which coilover
Discussion in 'Suspension' started by cain0725, Apr 24, 2021.
  1. Apr 24, 2021 at 7:18 AM
    cain0725
    cain0725 [OP] New Member
    can u adjust the height with out pulling the strut and shock back out ect?
  2. Apr 24, 2021 at 7:27 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    depends on the lifted coil over. Some require removal to adjust the clip height, other can be adjusted on the truck.
    Which coil over are you talking about?
  3. Apr 24, 2021 at 8:05 AM
    cain0725
    im asking which ones u can adjust on the vehicle
  4. Apr 24, 2021 at 8:09 AM
    frichco228
    Frank
    Virginia
    The ones that have threads and collars that adjust the height. Toytec boss system is a good example of that type.
    Coilovers like 5100s or 6112s use seat clips that have 3 different height adjustments, need to remove them to adjust the clips.
    You can see the threads and adjustment collars in the pic
  5. Apr 24, 2021 at 8:11 AM
    cain0725
    is there much difference in ride quality on road vs the bilstein 6112 and others
  6. Apr 24, 2021 at 8:12 AM
    cain0725
    thanks u seen to have a ton of knowledge, and i want ti buy once and not regret
  7. Apr 24, 2021 at 8:30 AM
    frichco228
    Frank
    Virginia
    I suggest you look over the suspension forum here, there is a ton of good info and reviews on the different coilovers. What you seek has been discussed and posted often.
  8. Apr 24, 2021 at 10:37 AM
    cain0725
    i have, too many decisions and options, thanks
  9. Apr 24, 2021 at 10:41 AM
    Plan on waiting 6 months for them as well....FYI.
    JimboSlice413 likes this.
  10. Apr 24, 2021 at 11:43 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    That's about the lead time I was quoted. I'm about 2 months in lol. Sucks
  11. Apr 24, 2021 at 12:09 PM
    Elduder
    Elduder New Member
    Anything with a c-clamp style ring, with the hex screw in it should be compressed before adjusting.
    Toytecs, Fox are this style.
    You don’t have to do it, but the concern is it will skip a thread while under tension as the ring is not full captive on the body threads.
    Solid rings like Ironman and Eibach are fine to adjust without compressing the spring.
    Of course you can still adjust them even if they have a set screw, but there’s a small risk and since Fox warns against this it’s unlikely they will warranty any damage as a result.
  12. Apr 24, 2021 at 1:36 PM
    Mr_Kane
    Mr_Kane New Member
    2019 TSS Crewmax
    :Eibach 2.5" Lift :SPC UCA's :34" Toyo AT3's :10" BA Muffler
