TRD Pro grill backlit TOYOTA
Discussion in 'General Tundra Discussion' started by RoasterOven, Apr 26, 2021.
  1. Apr 26, 2021 at 6:45 AM
    RoasterOven
    RoasterOven [OP] I make custom Tundra lighting
    Jordan
    Columbia, SC
    2017 Tundra Crewmx SR5
    TRD Pro grill Color matched bumpers Cold Air Intake Muffler delete Custom interior/exterior lighting
    I'm officially taking orders for the kit, it's completely plug and play.
    It retains stock letters (they go on top of my letters)
    In it's stock form it taps into the 10A ignition fuse so they turn on whenever the key is turned or remote start is initiated.
    I can also do addons like dimmers and remote switches, if requested
    PM for more info, questions, and pricing
    20201230_164345.jpg 20210425_202011.jpg 20210425_193219.jpg 20201226_180740.jpg
  2. Apr 26, 2021 at 7:38 AM
    OV-1794
    OV-1794 New Member
    Looks clean, how much and what’s the install like if you’re saying plug and play?
    cdavi060 likes this.
  3. Apr 26, 2021 at 8:00 AM
    RoasterOven
    Jordan
    Columbia, SC
    Ok so in terms of my side of the kit it's all plug and play, but you have to carefully use a heat gun to remove the factory letters. That's honestly the hardest part
    Then drill a 3/8" hole in the grill behind where each letters sits so the male end of the power connector on each lette can pass through
    Then you stick my letters where the originals sit, then the originals on top of mine
    Then you run the harness across then through an opening beside the driver-side headlight and the ground goes to the chassis ground bolt beside the battery. And power comes from the fuse tap 20210421_165139.jpg
