Techron, Seafoam or...
Discussion in '1st Gen Tundras (2000-2006)' started by alb1k, Apr 21, 2021.
  1. Apr 21, 2021 at 11:32 PM
    alb1k
    alb1k [OP] Always Coming From Take Me Down
    Left Coast
    05 2WD DC w/ attitude
    It's good
    On occasion, I’ve had a check engine come on. A bottle of Techron takes care of it. Seafoam better? I assume it’s ingectors.
    Metro14536 likes this.
  2. Apr 22, 2021 at 12:19 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Have you checked the code?
    Glock 40 likes this.
  3. Apr 22, 2021 at 12:23 AM
    alb1k
    Left Coast
    It's good
    I had it checked a while back. Can’t remember it but may still have it. But it indicated airflow, injectors, something else. I went cheap and replaced the air filter and ran Techron and no problem after some miles. Light came back maybe once a year or two, resolved with more Techron. Now Techron is just part or regular maintenance. No light.
  4. Apr 22, 2021 at 5:06 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    RdKing likes this.
  5. Apr 22, 2021 at 5:10 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Thats the BG system cleaner my Stealer used to use on my truck during its first few years of service there. They used all of their products.
    Rex Kramer[QUOTED] likes this.
  6. Apr 22, 2021 at 5:44 AM
    Rex Kramer
    Georgia
    If it doesn't do the job, the next step is the pressurized cleaner that's fed directly into the fuel rail.
    Has the OP tried cleaning the MAF and Throttle body with spray cleaners yet, has he checked the air filter?
    FrenchToasty, speedtre and RdKing like this.
  7. Apr 22, 2021 at 6:06 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
  8. Apr 22, 2021 at 6:40 AM
    Rex Kramer
    Georgia
    Inexpensive scan tools have the ability to scratch the surface of what your ECU could tell you, but only the expensive dealer level scan tool can do a deep dive.
  9. Apr 22, 2021 at 6:54 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Yeah.... just spray the shit out of it... should be good. What was I thinking?
  10. Apr 22, 2021 at 2:00 PM
    Fred
    Hand Protectors
    Since its Earth Day I’ll split the difference here in the name of Peace and say the BG will work but I’d get a scan tool anyways just to see if codes pop up and address those accordingly.
    Did anyone plant a tree today?
    panicman, bmf4069, Voss and 1 other person like this.
  11. Apr 22, 2021 at 2:04 PM
    Rex Kramer
    Georgia
  12. Apr 22, 2021 at 2:09 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    Probably getting a scan is best as others mentioned. But for regular fuel system maintenance/cleaning you might check out this stuff. Being German the product standards require it does what it says.
    https://www.amazon.ca/gp/aw/d/B00LPW3E2I/ref=ppx_yo_mob_b_return_o0_img?ie=UTF8&psc=1
  13. Apr 25, 2021 at 6:26 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Even better...Seafoam in a tank of Techron. Do some maintenance before you wind up walking...
  14. Apr 25, 2021 at 6:57 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Maybe time for some 12 hole injectors?
    Voss likes this.
  15. Apr 26, 2021 at 9:28 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    This is true, but even a cheap scanner will tell you much more than a little light bulb. For years I used my Scangauge2 to scan trouble codes and from there was able to solve problems with help from the internet.
    It wasn't until I went against every bit of advice and got a VW GTI that I needed to get serious scanning power. There are some problems that don't light the CEL. Those cars are engineered by bastards.
    panicman, bmf4069, abcinv and 4 others like this.
  16. Apr 27, 2021 at 6:18 PM
    alb1k
    Left Coast
    It's good
    I didn't even remember posting this one, but I love the responses, that's not sarcasm. 6 days old and I have everything from maintain your vehicle (insert check mark) to spray the throttle body and in between. I like the scanner post and have tested one, but get the limitations. I have a great mechanic, the guy other mechanics go to, I just like to do what I can. I know another diesel, fuel, marine mechanic that uses Seafoam as part of maintenance. I've also heard of mechanics cutting corners on injector cleaning with Techron. Regardless, I like to stay on top of stuff. My 95K truck has well exceeded 100k maintenance 15K ago. So, all of the responses are great, and add to my knowledge. Thank you. See you at 500K, and before. :canada:
