Window trim pieces
Discussion in '1st Gen Tundras (2000-2006)' started by Maker, Apr 20, 2021.
  1. Apr 20, 2021 at 2:16 AM
    Maker
    Maker [OP] New Member
    Christian
    Wyoming County, PA
    2002 Red Tundra SR5 AC 4.7 TRD
  2. Apr 20, 2021 at 3:41 AM
    I just did mine a few weeks ago. The clips help hold it in place. It doesn't come with anything chrome. The new ones are solid black.
    It wasn't too bad to install. It just takes a lot of force to pop off the old ones. I got free shipping by ordering through Toyota's parts program.
    Jack McCarthy, Maker[OP] and BubbaW like this.
  3. Apr 20, 2021 at 4:00 AM
    Professional Hand Model
    Fred
    Hand Protectors
    You could tape off and shpray paint or bedliner on the existing ones after a good prep sand and wipe down.
    Glock 40 and Maker[OP] like this.
  4. Apr 20, 2021 at 4:44 AM
    Maker
    Christian
    Wyoming County, PA
    Oh so these just clip in where the chrome trim currently is. Perfect. The picture helped a lot. Thank you!
  5. Apr 20, 2021 at 5:32 AM
    I don't know if your truck is different but for me, there was no chrome trim. Are you sure what you are seeing isn't the area where the black rubber coating wore off after 18 years? I've seen other trucks where the black wears off and under it appears chrome. Just make sure you take your time and line it up correctly because once you push it in place, you likely won't be able to fix it.
  6. Apr 20, 2021 at 5:38 AM
    Maker
    Christian
    Wyoming County, PA
    This is what I'm talking about. This is for that, right? Thanks again for your help.
    Jack McCarthy likes this.
  7. Apr 20, 2021 at 6:00 AM
    Yessir. It was black originally. You'll have to remove the door panel and pry that old one off. It helps if you have a wide pry tool to spread out the force.
    It will look like this once you're done.
  8. Apr 20, 2021 at 6:24 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    As PHM suggested, paint them where they sit.
    I prepped and bedlined mine in place, pretty easy.
    Rough them up with sandpaper, isolate with tape, apply adhesion promoter or primer, spray with bedliner. Perfecto.
  9. Apr 20, 2021 at 6:32 AM
    I want to do it this way, but it seems like prep on these is a bitch, I have large hands and it seems impossible to get down into the valley to clean all the old top layer off.
    Another reason to buy new, is the felt wears down over time and then allows more dust and dirt down into your window
  10. Apr 20, 2021 at 6:33 AM
    Maker
    Christian
    Wyoming County, PA
    This was my reasoning as well.
    BubbaW likes this.
  11. Apr 20, 2021 at 6:34 AM
    Maker
    Christian
    Wyoming County, PA
    Looks like my trim tools that I bought will come in handy. Thanks, I like this look a lot better than how mine currently is. I'll be ordering these.
  12. Apr 20, 2021 at 6:35 AM
    I bought our 4runner in Sandy Ego, and it only took maybe 4 months in the desert to dry rot the back window sweep and the driver(most used windows) when I replaced with oem you could tell a big difference in the felt thickness
  13. Apr 20, 2021 at 6:38 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Most of my top layer was non-existent, pretty much down to chrome. For me it was much easier to prep and coat rather than remove and replace.
  14. Apr 20, 2021 at 6:43 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I had to chuckle when I read this. I too have large hands... it's a blessing and a curse. We should high-five and shake the earth.
  15. Apr 20, 2021 at 6:44 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    As with everything in life, different strokes for different folks. While I did consider the paint method, it was a personal decision after 17 years to go back new OEM. In this case, it is now new and my wore out felt that window slides on is now water resistant wise....YMMV ! Similar to our head units, some wish to go new HU and others wish to stay original and add limited amount of features to their orig HU....as the world turns !
    Second what Erik said....patience ! I happen to be in process of doing mine and being anal, I went as far as removing mirror due to trim extends under mirror by a good 3 inches, placing new trim in place loosely and marking the clips location with neon sharpie. I have a plastic putty knife which helps with initial removal. Just bop that sucker and comes off with out marring truck paint.
  16. Apr 20, 2021 at 6:47 AM
    Haha mine are small compared to my dads, who was a wood worker, we called his banana hands. Mine aren’t on that level yet, but I use my hands for a living(not the same as PHM) so I’m sure I’ll get there one day
  17. Apr 20, 2021 at 6:58 AM
    I normally agree with the painting option. I did that with the rest of my black trim. But it's not always a permanent fix and all that taping off takes a lot of time. Also, my fear was that they will eventually discontinue this part and I would be stuck with this trim forever, with the felt getting worse and worse over time.
    Maker[OP], BubbaW and Glock 40 like this.
  18. Apr 20, 2021 at 3:26 PM
    Fred
    Hand Protectors
    I need to wipe my tears back for your sad story here. :rofl:
    Yeah I can see the dust being a problem in the desert. Someone else was complaining about water getting in there which happens even with new ones. New ones are nice. Just offering another alternative here. Works well.
  19. Apr 21, 2021 at 7:39 AM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Did you also have to remove the mirrors to install?
    I was not sure about that part.
    I plan on still keeping my tundra long term. Whatever it cost. I cant find anything brand new that I would like as much. And like others said. These parts are cheap as parts go. And may not be able to get them later. Already I have noticed a lot of parts have been discontinued.
    Thanks
  20. Apr 21, 2021 at 7:42 AM
    I had to on my access cab but someone with a DC said they didn't have to, which doesn't make sense to me. On my AC, the trim sits slightly under the mirror.
    BubbaW likes this.
  21. Apr 21, 2021 at 8:09 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    As Erik alluded to, on the DC it extends under our/my mirror a good 3”....but it was 2 fold for me, wanting not to cut trim to barely fit under and also to figure mirror out as far as how to get the triangle separated from mirror for repainting that grey ugly crap. The rest of window trim, lock actuator comes in tomorrow, so I’ll be hopefully spending a few days installing trim and painting. This truck will be in family for awhile IF either grandson wants it and besides, all I got is time being retired....keeps mind active.
    Damn green pollen, it’s in every orifice
  22. Apr 21, 2021 at 10:09 AM
    RR60
    RR60 New Member
    Mine is a regular cab. Maybe I should plan on it.
  23. Apr 21, 2021 at 5:50 PM
    I've already got micro scratches on the side glass from the grit that gets caught in the felt.
  24. Apr 21, 2021 at 5:55 PM
    Pretty sure my felt is non existent.
    The 4runner ones were so bad they detached from the main molding and would go up and down with the window.
  25. Aug 17, 2021 at 3:34 PM
    Actually, this is a valid concern. I'm about to start buying stuff now the 4th gen trucks are coming out. I've already noticed a couple of interior trim parts that've turned up discontinued the last two-ish years. One was a center console part that was around 4 months ago and discontinued as of 2 weeks ago.
    These window felt/trim bits, and I think the 3rd brake lamp assembly will be the big ones for me. I've been trying to remember the other annoying parts that've discontinued on other vehicles. Interior door pulls are one. The plastic rod clips used for for door and tailgate locks and handles.
  26. Aug 17, 2021 at 4:20 PM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    Our secondary hood release has been discontinued.
    :annoyed:
  27. Aug 17, 2021 at 4:30 PM
    I ordered that 3rd lamp assembly a year or so ago, not cheap; and put LEDs to hopefully not burn up the reflector……..and now I have a cap that blocks all that light…..
    FirstGenVol likes this.
  28. Aug 17, 2021 at 4:44 PM
    Does it come with a gasket or is it not needed?
  29. Aug 17, 2021 at 4:47 PM
    It did come with a gasket, and yes it was definitely needed. The old gasket pretty much crumbled as I pulled the light out
  30. Aug 17, 2021 at 5:01 PM
    This is what I wrote down in my notes a year or two ago.
    81570-0C010 => 3rd brake light complete assembly
    81572-0C010 => 3rd brake light gasket (housing to lens, not housing to roof!!)
    81571-0C010 => 3rd brake light lens cover
    EDIT: The gasket is ONLY for the lens cover to seal to the truck.
    BubbaW and FrenchToasty like this.
