Contemplating 17" with 33's
Discussion in 'Wheels & Tires' started by kletzenklueffer, Apr 21, 2021.
  1. Apr 21, 2021 at 12:38 PM
    kletzenklueffer
    kletzenklueffer [OP] New Member
    Georgia
    XP pack, TRD CAI
    Hey all, I have 15 tundra XP double cab 6.6' bed with the XP package so it has 20" wheels. I have 275 65 20 tures on it and the truck came with what I'm guessing is a dealer installed 3/1 leveling kit.
    I have a set of 285-70/17 Cooper stt pro tires that my wife doesn't want on her 4runner so I was thinking of using them on my tundra and buying some Icon vector 5 wheels so that I could use them.
    Do yall think that the 33s will look too small? They measure right at 33 and my cooper atps on the truck are supposedly 34.2".
    That only around a .62" drop in clearance but I'm wondering if I'll end up back at the tire shop going to a 315-70 which is 34.7 or so.
    Anyone already been down this road?
  2. Apr 21, 2021 at 12:43 PM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    I believe the only 17” wheel that will fit around the calipers is the TRD Rock Warrior wheels. I just got a set dirt cheap and had them powder coated. Unfortunately I couldn’t save the bead lock rings. The tires are 285/70/17.
    MTRock likes this.
  3. Apr 21, 2021 at 12:48 PM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
  4. Apr 21, 2021 at 12:48 PM
    18" TRD Off Road Wheels
    There are other 17" wheels that will fit. Several members use them, but you do have to be careful about where the wheel weights are placed to keep from having the calipers knock them off.
    Truck looks good. :thumbsup:
  5. Apr 21, 2021 at 12:57 PM
    Doug2000
    Doug2000 New Member
    My Rock Warrior wheels weigh 22 lbs without the bead lock rings. 22 lbs for the wheels and 50 lbs for the tires is a pretty good combination.
    I had heavy tires on my Tacoma and hated it so I am conscious of the weight.
  6. Apr 21, 2021 at 1:04 PM
    marshmellow
    marshmellow New Member
    San Diego
    2021 Toyota Tundra CM
    I believe most/all 17 inch methods fit over the calipers. I like the smaller wheel with fatter tire combo.
  7. Apr 21, 2021 at 3:49 PM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    Methods in 17” will fit along with the Icons.
  8. Apr 21, 2021 at 4:12 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
