2016 Toyota Tundra Whining Noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Buzz351, Apr 21, 2021.
  1. Apr 21, 2021 at 1:35 PM
    Buzz351
    Buzz351 [OP] New Member
    2016 Tundra SR5
    Hello ,
    Just signed up today and figured let me post about the whining engine noise my 2016 Tundra , 100k miles , developed. I hope someone finds this through a search and helps them out.
    For the past 6 weeks my truck developed a whining noise. A young mechanic determined that it was coming from the power steering pump , however , I was having no power steering issues. Power steering pump changed , noise still present. Found another thread on some other forum that said it was the “idler tension bearing” , changed that , noise still present. An old school mechanic showed up and said “ put the truck up on the lift”.....he took out his 2 foot door screwdriver put it on random parts of the engine , tapped on the alternator , and said “ it’s the alternator “.....alternator changed , problem finally solved. I forgot how quiet my truck was when it started. Hope this helps out anyone out who comes across this thread.
  2. Apr 21, 2021 at 1:38 PM
    Welcome from NY.
    Glad he figured it out without changing unnecessary parts.
  3. Apr 21, 2021 at 2:31 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    A good trick we used to use on the farm was a 3/4" or 1" wooden dowel, maybe 2-3 feet long, and use that to listen. Put your thumb over one end of the dowel, hold the other end on the housing holding the rotating bearing, and listen close to your thumb. It really works. Just gotta be careful around moving stuff
  4. Apr 21, 2021 at 3:21 PM
    Kywildman
    Kywildman New Member
    Joshua
    21 Tundra Silver SR 4x4
    Great advice
  5. Jun 18, 2021 at 7:13 PM
    Tundra11Racing
    Tundra11Racing New Member
    Justin
    VA
    2017 Black Tundra SR5 TRD OffRoad
    Katzkin Leather Seats TRD Pro Grille TRD Pro Wheel Caps Color Matched Front End Caps Extang Encore Tonneau Cover
    So glad to find this thread. My 2017 with 49,000 miles just started having the same problem and I had no idea where to look first. Thanks!
  6. Dec 18, 2022 at 9:25 AM
    Grey Fox
    Grey Fox New Member
    2016 Tundra 5.7
    I have a similar whine from my 2016 Tundra 5.7 85K and I thought sure it was the transmission. I've owned this truck for about 2 years and 12K miles and I hope it's only the alternator. I will get it checked out soon.
  7. May 5, 2023 at 3:14 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Did you ever change your alternator to see if that was what was making the whining noise on your truck? I have a ‘16 crewmax with 81,000 miles making same noise. Hoping it’s not the transmission too.
  8. May 5, 2023 at 3:16 PM
    Yota303
    Washington
    Or anybody else? Feel like this thread might be dead.
  9. May 5, 2023 at 3:20 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Does the whine change with increased RPMs? Does it change when sitting at a stop and turning the wheel?
    Does it whine at start up or does it kick in after a bit? I'd start there.
  10. May 5, 2023 at 3:26 PM
    Yota303
    Washington
    Mine has been making a whining noise for about a month now. Started out of nowhere and it is most noticeable right when I start it and then less once it’s warmed up but it’s always there when starting to accelerate from a stop. It follows engine speed and rpm’s while shifting, not vehicle speed. My first check was power steering fluid level as my old 4runner had a power steering fluid leak and the sound is almost identical to that of the power steering pump when low on fluid. No leaks and fluid level is normal on the Tundra. It sounds like like it’s from the general area of the alternator, water pump and power steering pump.
  11. May 5, 2023 at 6:39 PM
    Grey Fox
    Grey Fox New Member
    2016 Tundra 5.7
    I should have updated this forum a couple of months ago. So I took my truck to a shop I've been using for 25 years and I had them check everything out. I got my alternator changed out and the whining went away. Nice and quiet now. I went with a re-manufactured alternator with 2 years warranty versus the Toyota OEM with a 1 year warranty. And the total of the job was about $300 less, about $675.
    ZPhilip and Yota303 like this.
  12. May 5, 2023 at 7:22 PM
    Florida AF
    Logan
    North Florida
    Love when old threads bring value along the way! Glad it worked out for you.
  13. May 11, 2023 at 3:09 PM
    TOY4TKK
    TOY4TKK New Member
    2016, Silver Tundra TRD OFF ROAD
    My 2016 CM 55K miles has the same whining noise in the same area (Alternator, Power Steering Pump, Tensioner) when cold start up. I just replaced Tensioner Pulley and Serpentine Drive Belt but a whining noise still there. I don't have any problems with power steering system. What could be wrong????
    Thank you,
  14. May 11, 2023 at 4:42 PM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Alternator whine: sometimes bearings cause it but on Denso alternators (especially the ones on these Tundras) the whine is usually from a bad diode pack. To
    Test if it’s bearings or Diodes, you can unplug the connector on the alternator and start the truck. If the whine is gone, you know it’s diodes (or shorted windings) and not bearing related.
    Yota303 and TOY4TKK like this.
  15. May 12, 2023 at 1:29 PM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Here are a few pics of one of these alternators tore apart. The drive end has a Koyo bearing and the other end had a NSK bearing and that one is recessed slightly and a bear to remove without damaging the commutator.
    Yota303 likes this.
  16. May 15, 2023 at 1:59 PM
    Chriam1367
    Chriam1367 New Member
    2016 sr5 2wd 5.7
    Where exactly is the connector to the alternator? I need to try this, although I'm 95 percent sure my whine is the alternator.
  17. May 15, 2023 at 2:12 PM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    It’s right there in my picture. Can’t miss it lol
  18. May 15, 2023 at 2:31 PM
    Chriam1367
    2016 sr5 2wd 5.7
    I meant where can you get to it while it's still on the engine, I'll find it tho thanks
  19. May 15, 2023 at 3:27 PM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    It will be above the passenger side tire
  20. May 15, 2023 at 3:29 PM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    A little easier to get to if you remove the wheel but doable if you don’t
  21. May 18, 2023 at 2:22 PM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    Funny. I had similar noises and ended up being bad bearing in the alternator and shortly after, bearing in tension/idle pullety. This happens right under 75,000 which was covered by Toyota from my VSA. Now the truck fires right up and quiet at idle.
    Yota303 likes this.
  22. Jun 1, 2023 at 10:58 PM
    TOY4TKK
    TOY4TKK New Member
    Updated!!! Cost $30 plus 5 hrs labors the problem solved :). Mine was generator rotor bearing (brush holder assembly side) BAD.
    Yota303 likes this.
  23. Nov 2, 2024 at 3:27 PM
    JLB
    JLB New Member
    2017 Silver Sky 1794
    Advanced keys passive keyless entry w push button start King Suspension Camburg UCAs 35” Nito Ridge Grapplers Fuel Coupler - Gun Metal Black Machined with Dark Tint. Morimoto XB LED Headlights Morimoto Amber LED Fog Lights TRD Pro Grille + Hood Bulge Color matched mirror caps and door handles Color matched front bumper cap overlays Yellow Top Optima battery Stubby antenna AMP bed step Tundra license plate holders
    Man.. I'm encountering this right now. Whining noise pretty bad. 80k on my 2017 and the dealer is quoting me over 3k to replace the alternator. This sounds way more reasonable.
    HulkSmurf14 likes this.
  24. Nov 3, 2024 at 5:22 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    3k wow that is crazy
  25. Nov 4, 2024 at 3:54 AM
    yakeng
    yakeng 3URFE Apologist
    It's not an easy job, but 3K is theft. Run, don't walk.
  26. Dec 27, 2024 at 4:27 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Just got mine done (alternator) and was 1500$ at Toyota at about 6 hours. In my case under extended warranty. Whining noise is still present though haha.
