33's with 4.56 or 4.88
Discussion in '1st Gen Tundras (2000-2006)' started by TundraMiddleGA, Apr 21, 2021.
  1. Apr 21, 2021 at 9:59 PM
    TundraMiddleGA
    TundraMiddleGA [OP] New Member
    01 Tundra
    33's, cheap coil overs, cut bumper
    01 Tundra on 33's looking to gear down to 4.56 or 4.88 for towing. Anyone run either combo and what are your rpm's like at highway speeds?
  2. Apr 22, 2021 at 7:42 AM
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    @Darkness has 4:56 with 33s hopefully he will chime in
    I would say go with 4:56 for 33s. 4:88s will make your rpms a bit high at crusing speeds i would think.
    Darkness likes this.
  3. Apr 22, 2021 at 7:49 AM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    Can someone educate me on what ratio stock gears are, and how hard it is to change gears?
  4. Apr 22, 2021 at 7:52 AM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    You’ll want to get gears done. They are very difficult to do at home and get correct. I believe stock ratios are 3:91 or 4:11.
    @Tundra2 @Professional Hand Model
  5. Apr 22, 2021 at 8:16 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Stock gears are 3.91. I regeared to 4.56 for my 33s and it’s a bit higher than stock. You run out of RPM pretty quick with OD off. At 60mph with OD off I’m at 3000rpms.
  6. Apr 22, 2021 at 8:20 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    There are a lot of gear ratios from the factory. You can look up your vin and find out what it cane with.
    4.56 and 33s is not necessary but it did bring back acceleration and power. RPM with this combo will be slightly higher than stock but it doesn't hurt your fuel economy. If anything I found better fuel economy with this combo than with stock gears (3.91 in my case) and 33s.
    I would never advise to change gear ratio to save fuel, it is a lot of money to spend when driving style is the biggest influence on fuel economy by far. That said, don't believe the old notion that higher rpm (within reason) equals less miles per gallon. On old carburetor motors that math is true but on more modern fuel injection vehicles with good ECU programming that isn't the case. Lightening the load on the motor let's them run more efficiently (to a point, this doesn't mean 5.29 gears and 3k rpm will get you 30mpg). You can get close to stock mpg by lowering the strain.
    As far as RPM at highway speed, at 70mph I am somewhere around 2300. This can actually be in your favor if you have aftermarket exhaust as the drone zone is between 1900 and 2200 rpm, an unintended benefit.
  7. Apr 22, 2021 at 12:35 PM
    TundraMiddleGA
    01 Tundra
    Thank you for the replies. Probably will go with the 4.56. I threw 4.88's in a old jeep on 33's and it was a beast till 70 mph then it was screaming. Looking to do the same with the Tundra but not have the rpm's at 3,000 at 70 lol
    Voss and Professional Hand Model like this.
  8. Apr 22, 2021 at 7:36 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    If you plan to be near the limit of your towing capacity (or tow very often), stepping up to 4.88's may be worth it. Especially if you are at higher elevations.
    IIRC another member here did as he towed a lot and was happy with it.
    Otherwise 4.56's.
    With 285/75r16 (33")
    4.56 65mph = 2225 rpm
    4.56 70mph = 2400 rpm
    4.88 65mph = 2375 rpm
    4.88 70mph = 2550 rpm
  9. Apr 22, 2021 at 7:42 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    How much you planning on towing? I’m on 33’s with stock 3.91’s and CAT scaled my little tent trailer and bed full of gear and GCW was little under 10k. 75mph all day long and still got 11-13mpg. But I have the VVT.
    If I was towing a big travel trailer maybe I’d consider regearing. But if I’m going to regear, I’m moving up to 35’s and 4.88’s
  10. Apr 23, 2021 at 5:35 PM
    TundraMiddleGA
    01 Tundra
    I have a big enclosed trailer I pull for lawn care during the week when I'm off and a 16' car trailer I use often. Last time I pulled it down to Florida I was searching for gears with OD off doing 65 the whole way and no one wants someone on the highway doing 55
