  1. Apr 23, 2021 at 3:54 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Maybe. I'll have to go test it out.
  2. Apr 23, 2021 at 4:04 PM
    The front windows have no tint. The rear windows have factory tint which is part of the glass, you cannot remove it. You can tint over it if you want it darker.
    No such thing as a stupid question. ;)
    Sean492, Wallygator and GoSox[QUOTED] like this.
  3. Apr 23, 2021 at 4:12 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I’m doing the same thing I did with my 4runner pro. Just matching my tint on the front door windows with the rear. It’s looks good.
  4. Apr 23, 2021 at 4:17 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    The rear factory tint doesn’t offer any UV protection as far as I can tell. I plan to have a clear film with UV protection installed to help with heat gain and protect the interior.
    Wallygator and GoSox like this.
  5. Apr 23, 2021 at 4:28 PM
    Rely01
    Rely01 Window Shopping
    Eli
    SW Arkansas
    2016 Silver Sky SR5 CM
    It says they fit.. worth a shot?
    KWC[QUOTED] and Fotnot like this.
  6. Apr 23, 2021 at 4:58 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    I'll say if you truly want sliders then no. If you want a step that looks like a slider than your call to go for it or not. These aren't a true slider like sdhq, wkor, demello, ect..... You will also notice a bigger price difference on a true slider. All the sliders I researched were around a grand and up. For example you wouldn't want to jack your truck up by the smittybuilt, you probably couldn't expect to bang them off rocks without a good chance of them bending. Not my personal experience on the smittybuilt, just what I've heard. Seeing the price difference too I'm guessing that's why, they're not built the same to take the abuse a true slider will. Good luck.
  7. Apr 23, 2021 at 5:08 PM
    18" TRD Off Road Wheels
    ^^^ This.
    There is a reason people go with the ones that cost more. RCI for example, does this with their bolt on sliders to demonstrate their durability.
  8. Apr 23, 2021 at 5:50 PM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    2021 SR5 Tundra Crewmax 4x4
    Bakflip G2 Tonneau Cover
    Installed my mat holders on the passenger mat, next up is two in the rear mat to keep my kids from sliding it around.
    Also printed Grogu to ride on the dash... Printed him out of color changing filament, green when cold and yellow when hot....
  9. Apr 23, 2021 at 6:00 PM
    Dan_Gleesac14
    Dan_Gleesac14 New Member
    2023 Tundra SR5;2018 Tundra Platinum (SOLD)
    thanks! Will try it this weekend and report back
  10. Apr 23, 2021 at 6:14 PM
    Gabrielo93
    Gabrielo93 New Member
    Gabriel
    Grand Prairie, TX
    2015 Black Toyota Tundra SR DC
    12 Volt Remote Starter Lockerdown Safe ICS Fab Dash Mount Husky All Weather Beaters Mats Rear Folding Seat Mod Linex Platinum Kicker Sub/Amp Combo CoverCraft Dash Cover Kenwood Headunit Cravenspeed Untenna CupHolderHero Aukee Tailgate Inserts OEM Deck Rails Rolling tonneau cover CravenSpeed Untenna
    Got a full size spare to match the other wheels.
    dpast88, 3xYOTA, Wallygator and 9 others like this.
  11. Apr 23, 2021 at 6:15 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    They work great, I have 20" wheels with -24 offset on 35s with no more rub.
  12. Apr 23, 2021 at 6:52 PM
    Rely01
    Eli
    SW Arkansas
    Thanks for the input. I don't do any kind of rock crawling, much less come across many here in South Arkansas. I'm more looking for something that will give more protection that a nerf bar, but keep the wallet from stretching thin on something I wouldn't use to the fullest. I'll keep looking around and keep posted. Thanks again!
  13. Apr 23, 2021 at 6:55 PM
    BrianH4x4
    BrianH4x4 New Member
    Shelby, North Carolina
    2015 silver sky metallic
    USB plug added for backseat 6 circuit fuse holder added Amp power steps Bed lights Bumper led ( anytime) lights Amp reasearch bed step Focal three way components up front Focal 165 in rear Jl xd200 amp for front stage Jl xd 300 amp for 10 W3 -D4 sub Maestro rr for steering wheel control
    I just had my front windows matched to the tinted rear windows. Also had the sunroof tinted to help with heat build up while parked.
    AggiePhil likes this.
  14. Apr 23, 2021 at 6:57 PM
    BrianH4x4
    Added some AVS vent visors today. I had these on my Tacoma and had to have them on the Tundra.
    Wallygator, NAFlash, GAknight and 5 others like this.
  15. Apr 23, 2021 at 7:00 PM
    Rely01
    Eli
    SW Arkansas
    @AzureNightmare @mgm16trdpro probably should have read the Q&A earlier. This isn't exactly what I was wanting. Thanks for the heads up.
  16. Apr 23, 2021 at 7:00 PM
    Nighthawk
    Nighthawk New Member
    Keith
    Frederick Md.
    2018 Tundra Limited crewmax
    linex bed Truxedo Pro F-15 Tonneau,Weathertech mats,TRD exhaust,Matt Geckco bed lights,hood light,shorty antenna, all LED lights inside, Fomoto oil drain valve,
    I changed front,rear & transfer case fluid. Not too bad of job.
    Wallygator, Jpd0144 and Fotnot like this.
  17. Apr 23, 2021 at 7:05 PM
    BrianH4x4
    I believe it was 35%. Legal here in North Carolina. Thanks!
  18. Apr 23, 2021 at 7:47 PM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Changed the oil for the first time with
    mobile-1 0w/20 and a Toyota filter. What a pain in the a$$ compared to my Tacoma and land cruiser!
    got a delivery for my weathertech mats. I have had these in every truck I’ve owned. Well worth the price and easily one of the best mods you can do IMHO.
    Wallygator, Ostrich, RRR1C0 and 6 others like this.
  19. Apr 23, 2021 at 8:14 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Any issues with the keyfob? I'd be interested in getting one of these too.
    TunBrun[QUOTED] likes this.
  20. Apr 23, 2021 at 9:38 PM
    mgm16trdpro
    Northern NJ
    You're welcome, if you're looking for more protection than a nerf bar than your best bet is a slider. If you want no drilling to frame than sdhq or p&p sliders are the only 2 I know of that can be bolted to frame without drilling. If I was you I'd try to find a slider that someone is selling secondhand. That way it saves you some coin but you're still getting the protection you desire. If you only want new and don't plan to beat them really, more protection from debris kicking up on your sides like the Go Rino RB20 side steps look good and will keep the small stuff from kicking up on your sides. Again no experience with, but plenty guys on the forum have them and I've only heard pretty much good things. Something like that, Tyger, or the smittybuilts you mentioned will give you some protection but again, no jacking up on them and take it easy like you said. If you want more protection than a nerf bar/side step than you're looking at a slider and it's gonna hurt the wallet,unless you can find secondhand or a shop local to you that can fab up a custom set kindly to your wallet. Good luck.
  21. Apr 23, 2021 at 10:03 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    1A52C5BE-7F67-4EC8-8BE9-3BCC97BC47A0.jpg 5DCD14F0-34CA-47AD-B5C0-1590BC5E1FE9.jpg F84BDA85-FA79-44F6-94F7-CCFE4F3262E3.jpg CBI covert, warn 12k and factor 55 ultra hook
  22. Apr 23, 2021 at 10:12 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Oh fuck!
    Hightide likes this.
  23. Apr 23, 2021 at 10:13 PM
    RainMan_PNW
    Casey
    Clark County, WA
    What’s your all-in cost on that setup, and how do you get to the clutch?
    3xYOTA and Ltaco17[QUOTED] like this.
  24. Apr 23, 2021 at 10:16 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    I can vouch for the Go Rhino RB20 as being a legit product. Mine took a nasty hit and didn't budge. The finish came off a little but nothing linex won't fix down the road.
  25. Apr 23, 2021 at 10:17 PM
    RCI Offroad are also no drill sliders. The have optional drill points, but the forklift photo was just the bolt on application, IIRC.
  26. Apr 23, 2021 at 10:18 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    Clutch can be reached through the grill cover. Winch and all about $1700
  27. Apr 23, 2021 at 10:19 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Bumper too, or bumper separate?
  28. Apr 23, 2021 at 10:20 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    Yes everything
    Hightide and RainMan_PNW[QUOTED] like this.
  29. Apr 23, 2021 at 10:22 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    What’s wrong with it?
  30. Apr 23, 2021 at 10:22 PM
    RainMan_PNW
    Casey
    Clark County, WA
    :monocle: :smokertransformer:
