ANOTHER Towing Question.
Discussion in '2.5 Gen Tundras (2014-2021)' started by ATCinfantry, Apr 16, 2021.
  1. Apr 19, 2021 at 9:57 AM
    #121
    AZBoatHauler
    So.Arizona
    Problem is 99% of insurance policies don’t cover punitive damages so as the lawyer you could argue yourself right out of coverage for the claim. If you don’t think that matters you’ve never tried to collect a judgment from a person’s assets.
    I once pled a shooting/homicide case as the shooter “negligently perceiving a threat and discharging his firearm” so the insurance would pay the claim.
    Ruggybuggy likes this.
  2. Apr 19, 2021 at 10:27 AM
    #122
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm assuming your a lawyer. So what's your opinion on a vehicle towing over it's payload and getting into an accident that's no fault on his part.
  3. Apr 19, 2021 at 10:55 AM
    #123
    timsp8
    NY
    Don’t know. Maybe to keep the payload the same while accounting for the heavier 4wd components.
    https://www.toyota.com/tundra/ebrochure/
    Cpl_Punishment likes this.
  4. Apr 19, 2021 at 10:59 AM
    #124
    AZBoatHauler
    So.Arizona
    Here is my CYA disclaimer - the following is not legal advice nor does it imply or create any sort of client-lawyer relationship.
    In Arizona, if being over payload (or towing capacity/axle capacity/tire load, etc) did not contribute to the collision (in terms of would the collision have happened anyhow) generally speaking the operator would bear no fault or liability for the crash. Here are the instructions given to juries in Arizona when they are determining who is at fault for injuries -
    FAULT 5
    Statement of Claims, Definition of Fault;
    Definition of Negligence
    (Comparative Fault)
    Plaintiff claims that Defendant was at fault. Defendant claims that Plaintiff was at fault.
    Fault is negligence that was a cause of Plaintiff’s injury.
    Negligence is the failure to use reasonable care. Negligence may consist of action or inaction. Negligence is the failure to act as a reasonably careful person would act under the circumstances.
    FAULT 6
    Definition of Causation
    (Comparative Fault)
    Before you can find any party at fault, you must find that party’s negligence was a cause of plaintiff’s injury.
    Negligence causes an injury if it helps produce the injury, and if the injury would not have happened without the negligence. There may be more than one cause of an injury.
    I use the analogy it is the same as being in a non-fault crash while DUI - If I'm driving drunk stopped at a red light and get rear ended, I'm still 0% at fault for the collision. That doesn't mean there won't be any legal ramifications for my malfeasance...
    When a vehicle is grossly overly loaded and plows into a line of traffic killing 10 people, the fact the truck was overloaded may or may not have been the cause but the reckless disregard for others safety would likely be argued as an aggravating circumstance for which the defendant should be punished beyond the "monetary value" of the damages inflicted and lives that were lost.
  5. Apr 19, 2021 at 11:11 AM
    #125
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I appreciate your outlooks on it. Question, could it be argued that safely stopping a bigger load could have been done with a 1 ton truck? Not would it matter in real life, but in a court argument?
  6. Apr 19, 2021 at 11:24 AM
    #126
    AZBoatHauler
    So.Arizona
    Sure. Engineers doing accident reconstruction is a multi billion dollar industry. But that argument is shifting back to being overloaded was “a cause” of the collision.
    Regarding a 1 ton stopping the load faster, there will always be something that performs better and/or more efficient (a Supra stops a whole lot faster than a Rav 4) but negligence hinges on were you within “reasonable” use of the vehicle and if not was the unreasonable use a cause of damages and if so to what extent?
  7. Apr 19, 2021 at 11:36 AM
    #127
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Adam thanks for all your input
    WBW and AZBoatHauler like this.
  8. Apr 19, 2021 at 12:15 PM
    #128
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Thank you very much. Cheque is in the mail. :spending:
  9. Apr 20, 2021 at 7:29 AM
    #129
    wsutundra
    wsutundra 2021 Smoked Mesquite 1794
    00B99AB8-8545-40B4-9BBB-8AF6A99BEB2B.jpg Payload question, does a WDH reduce tongue weight? Obviously with my 3000lb camper I’m in no way near towing/payload capacities. But just curious if a WDH reduces its toll on the payload. I use the equalizer weight distribution/sway bar system.
  10. Apr 20, 2021 at 7:33 AM
    #130
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It just transfers weight from the rear axle and moves it forward to the front axle so overall payload on the truck would be the same.
  11. Apr 20, 2021 at 7:50 AM
    #131
    wsutundra
    I see, that makes a lot of sense. thanks.
    Ruggybuggy[QUOTED] likes this.
  12. Apr 20, 2021 at 7:55 AM
    #132
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    The WDH technically transfers some weight to trucks front axle and some back to the trailer.
  13. Apr 20, 2021 at 8:12 AM
    #133
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Of course, I gave a quick simple answer responding to the question on truck payload.
    A-A-Ron[QUOTED] likes this.
  14. Apr 20, 2021 at 8:18 AM
    #134
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    question. Does single vs dual axle trailer setup affect how a wdh works?
    ive pulled years of dual axle trailers, now im on a single and i am trying to dial in my setup
  15. Apr 20, 2021 at 8:28 AM
    #135
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It shouldn't effect the setup. All the measurements are made from the trucks front and rear axles. I had a large single axle trailer and once the WD is set up properly it made for a much better towing experience.
    Hbjeff[QUOTED] likes this.
  16. Apr 20, 2021 at 12:01 PM
    #136
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    Holy crap, I thought your trailer was sitting backwards behind your truck. I have never seen a tt that squared off before?
  17. Apr 20, 2021 at 12:17 PM
    #137
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I think its a V nose
  18. Apr 20, 2021 at 1:40 PM
    #138
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It's a Jayco. It was an odd trailer but it had lots of high end features. They only made it for three years I believe but the cost of manufacturing was high so they had to ask mucho dollars for them. No one was willing to pay 25K for a 20' TT.
