Issues with new carrier bearing
Discussion in '1st Gen Tundras (2000-2006)' started by 01tunder, Apr 22, 2021.
  1. Apr 22, 2021 at 2:16 PM
    01tunder
    01tunder [OP] New Member
    Ca
    2010 4x4 trd tundra
    hey guys. So I have a 2001 tundra sr5 Rwd. The carrier bearing is super torn. I took off the drive shaft and got a new bearing. I put in the new bearing andnI noticed its kind of hard to spin. When I put the nut in the bearing does not spin at all even if I try super hard.. Is this normal? I seen a couple of YouTube videos where the bearing is somewhat able to spin.
    I got the part from orielly's. It's a precision brand.
  2. Apr 22, 2021 at 2:30 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Toyota (made by Spicer) is the way to go.
    Not familiar with Precision, but have seen some aftermarkets sold and used by others that are inferior with hollow rubber and poorly made.
    Do a search here for the Spicer Carrier Bearing Thread for your truck.
    Glock 40 likes this.
  3. Apr 22, 2021 at 2:32 PM
    01tunder
    Ca
    2010 4x4 trd tundra
    OK. Is it normal for it to be that hard to spin? Or not spin at all?
  4. Apr 22, 2021 at 2:34 PM
    Fred
    Hand Protectors
    Never tried to spin mine after putting it on. I put it on about 2 years ago and she has been holding nicely. Used the high dolla Toyota one but should have gone direct with Spicer.
    Did you torque everything properly?
  5. Apr 22, 2021 at 2:36 PM
    01tunder
    Ca
    2010 4x4 trd tundra
    Yes 100lbs for it. I'll put the driveshaft on and see what happens
  6. Apr 22, 2021 at 5:01 PM
    01tunder
    Ca
    2010 4x4 trd tundra
    Ok got the spicer bearing. Spins perfect.. Now I'm having trouble with the u joint. The plastic parts the cap broke off. I got a universal one from orielly doesn't seem to fit :(.
  7. Apr 22, 2021 at 5:36 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    buy good parts, not universal. Cost a little more but worth it in fit and function....and you won't have to do the job twice.
  8. Apr 22, 2021 at 5:59 PM
    terrward
    terrward New Member
    2004 DC SR5
    Stop buying junk parts from oreilly’s
  9. Apr 22, 2021 at 6:52 PM
    01tunder
    Ca
    2010 4x4 trd tundra
    Yes your right. Don't buy orielly parts. Get spicer
  10. Apr 23, 2021 at 4:23 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
  11. Apr 23, 2021 at 9:49 AM
    01tunder
    Ca
    2010 4x4 trd tundra
  12. Apr 23, 2021 at 10:06 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    No-no-no no'Reillys! Shoddy parts.
    bmf4069 likes this.
  13. Apr 23, 2021 at 10:31 AM
    Fred
    Hand Protectors
  14. Apr 23, 2021 at 9:19 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I used a Timken CB and it’s working great and was a 3rd the price of Toyota. I normally use all Toyota parts, but some things that are easy to swap when they fail I’ll look elsewhere. $200 was a little pricey for me.
  15. Apr 24, 2021 at 11:10 PM
    01tunder
    Ca
    2010 4x4 trd tundra
    Now I noticed there is a small oil leak coming from the Area where I took the drive shaft out the part that goes into the transmission. I guess it's called a dust cap that goes over by the yoke
  16. Apr 24, 2021 at 11:23 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Transmission output shaft seal.
    Is it residual from the removal or is it now a steady leak that shows after cleaning up?
    15whtrd likes this.
