  1. Apr 26, 2021 at 7:46 AM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    I woke up this morning concerned about previous work done by my mechanic. If he used aftermarket ball joints even after I specifically asked for Toyota ball joints... what if he used an aftermarket timing belt as well?!? Guessing I have to take the front of the engine apart just to check?
    Fairly soon after the timing belt change I started getting a squeaking/screeching sound when I’d 1st start my truck in cold weather. I thought it could be my power steering pump on its way out but it’s been over a year now and my power steering is still working. Became constant at start ups a couple months ago and I did a power steering flush. Sound still there 50% of the time on start ups, gets quieter once warmed up but there is still a little whining sound that’s constant, even when I don’t have the louder screeching sound on start up.
    Checking my timing belt is a must for me at this point. I sure would like your thoughts and opinions on this as well.
    Thanks!
  2. Apr 26, 2021 at 7:49 AM
    The belt changes require the cooling system to be opened up. The coolant that spills onto the belts and pulleys is slippery. If it's not cleaned up, it can cause slippage and squealing. Bad tensioner bearing, bad new water pump bearing, obviously could be the power steering, but I hate to believe in coincidences. They do exist, I just try to chase back what I've recently changed that could be causing it.
    Voss likes this.
  3. Apr 26, 2021 at 7:52 AM
    In just a few minutes you can pull back the timing cover on the passenger side to see the belt. I'm not sure if you could easily tell what brand it is without pulling it back a bit more though.
    Voss[QUOTED] likes this.
  4. Apr 26, 2021 at 7:54 AM
    Voss
    Valod
    2003 AC TRD 4x4
    You just reminded me, soon after the timing belt change, I had some sort of leak where most of the front of my engine was covered in a pink fluid. Mechanic fixed it at no charge, told me it was a faulty gasket we hadn’t changed. That stuff would’ve of definitely gotten on the belts.
    KNABORES[QUOTED] likes this.
  5. Apr 26, 2021 at 8:01 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Pricing is kind of fixed. Most plumbing shops I have worked at have a book price that includes replacing supply lines and the gas line, the problem is not a single shop monitors prices actually charged. Changing the shut off is commonly needed if its a gate valve but is considered extra. Depending where you live (outside of earthquake country) if your heater is hard lined with copper, thats what he should have replaced the piping with.
    I hate plastic lines. As if we didn't learn our lesson with butyl 50 years ago, it drives me nuts to see plumbers using pex and wirsbro and I cringe when I see them using sharkbite couplers.
  6. Apr 26, 2021 at 8:11 AM
    All my copper cold water pipes sprung leaks under the slab. Everyone in my neighborhood had the same. Also the 5 sq. mile radius around me had the same thing. Copper ain't the end all be all. Replumbed with PEX.
    MS22 and FrenchToasty like this.
  7. Apr 26, 2021 at 8:14 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    With stock exhaust it fits. With duals or anything custom its harder to say.
    NUDRAT[OP] likes this.
  8. Apr 26, 2021 at 8:25 AM
    Yeah I’m still wondering if I can fit anything underneath at all
  9. Apr 26, 2021 at 8:32 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Mine doesn't fit for now but im going to revise things some day and maybe make it fit. I'm tired of the spare being in the bed.
  10. Apr 26, 2021 at 8:34 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    The shop mechanics here should start some "customer states" editions
    CodyP, bmf4069, Voss and 1 other person like this.
  11. Apr 26, 2021 at 8:38 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Depends where you live really but slab leaks are more common than they should be. The lime in cement will eat through copper, copper should be shielded from the cement but if it isn't thats what happens. Most slab leaks I have fixed revealed copper through cement. Similar happens if you have galvanized touching copper directly. You'll eventually leak at a joint or get a random pinhole.
    Its trading one problem for another. Pex won't likely leak under a slab but in the walls or ceiling I have seen rodents chew through it. Never seen a rat eat copper.
    bmf4069 and Voss like this.
  12. Apr 26, 2021 at 8:47 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  13. Apr 26, 2021 at 8:50 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Load me up in there when I die.
  14. Apr 26, 2021 at 8:59 AM
    Is it a BMW M3? I would never buy it but I don't hate it. Reminds me of something you'd see in that DIWhy subreddit.
    Darkness likes this.
  15. Apr 26, 2021 at 9:22 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I was thinking M4 but not sure. I would love to drive it but like you wouldn't want to own it.
  16. Apr 26, 2021 at 9:32 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ll be going custom after the 33s.. I can make that work
    Voss and Darkness[QUOTED] like this.
  17. Apr 26, 2021 at 9:47 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    NUDRAT[OP], Voss and Darkness[QUOTED] like this.
  18. Apr 26, 2021 at 10:20 AM
    speedtre
    speedtre New Member
    Inland Northwest
    My 255/80/17 fits a charm...
    empty_lord[QUOTED] likes this.
  19. Apr 26, 2021 at 10:41 AM
    empty_lord
    05 rollover special
    I’m just praying I won’t rub! Lok
    Voss and speedtre[QUOTED] like this.
  20. Apr 26, 2021 at 10:52 AM
    So I've heard there is a shortage of new vehicle inventory on some models because of the microchip issue but I didn't realize the extent of it. I drove past our Toyota dealer Saturday and the lot was only around 60% full. In 15 years, I've never seen more than a few open spots in their lot. Maybe demand is high as people spend their stimmy?
    @empty_lord is your dealer low on inventory?
  21. Apr 26, 2021 at 11:00 AM
    empty_lord
    05 rollover special
    We have probably 40% inventory
  22. Apr 26, 2021 at 11:09 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I've knocked toyota for being behind the times here and there. My wife's gx is no exception. There are some things that mercedes did better and that's comparing a 2012 gx and a 2013 ml350. I'd say they are similar vehicles or for a similar potential customer. I have much more faith in the gx after the 150 or 200k mark than the mercedes. Not much on the gx is untried technology or design, even starting at 2010 (the first year of the gx460).
    Sounds about right.
    onesojourner and chrisb like this.
  23. Apr 26, 2021 at 11:24 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    We have the same 'take a seat' sign above the commode in our main floor bathroom.
  24. Apr 26, 2021 at 11:30 AM
    I don't think it's the chips. When I was looking at motorcycles the dealers had low stock then too. Basically like 1 of each type to choose from.
  25. Apr 26, 2021 at 11:38 AM
    empty_lord
    05 rollover special
    New wheels for tundra will be here tomorrow
    NWPirate and onesojourner like this.
  26. Apr 26, 2021 at 11:46 AM
  27. Apr 26, 2021 at 11:46 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    VOLK TE37?
    bmf4069 and Darkness like this.
  28. Apr 26, 2021 at 12:22 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think just for sleeping I could work with it, but it sends me back to my own method of "carrying a tent is better". The amount of fabrication they did is a bit of unnecessary effort I think.
    Jack McCarthy[QUOTED] and Voss like this.
  29. Apr 26, 2021 at 12:24 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Just ordered new lower ball joints from one of the sites I've seen reco'd here... About 40% less than what stealer wanted AND, these OEM ball joints are cheaper than the aftermarket ones I paid for through the mechanic. Good start to the week.
    KarmaKannon, bmf4069, MS22 and 3 others like this.
  30. Apr 26, 2021 at 12:41 PM
    That mechanic is an asshole. You should let him know.
    RUSTYNUTS, KarmaKannon, MS22 and 4 others like this.
