What's this button for?
Discussion in 'Towing & Hauling' started by MXPCUS, Apr 25, 2021.
  1. Apr 25, 2021 at 1:12 PM
    MXPCUS
    MXPCUS [OP] New Member
    Ken
    Southern IL
    2007 Tundra SR5
    Push bar and bed rails
    Haven't needed to tow anything yet, so I'm not sure what this button does
    bleach likes this.
  2. Apr 25, 2021 at 1:17 PM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Just by looking at the picture I think it sets your tire pressure at a certain PSI. I could be completely wrong.
  3. Apr 25, 2021 at 1:17 PM
    18" TRD Off Road Wheels
  4. Apr 25, 2021 at 1:19 PM
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    That resets your tpms. Right now it's set for factory specs but if you wanted to increase or decrease the air pressure in your tires you would use that button to reset the tpms monitor system. Basically the light on the dash will warn you if your tire pressure is a certain % below what it is set at . If your tpms is set for 35psi then when It goes below that by a certain amount the light comes on. If you want to run your tires at a different psi fill the tires to your desired psi then hit the reset button and now your tpms light will come on if your psi goes below a certain % of the psi you out your tires at. Hope that makes sense.
    p1ayn likes this.
  5. Apr 25, 2021 at 1:20 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    That is to reset and reprogram the TPMS in the tires. If you rotate tires, air up tires etc..... It is a good idea to reset and let the vehicle relearn the sensors and their positions on the truck.
    p1ayn likes this.
  6. Apr 25, 2021 at 1:24 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Mine didn't do squat when I changed to different tires with new TPMS. I followed the instructions exactly as written in the manual.
    MXPCUS[OP] likes this.
  7. Apr 25, 2021 at 3:04 PM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Same as on my '09 Highlander, trying to get the TPMS light on the dash to go out.
    I haven't even looked for it on my '07 Tundra since the light is not on.
    Nope, not gonna mess with it!
    SPP
