2inches of sag
Discussion in 'Towing & Hauling' started by Dallas007, Apr 25, 2021.
  1. Apr 25, 2021 at 8:55 AM
    Dallas007
    Dallas007 [OP] New Member
    Dave
    2021 Tundra Pro Max
    Greetings,
    My trailer causes my 21 TRD PRO Crew Max to sag 2 inches (trailer only weighs 2500 lbs). Doesn’t seem bad enough for air bags but how about something like Timbren’s? Worth it or not? Thanks in advance.
    Dave
    IndianaGeologist likes this.
  2. Apr 25, 2021 at 9:00 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Might try some Helwig helper springs. I had them on my Tacomas and they worked well. I had the 1/2s. My boat weighs 5000 lbs. I estimate tongue weight at 400 or a little more. I have about 1" sag.
    Black Wolf likes this.
  3. Apr 25, 2021 at 9:09 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Unlevel your truck to get back the 2" of rake you're supposed to have for towing.
  4. Apr 25, 2021 at 9:10 AM
    Weight distribution hitch
  5. Apr 25, 2021 at 9:13 AM
    Since you have a Pro, your leveled already and this amplifies the problem.
    Are you having weird towing experiences? Towing for long distances?
    Reason I ask is limiting a suspension system you paid extra for. If it was me and I had to have it level:
    Airbags
    Daystar cradles.
    saybng, BlackSheep, snivilous and 4 others like this.
  6. Apr 25, 2021 at 10:46 AM
    Dallas007
    Dave
    2021 Tundra Pro Max
    It’s more of an esthetic thing. Tows fine, no issues. Thanks for the feedback
  7. Apr 25, 2021 at 11:02 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I think the pro's all look like they have some sag in the rear because of the front only lift.
    I would install some shackles out back to give it the normal truck rake stance.
    But other options would be fixing your tongue weight, a weight distribution hitch, air bags which i didn't like on my taco, timbres which I loved but really only help if you're bottoming out, helper springs, add a leaf, new leafs...
  8. Apr 25, 2021 at 11:34 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Needing a WDH to pull an empty 2500 pound trailer is treading close to oxymoron territory. :rofl:
  9. Apr 25, 2021 at 11:35 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    What are you towing specifically
  10. Apr 25, 2021 at 4:28 PM
    Dallas007
    Dave
    2021 Tundra Pro Max
    1,000 pound Polaris ATV. Have a 4,000 mile trip coming up.
  11. Apr 25, 2021 at 4:32 PM
    Pudge
    CT
    Get shackes and life the back end an inch or 2. Trucks should have a rake. I never understood the leveling thing, it may look cool but it screws up the functionality of having a truck.
  12. Apr 25, 2021 at 4:51 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    if the trailer has too much tongue back up the quad just a little until it feels perfect. Too far back and it will be bouncing on the hitchball. But backing it up a few inches will put some weight on the trailer axle
  13. Apr 25, 2021 at 4:59 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    A set of coachbuilder +1 or +2 shackles would help and they’re a nice upgrade over the stock things with rubber bushings. I went +1 to return to dead level with my topper installed. Often wonder if I shouldn’t have gone +2 for a smidge of rake to level out when towing.
    Hbjeff likes this.
  14. Apr 25, 2021 at 6:18 PM
    Dallas007
    Dave
    2021 Tundra Pro Max
    I weighed the tongue and it’s 240 pounds which is pretty close to 10%. Thanks
  15. Apr 25, 2021 at 8:06 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Dang! 2 inches of sag from 240 lbs...that seems a little much. That trailer is so light do a 1 inch shackle lift and be done
  16. Apr 25, 2021 at 9:31 PM
    Maadcaap
    Maadcaap White Tundys
    Rancho Cucamonga, Ca.
    2019 Trd Pro
    275/70/18 KO2
    Airbags and cradles.. tow level and hit some trails after you park the trailer..
    Bigboitundra and Dansly56 like this.
  17. Apr 25, 2021 at 9:42 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Not believing it. 2” measured where?
    JohnLakeman likes this.
  18. Apr 26, 2021 at 4:28 AM
    Dallas007
    Dave
    2021 Tundra Pro Max
    It was 1 1/2 just the trailer but by the time I put more gear in bed I’m assuming I will loose a bit more so rounded up to two. I opened tail gate and measured from edge of tailgate to level concrete garage floor. Then put hitch on ball and lost 1 1/2”.
  19. Apr 26, 2021 at 5:54 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    This. No need for bags or springs.
  20. Apr 26, 2021 at 7:16 AM
    FlightMedicRN
    FlightMedicRN New Member
    2020 Super White Crew Max- TSS SR5
    Interior chrome delete- AJT Designs, S&B Cold air intake, 10" BAMuffler exhaust system, color-keyed bumper covers, LED fog lights, TuffSkins interior inserts, black exhaust tail pipe and tip, Peragon tonneau cover.
    Sumo springs would be a good solution since they only "engage" when you have weight in the back of the truck or on the tongue. When you're driving empty you don't even notice them there (at least I didn't). They are also cost effective and you can install them yourself in about 20 min....
  21. Apr 26, 2021 at 7:31 AM
    Dallas007
    Dave
    2021 Tundra Pro Max
    I sincerely appreciate all the responses and you have provided me with solid information on how to address this.
    Thanks very much!
    Dave
  22. Apr 26, 2021 at 7:33 AM
    15whtrd
    15whtrd Mr. Blonde
    H
    I’ve discussed this with another member but it’s been a long time. It seems as though you can go with Timbrens (similar idea to sumo‘s.) and their cradles, and use a Superbump (aftermarket bumpstop) in the Timbrens place when you’re not hauling anything. Under the assumption that the single set screw that holds the Timbren in place is the same size as the Superbump. This way your travel isn’t limited when unloaded and wanting to off-road, keeping the articulation.
    TunBrun likes this.
  23. Apr 26, 2021 at 10:42 PM
    Dansly56
    Dansly56 New Member
    daniel
    I pull a 5000lb travel trailer and with the trd sway bar, timbrens and WDH I’m good to go
    Dallas007[OP] and 15whtrd like this.
