Transmission Oil Cooler - Not Rehashing The Same BS
Discussion in '2.5 Gen Tundras (2014-2021)' started by 737fixer, Apr 25, 2021.
  1. Apr 25, 2021 at 2:26 PM
    737fixer
    737fixer [OP] New Member
    Not here to start more dialog on the tranny cooler debate although I completely agree Toyota absolutely lied to their customers the way their Monroney Label suggests a cooler IS installed.
    I know a ton of you have installed an aftermarket trans cooler and some have even said they had Toyota install it. I have spoken to three dealers in the East Valley of Phoenix and none of them will tackle this job so my warranty is covered.
    I realize there are laws that protect a person when installing aftermarket parts but bottom line is your still hiring an attorney to try and fight Toyota. Good luck with that.
    Question is, "Does anyone know for a fact whether or not the warranty will be covered if an aftermarket cooler is installed"? I purchased an 8year/125,000 warranty through Toyota and just want to make sure all will be good.
    Thanks as usual.
    AZ_Tundra1 likes this.
  2. Apr 25, 2021 at 2:38 PM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    My understanding is there's no way to know officially. That being said, 3 local dealers are all refusing to do the install and offer a warranty. If you were to have an issue with your trans and had installed a separate trans cooler, then reason suggests that the dealer would deny the claim, citing an aftermarket cooler. They're likely to look for a way out of warranty work.
    You can't void a warranty, but you can get your claim denied. Some options:
    1) keep the warranty and do trans fluid changes more often to preserve the trans. install the cooler once the warranty runs out
    2) install the cooler and accept the risk that if the trans had a problem, there's a chance it won't be covered by the warranty.
    3) Keep the warranty and trust Toyota's decision to remove the cooler
    co2owen likes this.
  3. Apr 25, 2021 at 3:37 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    I’m rolling with a combination of 1 and 3. Trusting but verifying.
  4. Apr 25, 2021 at 5:16 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    My suggestion if you have the ability to install cooler, car paid off you have no other debts and want a cooler install one. IF you have a transmission issue remove it before taking to dealer. Probably take an hour to remove cooler. 95% of transmission failures not caused by excessive heat or abuse is a shift solenoid. Drop pan and replace. Transmission needs a cooler, bad call on Toyota part but we all make bad decisions and that fine just don't repeat the same bad decision....
    As far as not covered by warranty I call BS. You signed a piece of paper when you bought your truck you would do forced arbitration. You have to arbitrate it was in the stack of papers at dealer..........
  5. Apr 25, 2021 at 5:16 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I’m rolling with #3. If it turns out that my transmission fails and it seems overheating was the culprit, then I will have bought my last Toyota truck.
    Clemsonman14, co2owen, LS3 and 5 others like this.
  6. Apr 26, 2021 at 9:48 AM
    co2owen
    co2owen New Member
    VA
    2020 Cement Limited CM TRD Off-Road
    Trans Cooler. 5100's up front at mid-setting. ESP Plastic Storage.
    After telling myself and others I would not install the trans cooler and would just let it run hot, I ordered a kit from genuinecoolingsystems.com this morning. Going to be a fun afternoon project for me and my dad to do together and who knows how many projects we have left to do together, so there's that.
  7. Apr 26, 2021 at 1:54 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    In theory they could deny a warranty on your transmission for the cooler being installed but if your radio dies they can’t claim it is not covered because you installed a transmission part. So if you install you are putting part of your warranty at risk but not voiding the entire thing.
  8. Apr 26, 2021 at 1:59 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Talk to Ben at AZ Toy Pros in Mesa. He was a former Toyota tech at one of the dealerships and knows his way around a lot of these issues. He can get you straightened out on what you can and can't do, and he's also able to do warranty work at his shop. (480) 687-4118
    Terndrerrr and Vizsla like this.
  9. Apr 26, 2021 at 2:01 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I detect a rehash.
  10. Apr 26, 2021 at 2:37 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    with a side of same BS
  11. Apr 27, 2021 at 4:37 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I hope that's not the case. It would be the end of a long run of Toyota truck ownership for ya!
    I still don't get how we can keep all of these posts going with the same topic but the question is delivered differently. Everyone has their opinions on the cooler or lack thereof before reading or starting these threads. Do what you want @737fixer. It's your truck and that's all that matters.
  12. Apr 27, 2021 at 6:03 AM
    Those are great kits that he put together. I installed the Hayden kit on mine. @2020Platinum has an excellent installation video. I pulled my TT after installing mine and my average trans temp was 192. Did you already order the Bluetooth module that monitors the temps? You will need it for servicing after the install as well. I got the fluid pump from AutoZone.
    2020Platinum likes this.
  13. Apr 27, 2021 at 6:14 AM
    IndianaGeologist
    IndianaGeologist New Member
    Why do you need the bluetooth module for servicing?
  14. Apr 27, 2021 at 6:27 AM
    The trans temp when servicing has to be between 99 and 111 when you pull the overfill plug.
  15. Apr 27, 2021 at 6:32 AM
    18" TRD Off Road Wheels
    No, you're not.
    Read the info linked in the first post here. https://www.tundras.com/threads/if-you-are-asking-can-this-void-my-warranty-please-read.60493/
    You don't try to take Toyota on in court. You report their violation of the law. You don't have to try and fight it. It also explains how your warranty CANNOT be "Void" for a mod. You make a claim, and it can be approved or denied. Worst case scenario, you wouldn't be able to get your transmission warrantied, but everything else would still be covered as normal. Odds of a transmission failure with or without the cooler are really low.
    Cpl_Punishment, Bammer and Dsptundra like this.
  16. Apr 27, 2021 at 7:34 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Do you buy the extended warranty and then trade your truck in once the warranty is up? If so, I maybe wouldn’t worry about a cooler.
    If you’re like me, and you want to get to 300k or even 500k miles (supposing people are still allowed to put gasoline in their v8 trucks by the time it would take to reach those milestones), I would definitely install one. Not telling you what to do; just telling you what I’d do.
    I haul heavy loads infrequently, off-road regularly in 4Lo, and tow a boat regularly (twice a month or more?) in season. You might use your truck differently than me, but I would not want 125k miles of my kind of use with no cooler, especially if those miles were racked up in your climate (I’m assuming you’re in AZ since you mention Phoenix dealers).
    First thing you could do before deciding to install the cooler is start regularly monitoring your temps. That might help you decide one way or the other.
    Bammer, IndianaGeologist and GODZILLA like this.
  17. Apr 27, 2021 at 8:33 PM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    I also installed the kit with the Hayden heat exchanger. I had a similar experience towing camper. Last summer I saw temps in the 230s just commuting without it.
  18. Apr 27, 2021 at 8:40 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    As mentioned above, they can’t void a warranty by installing an aftermarket part, but a claim can be denied if they can prove it was related to the addition of said part...this debate will go on forever, but all I know is I definitely was not comfortable with the temps I saw before install, and they’re WAY better after...here’s my install video if it would help, shoot me a message if ya have any questions!
    Transmission Cooler Install On 2020 Toyota Tundra
    https://youtu.be/5DLkja6vXvc
    SSPey, Bammer and Terndrerrr like this.
  19. Apr 28, 2021 at 5:06 AM
    co2owen
    co2owen New Member
    VA
    Yes, I have the Veepeak reader and the OBD Fusion app.
    Tundra234[QUOTED] likes this.
