Air compressor install location on First Gen?
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Nov 9, 2020.
  1. Apr 24, 2021 at 7:34 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Frenchy did you pull time out of your ass? I would like you to make three pretty pleaseee. I have a dual that's been sitting.
    If not, do you think @papasmurf could duplicate yours, @Sunnier?
    Voss[OP] and Darkness like this.
  2. Apr 24, 2021 at 8:25 AM
    No time was acquired out of my rectum as of yet. I’ll probably get one going sometime soon. When was the last time you lifted/felt your dual ARB? I forgot how much of a boat anchor those things are!!!! Specs say 18lbs but it feels like 25!
    I’ll let you know if I come up with something
    bmf4069, Voss[OP], Darkness and 2 others like this.
  3. Apr 24, 2021 at 8:39 AM
    des2mtn
    SW
    Tonto cover
    Thank you, I appreciate it.
    For funsies, I just went and weighed myself twice, one time holding it. 17.1lb difference.
  4. Apr 24, 2021 at 8:51 AM
    Do you already have a switch management system or how do you plan to control your comp? That’s like the last piece of my puzzle; but I’m dreading dropping 500+ for a switch system. I built my own for the 4runner, but the truck doesn’t have a lot of useable switch locations. If I do a management system I’ve eyeballed making a bracket for under the ignition or possible sunglasses holder area, I’ve got to squeeze out a lot more time before that happens!
  5. Apr 24, 2021 at 10:17 AM
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    Mine came with a switch and I put it under the ignition area. Plenty of room behind it for wiring.
  6. Apr 24, 2021 at 10:36 AM
    That’s the area I plan to build a switch panel mount for.
    Voss[QUOTED][OP] likes this.
  7. Apr 24, 2021 at 11:22 AM
    des2mtn
    SW
    Tonto cover
    Uh, I tend to mickey mouse this sort of stuff. I'm not going to spend big bucks on a switch management system either. As long as it works? :annoyed:
    This is how my ditch lights are wired currently. I'll realistically be adding four more switches down the line. I might utilize @Voss' location too.
  8. Apr 26, 2021 at 3:05 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    I don't but, if @Sunnier comes by I can take measurements and recreate them. PM me and we can discuss
    bmf4069, Voss[QUOTED][OP] and Sunnier like this.
