Metal clicking sound when turning
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Apr 22, 2021.
  1. Apr 22, 2021 at 5:04 PM
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    On this weeks episode of “What’s that Noise?”... when I turn my steering wheel, it sounds like metal washers falling on each other. I changed the steering rack bushing over the weekend, double checked everything and it’s all tight.
    The sound seems like it’s coming from inside the steering wheel.
    Any ideas of what it could be? I don’t have any issues turning, just this metal clicking sound that started yesterday.
    Appreciate you all!
  2. Apr 22, 2021 at 11:59 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Clicking while turning usually means CV axle.
  3. Apr 23, 2021 at 5:00 AM
    Here's what's behind your air bag:
    I don't think anything back there would be making noise. How does the steering feel? Any work done recently?
  4. Apr 23, 2021 at 6:40 AM
    Voss
    Valod
    2003 AC TRD 4x4
    I should clarify, it’s just 1 click. Turn left, sounds like a washer hitting another. Straighten the wheel and get 1 more click.
    Steering is tight. Did replace the steering rack bushing over weekend.
  5. Apr 23, 2021 at 6:41 AM
    Does it seem like this noise is inside the cab, or outside?
    Voss[OP] likes this.
  6. Apr 23, 2021 at 6:47 AM
    Sounds like you have a screw loose. Not you personally....
  7. Apr 23, 2021 at 6:48 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Inside and coming from the behind the steering wheel/dash area. I thought it might be the key in the ignition for a moment but couldn’t replicate the sound by moving the key.
  8. Apr 23, 2021 at 6:49 AM
    Something hanging down and contacting the steering shaft when it's turning?
  9. Apr 23, 2021 at 6:53 AM
    Voss
    Valod
    2003 AC TRD 4x4
    I’ll open up the portion behind the steering wheel this weekend to see if I pin point where the click comes from.
  10. Apr 23, 2021 at 7:28 AM
    I'm wondering if maybe that steering boot thing that was a hot topic a few months back isn't torn and letting a new noise in since your bushing replacement. Like the bushings took the slop out and now your rack is making noise and coming inside.
    Darkness and Voss[OP] like this.
  11. Apr 23, 2021 at 7:42 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Steering rack boots? Those are in good shape.
    Seems like you are referring to something else tho?...
  12. Apr 23, 2021 at 9:12 AM
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
  13. Apr 23, 2021 at 9:34 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Wes_heppy[QUOTED] likes this.
  14. Apr 23, 2021 at 11:43 AM
  15. Apr 23, 2021 at 4:12 PM
    Voss
    Valod
    2003 AC TRD 4x4
    This can’t be normal...
    SouthPaw and Darkness like this.
  16. Apr 23, 2021 at 4:19 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Found the source. This piece is loose. Not sure about where it goes but guessing it shouldn’t just be dangling on the steering shaft...
    Anyone know what the part is or how I can go about learning how to fix it?
    des2mtn likes this.
  17. Apr 23, 2021 at 4:34 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    dude
    you need a whole new steering column.. someone threw a different column in and cut the key shit off and band clamped the old one on.. WTF
  18. Apr 23, 2021 at 4:47 PM
    Voss
    Valod
    2003 AC TRD 4x4
    That sounds like a fun and inexpensive project...
    They also tried to weld?... or possibly soldered it?...
  19. Apr 23, 2021 at 4:51 PM
    empty_lord
    05 rollover special
    yea.. time to go to a junkyard for a whole column THAT HAS ITS KEY. swap the key cylinders and be back in business with a not jury rigged setup
  20. Apr 23, 2021 at 4:55 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Thanks bud
  21. Apr 23, 2021 at 4:56 PM
  22. Apr 23, 2021 at 4:57 PM
    Voss, are you in the South? Round here we'd say someone Bubba'd that.
    No offense @BubbaW :D
  23. Apr 23, 2021 at 5:00 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Lol. No bud out west where we stick to Mickey Mouse job
    des2mtn, Jack McCarthy and Darkness like this.
  24. Apr 23, 2021 at 5:12 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    That's way worse than a Bubba'd
  25. Apr 23, 2021 at 5:18 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Called a couple junkyards and one of them told me he has the ignition portion with the Key which I can use with the existing steering shaft. As in take off the “bubba’d”(no offense my dude lol) ignition portion from the steering shaft and put on the one they have.
    Does that sound right?
    BubbaW likes this.
  26. Apr 23, 2021 at 5:19 PM
    empty_lord
    05 rollover special
    You can but you have to drill out the old one time use bolts either way, the column is being removed. I would replace the whole thing honestly out of fear there’s an different issue that caused this fuckery in the first place
    Voss[QUOTED][OP] likes this.
  27. Apr 23, 2021 at 5:27 PM
    Voss
    Valod
    2003 AC TRD 4x4
    I’ll see if I can find one. Thanks
  28. Apr 23, 2021 at 5:28 PM
    And he makes the backhanded assist....:D
  29. Apr 23, 2021 at 7:24 PM
    OK, now I'm just wondering how this is just now coming up.
  30. Apr 23, 2021 at 7:37 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    How long have you owned tis truck? To the right of those "welds" it looks like stress cracks on that crossmember not sure what that piece is called.
