help i wonder?
  26. Dec 1, 2021 at 8:45 AM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
  27. Dec 1, 2021 at 9:33 AM
    EZDoes It
    Ed
  28. Dec 1, 2021 at 1:01 PM
    Danman34
    Danman34 New Member
    Danny
    I have over 38k miles on my 5160s. Zero issues. Zero rust. I also don’t live in an area that sees snow and I wash the truck regularly. But anything will corrode or rust if you don’t take care of it
  29. Dec 3, 2021 at 8:09 PM
    Quicksand_Tundra
    Jon
    Yes. This setup will work with the TRD Dual Exhaust.
    Here is mine:
