1st Gen Door speaker upgrade? Whatcha got?
Discussion in 'Audio & Video' started by Jerry311SD, Mar 28, 2019.
  1. Mar 28, 2019 at 11:25 AM
    Jerry311SD
    Jerry311SD [OP] New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Now that I went crazy with the sound proofing it's time to upgrade the speakers.
    I'm going to use the stock stereo and all of that. I have a 10" Sub setup.
    I'm looking at replacing the 6.5's in the front and rear doors.
    So what did you guys use (speakers) and how do you like them?
  2. Mar 28, 2019 at 11:59 AM
    I updated mine to JVC through Crutchfield. I'm of the belief that most of the manufacturers put out similar quality unless you're willing to spend a lot more.
    Or more simply put, of the ones in the same price range you are not going to notice a huge difference from one brand to another. I've been happy with my JVC stereo and speakers but I definitely need a sub.
    Darkness and Jerry311SD[OP] like this.
  3. Mar 28, 2019 at 12:12 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  4. Mar 28, 2019 at 12:20 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    I have diamond audio in front and rear
    Jerry311SD[OP] likes this.
  5. Mar 28, 2019 at 12:40 PM
    Casper421
    In the woods
    06 DC
    Do you have the jbl system?
  6. Mar 28, 2019 at 12:43 PM
    Also, this is one of those times I would recommend Crutchfield over Amazon. Their expertise and customer service is really 2nd to none.
  7. Mar 28, 2019 at 12:58 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Yes
  8. Mar 28, 2019 at 1:16 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
  9. Mar 28, 2019 at 2:14 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Crutchfield is top notch. I won't buy head units anywhere else, only bought the speakers through Amazon because I had a gift card.
    Next up is Clarion compact amp.
  10. Mar 28, 2019 at 2:22 PM
    Casper421
    In the woods
    06 DC
  11. Mar 28, 2019 at 5:25 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I put Infinity Reference in all 4 doors in 2008. Powered by the Alpine head unit, they're pretty nice.
  12. Apr 1, 2019 at 5:00 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Ga
    Give these a try and let us know. They’re 2 ohm 7”, almost a perfect fit (need to create new screw hole). Crutchfield sells them for $50.
    Lupe, speedtre and Jerry311SD[OP] like this.
  13. Apr 1, 2019 at 8:30 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    I did the kicker CS series speakers. I got the 6 3/4 in all 4 doors and they were a perfect fit with the factory housings. Best buy had the best price at the time. $39.99 for 2 speakers. (I have a 2000 Access Cab) I just used the supplied mounting screws. I paired this with a nice sony headunit that gave a little more power than the other headunits I was comparing. I did not however replace my tweeters, I need to do that! They don't have much bass, which is to be expected. You'll be fine with the 10" sub. I have a 12 rockford fosgate punch w/ kenwood amp. amp is set at half power and it's perfect for my needs.
    Toyotundra06 and Jerry311SD[OP] like this.
  14. Apr 1, 2019 at 9:33 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I used Kicker CS series speakers in my 2017 Tacoma with the stock HU and it improved the sound IMMENSELY, so I second the Kicker recommendations.
  15. Apr 1, 2019 at 9:59 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    39$ Isnt to bad.
  16. Apr 1, 2019 at 11:34 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Agreed. Normally I stay away from Best Buy, but the guys that I talked with were cool. They even let me open the box of speakers to verify the mounting holes lined up to my factory mounts (I took one completely out of the truck and brought it into best buy with me) So for $80ish you'll have 4 new speakers that in my opinion are great for what you are paying.
    Hope this helps!
  17. Apr 7, 2019 at 7:34 PM
    Shellback
    Shellback New Member
    Pink/Silver 2001 Tundra TRD
    Peeling door window trim.
    When installing 2 way 6.5's in the front door, do you just replace the original factory 6.5's? What about the tweeters on the upper door? Leave them alone? I purchased a pair of Rockford Fosgate as recommended by Crutchfield, but I had to use a gift card on Amazon, therefore, no installation instructions you normally get with Crutchfield.
  18. Apr 23, 2021 at 8:30 AM
    probiz
    probiz New Member
    2006 Tundra 4x4 DC Limited
    I'd like to revive this post.
    I've got a blown stock JBL speaker in my '06 Tundra Limited DC so I am ready to replace my front and rear speakers. Having just spent $130 on a GTA Car Kits Bluetooth adapter, I will be keeping my stock nav/head unit. I've seen the adapter plates on Amazon that will allow for new speakers to be mounted up front, however they do not have a mounting location for another tweeter/mid to replace the stock one. I don't know if that'll cause problems with the stock amp (if I even have one).
    Can someone please recommend a path forward that would be a straightforward replacement of the stock speakers?
  19. Apr 23, 2021 at 8:41 AM
    speedtre
    speedtre New Member
    Inland Northwest
    You have a JBL amp for sure (99%)...so if you replace the speakers you will need to use 2 Ohm speakers...which are rare.
    Most likely, your speakers aren't blown (very rare) what you have is deteriorating foam surrounds on one or both front speakers. They can be reparied with a $35 kit. I did this on my 2005 DC and it worked a charm. I will be doing it on my 2006 DC probably this weekend. This is the easiest way to fix your issue if you like the stock sound before the foam deteriorated.
    https://www.simplyspeakers.com/toyota-jbl-speaker-foam-edge-repair-kit-fsk-7m-complete.html
    abcinv likes this.
  20. Apr 23, 2021 at 9:56 AM
    probiz
    probiz New Member
    So could I replace the amp in order to give myself more speaker options? I really think I'd rather just get new speakers than try to revive the old ones.
  21. Apr 23, 2021 at 9:59 AM
    speedtre
    speedtre New Member
    Inland Northwest
    You can bypass the amp (and use new speakers of your choice), replace the amp (and use new speakers of your choice) or keep it and use new 2 Ohm speakers or repair the current speakers and leave everything else as is.
    Crutchfield is your best place for advice for any option besides repairing the current speakers.
  22. Apr 23, 2021 at 6:07 PM
    abcinv
    Tommy
    NW Ga
  23. Apr 24, 2021 at 10:38 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
  24. Jun 18, 2021 at 1:13 PM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    Just curious, how do you like the GTA Bluetooth adapter so far? I just ordered one after reading several good reviews. Should be here next week.
