AGM Batteries in ur Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by wandering_boy, Apr 20, 2021.
  1. Apr 22, 2021 at 7:37 PM
    #61
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Google doesn’t lie...
    NewImprovedRon likes this.
  2. Apr 22, 2021 at 7:50 PM
    #62
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    I run Optima in my work truck and personal. Does just fine. Red top in personal truck and yellow top in the work rig.
    Chose yellow top for work because I run a 2300 constant watt modified sine wave inverter to power electrical testing equipment with my truck idling for hours. At higher loads a standard lead acid battery would quit after a couple hours. Even when adjusting idle up. Had it for about 4 years no problems. Can even tell the difference just by how fast the engine turns over on first crank vs coworkers trucks that run lead acid.
    Red top for personal truck because, well, why not? I got it for free. Hahaha. It's been in service about 3 years with no complaints. Cranks up every time even when I haven't driven it for a week or two. If I didn't get Optimas for free every now and then, or if my work didn't pay for them I wouldn't be able to justify the price.
    Replace a lead acid battery at least every 5 years and they work just fine for most applications. Choose maintenance free batteries when you can. Or if you have regular vented lead acid just check fluid levels and top off with DISTILLED WATER ONLY. And don't overfill. Leave about 1/4 - 3/8 below the cap neck to prevent boiling over of the electrolyte.
  3. Apr 22, 2021 at 8:11 PM
    #63
    wandering_boy
    wandering_boy [OP] Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    I picked up the red top today and put it in the Tundy. I had to take the cover plate and put it under so the battery was tall enough to be held down properly but its not sketchy. It says you can use the cover plate underneath on the thing. The truck cranked right up and voltage was holding steady. I let it idle it until it warmed up all the way and watched the volt meter the whole time but I do have a digital voltmeter coming that can handle 2 loads (heard ur wife can also handle 2 loads). I will see how it does this weekend when I drive to and from my MTB race and I'll be keeping an eye on that meter.
  4. Apr 22, 2021 at 8:15 PM
    #64
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Disconnect the posts while it sits?
  5. Apr 22, 2021 at 8:23 PM
    #65
    No sir. I'm too lazy for that.
  6. Apr 22, 2021 at 8:32 PM
    #66
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Run a bigger AGM and the $5 ford or gm diode to bump voltage above 13.8/13.9v. Probably will last 3 weeks sitting.
  7. Apr 22, 2021 at 8:41 PM
    #67
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I bet it's profitable to tell people to buy agm batteries.
    Leo's first, KNABORES, CodyP and 2 others like this.
  8. Apr 22, 2021 at 8:46 PM
    #68
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I don't think an agm lead acid battery looses power faster than a flooded lead acid battery does it? My truck will set for a week at a time on occasion and it starts with like a beast.
  9. Apr 22, 2021 at 8:48 PM
    #69
    Garand
    Garand New Member
    2024 TRD OR Limited DC
    285/65R20
    This topic has come up often enough that we should start a dedicated section for it.
    https://www.tundras.com/threads/battery-whats-your-best-pick.85682
  10. Apr 22, 2021 at 9:17 PM
    #70
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
  11. Apr 22, 2021 at 11:56 PM
    #71
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I used to work at Napa a long time ago and I purchased an Optima red top for my Jeep Wrangler. Worked fine for first year but one day, I started my Jeep to let it warm up and after 10-15 min, I heard a loud pop. I ran out side and it was still running but smoke was coming out of the hood.
    I popped the hood open and the battery had ‘exploded.’ It was wet every where and the battery was swelling. I shut it off and it wouldn’t restart. I took it out and replaced it with a standard Exide battery. That was years ago and I’ve never wanted to run one since. Not sure what caused the failure but it’s not completely unheard to have them explode.
    Wallygator and RitcheyRch like this.
  12. Apr 23, 2021 at 3:56 AM
    #72
    Wallygator
    At some point Optima started manufacturing their batteries outside of the USA. Heard their quality control took a big hit after that. That would be scary to have a battery explode like that.
  13. Apr 23, 2021 at 4:46 AM
    #73
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    My oem Tundra battery has served me through 8 Saskatchewan and northern Ontario winters and is still working fine. I do plug in the block heater and a battery blanket when it gets cold. Probably get another of the same if a northstar or diehard gold is more expensive.
  14. Apr 23, 2021 at 5:21 AM
    #74
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I've heard good things about these.
  15. Apr 23, 2021 at 5:36 AM
    #75
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    while you're off at college, pickup a noco trickle charger, you can get their cheapest one, but leave your battery plugged in and it'll make sure it doesn't die (safe to leave the battery plugged in for as long as you need)
  16. Apr 23, 2021 at 6:10 AM
    #76
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    Full disclosure...I'm in the battery industry. With that said, I deal with deep cycle, industrial batteries for motive power (lift trucks). For these applications, it most certainly is a true statement. For starting applications, you're correct...not 100% true. You will pay more for AGM, but may not see shorter life. Most flooded starting batteries made today are maintenance free (no need to add water). In fact, many don't even offer removable vent caps. You can also get more CA and CCA with flooded vs. AGM with the comparable battery group size.
    My opinion...If off-roading is your thing, I would probably make the investment in the AGM. For me personally and mostly highway miles, I see no value in the AGM. Being from Minnesota, I also want the highest CCA's available.
  17. Apr 23, 2021 at 6:12 AM
    #77
    Garand
    Garand New Member
    285/65R20
    Nope.
    I checked the voltage when I installed the first one, the truck is putting out between 14.1v and 14.4v so never worried about it.
    Clipped from the Northstar website. (can't find a similar statement with X2 listed)
    Will there be a list of vehicles that we do not want to sell product into because of their alternators?
    No, the number of vehicles and systems that exist today would make it difficult to identify, manage and update a list on a regular basis. So instead we have set charging the charging parameters of between 14.1 volts and 14.8 volts as an acceptable charging range. So long as the battery charging remains within these tolerances the battery will perform to its engineered specifications. It is recommended that for every application the customer test the charging voltage to ensure it is within the acceptable limits.
    onesojourner[QUOTED] likes this.
  18. Apr 23, 2021 at 6:54 AM
    #78
    So an AGM battery might last twice as long(or more), but it's also twice the cost(or more). Seems like a wash. :notsure:
    wandering_boy[OP], CodyP and WILLINH like this.
  19. Apr 23, 2021 at 7:01 AM
    #79
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    It is not a wash if you want to use the battery to power things. If you just need a starting battery maybe it is. Then again if I can replace something every 5 years or every 10 years I would pick the longer service time.
  20. Apr 23, 2021 at 7:24 AM
    #80
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Yup. My honky tonk ain't gonna play itself for 4 hours or more in the backwoods while I'm working. AGM has never failed this task. Great for winching too! AGM is OE in my Jeep.
    Iffn yer just a regular-use street daily driver, don't worry about it... regular battery would be just fine.
  21. Apr 23, 2021 at 8:18 AM
    #81
    Garand
    Garand New Member
    285/65R20
    Or it may not last any longer, but because of the free replacement it might not cost you any more in the long run than an OEM replacement.
    wandering_boy[OP] likes this.
  22. Apr 23, 2021 at 9:47 AM
    #82
    Professional Hand Model
    Fred
    Hand Protectors
    wandering_boy[OP] and des2mtn like this.
  23. Apr 24, 2021 at 6:20 AM
    #83
    Wallygator
    Totally agree. If my application didn't warrant it, no way I would have thrown down so much money for an AGM
  24. Apr 24, 2021 at 11:57 AM
    #84
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    FWIW I've ran AGM's (Odyssey) in my boat to power a 24 volt trolling motor which I often run for hours a day draining them down almost all the way. They handled great, charged right back up to full power rapidly using a standard on-board battery charger. I had a boating accident and had to re-build the entire boat. So I gave those Odyssey's to a friend. When I was done with the re-build I purchased 3 Lifeline AGM's (The smallest ones they make) 1 for starting, and 2 for the 24 volt trolling motor . . . they lasted almost 7 years before they started to discharge quicker, so I swapped them out for 3 more. For this application I can say without a doubt the AGM's perform better and last longer than standard lead-acid where I was only getting 2 1/2 to MAYBE 3 years out of a set. Boat sits for long periods w/o use, and then when I use it, I hammer on the batteries pretty good.
    As far as my truck . . . meh, I did put an AGM in there, only for the reason I was hoping it would last twice as long . . . but after reading all this, I may have made a poor decision . . . oh well, we'll see.
    FrenchToasty and Wallygator like this.
  25. Apr 24, 2021 at 12:32 PM
    #85
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I have a question maybe 'sorta' related to this thread . . . my 06 DC SR5 has the towing package, and on the Toyota Vehicle Specs. / VIN website it lists it as having a 'Heavy Duty Alternator 130 Amp Alternator'. Was there a 'Non-Heavy Duty' version? And will the HD version be any better putting juice back into my AGM , or is it the same voltage going back into the battery regardless of which alternator? Sorry for a dumb question, electrical has never been my strong point.
  26. Apr 24, 2021 at 3:19 PM
    #86
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Whether a 100 or 130 amp, output voltage of alt should be 13.5-14.5 volts
  27. Apr 24, 2021 at 5:44 PM
    #87
    Wallygator
    Just throw the truck on a battery tender once a month and it will be fine
    HBTundra[QUOTED] likes this.
  28. Apr 24, 2021 at 5:49 PM
    #88
    tyler-brown
    tyler-brown New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    HBTundra likes this.
  29. Apr 24, 2021 at 5:56 PM
    #89
    I bet it's profitable to tell people to buy lead acid batteries to power a winch, high end aftermarket lights, and upgraded stereo. No need need to waste your $$$ on a deep cycle AGM. LOL
  30. May 6, 2021 at 10:36 PM
    #90
    wandering_boy
    California
    2005 AC SR5 TRD
    After getting the Optima in I wanted to get a digital voltmeter in to keep an eye on things. I found this thing on Newegg for decently cheap. Install was easy just had to widen out the empty switch there. (at least mine is. My alternate location was going to be where that plastic plate is.) and then cut out the switch mount on the inside. Then the voltmeter just slid in and clamped down with a threaded ring but I added some super glue to the bezel to make sure it wasn't going to go anywhere. And for now It's powered by a connector in thats in there. But I do have plans to run a positive wire straight to the alternator or I might put another one in that alternate spot for the alternator. Otherwise so far so good. It runs at 14.4-14.6 volts. And I'm not sure if this is a bad thing but after a while of driving I notice it drops down to about 13.4-13.6 and then it either stays there for the rest of the drive or sometimes it bumps back up after a while. Either way I'm just super happy with how clean it looks and the green matches pretty well, little bright at night though.
