RAS with Bilstein 5100's - What setting for a level stance
Discussion in 'Suspension' started by jamlewis, Apr 23, 2021.
  1. Apr 23, 2021 at 7:59 AM
    jamlewis
    jamlewis [OP] New Member
    RAS
    On Monday I am getting a TRD Sway bar and 5100's on all 4 corners of my 2014 Tundra CM 2WD running Michelin Defender 285/60R20. I installed RAS on the black disc a few years back, and it seems like it rode a little higher in the back afterwards. Has anyone had any experience installing the 5100's and has the RAS installed as well? I am wondering what setting you put the 5100's at to achieve a level stance? I would like to dramatically reduce the rear to front rake, but don't want to go nose high. Thanks!
  2. Apr 23, 2021 at 8:21 AM
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    Middle leveled out mine perfectly...
  3. Apr 23, 2021 at 8:44 AM
    Blueknights75
    Ron
    Clayton, NC
    Top setting leveled mine perfectly with 0 rake. Nothing done to the rear except a set of 5100s.
  4. Apr 23, 2021 at 8:49 AM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    I think the popular choice is middle setting... almost level better ride quality.
    BravoDeltaRomeo likes this.
