Clunk after 3" lift.
Discussion in 'Suspension' started by renlo, Jul 22, 2017.
  1. Jul 22, 2017 at 2:49 PM
    renlo
    renlo [OP] New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    I need some help. I have developed an intermitten clunk on the front end after I redid my lift. The cluck happens when going in reverse and turning the steering wheel to the right. I have also been able to replicate it when backing up slowly and braking quickly, as well as going forward slowly and braking quickly also. It appears to happen when there is a shuft in weight either front to back or vice-versa.
    Previously I had the bilsteins set at the middle setting with 2 coachbuilder shims for a total of 2.5" lift. Never had a clunk. Now I have the bilsteins on the top setting with one shim for a 3" lift. I also added SPC UCAs and a front diff drop and have the clunk.
    I had the shop check all bolts and they assured me they are tight. One of the diff drop bolts was a little loose and I tightened it, but the clunk was still there. I'm thinking its either sway bar or lca bushings, but my trucj only has 1800 miles.
  2. Jul 22, 2017 at 3:03 PM
    Paul84
    Paul84 New Member
    Paul
    2014 4x4 Crewmax
    Try installing a sway bar drop kit. They're cheap on Amazon and easy to install. I had the same issue with my truck after a 6112/5160 w +3 CB shackle lift and it seams to have cleared up the isssue.
    Bmxrider1331 and renlo[OP] like this.
  3. Jul 22, 2017 at 3:10 PM
    renlo
    Rene
    Thats exactly what I was thinking as I wrote the post. I remeber I installed one on my tacoma when I put coilovers set at 3" on it.
  4. Jul 22, 2017 at 4:59 PM
    15whtrd
    15whtrd Mr. Blonde
    Make sure your a arm adjustment cam bolts are tight. Sorry I can't remember the name right now. I think I remember they're supposed to be like 150 to 200 pounds. Hopefully someone can correct me.:cheers:
    Pudge likes this.
  5. Jul 22, 2017 at 9:08 PM
    TheBeast
    TheBeast The Beach
    tag for outcome
  6. Jul 22, 2017 at 10:27 PM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    If you put any kind of block on the rear and the bolts are the slightest bit loose they will cause a clunk when changing direction
    renlo[OP] likes this.
  7. Jul 23, 2017 at 3:12 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    I have a clunk at random times and I think its my ball joints. I too have SPC uppers. Will report back once I put the new ball joints in.
  8. Jul 23, 2017 at 3:57 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    225ftlbs
    renlo[OP] and 15whtrd[QUOTED] like this.
  9. Jul 23, 2017 at 4:49 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    My `14 with the 7" ProComp lift would occasionally make a hell of a bang after turning the wheel while stopped and then moving again- as in a parking lot or backing in my driveway. It was like something bound up under tension unloaded once the tires rolled free.
    The first time the shop looked at it they told me the adjustment cams were 180 degrees out. Correcting that and redoing the alignment was good for about two or three months. After casually driving down a deeply rutted dirt road the clunk was back. The shop looked at it again for two and a half hours and came back scratching their heads, even after calling ProComp.
    I got tired of the noise and no solution and traded that truck unresolved.
    Black Wolf and renlo[OP] like this.
  10. Jul 23, 2017 at 4:56 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    I thought this was only me. If I'm at full lock and hit take a turn I get a pop too. I always thought it was just where I had my wheel turned too tight. Had the truck three years and have noticed it but 2-3 times in the past six months. Commenting for more info :D
  11. Jul 25, 2017 at 6:03 AM
    renlo
    Rene
    Havent had a chance to look at it but the only other thing I had changed was SPC arms and diff drop kit. I will post update later.
  12. Jul 25, 2017 at 6:04 AM
    renlo
    Rene
    How long have you had your SpC upperd, mine are new with maybe 100 miles.
  13. Jul 25, 2017 at 7:08 AM
    joem1cha3l
    Albany, NY
    Mine had less than 500 miles on them. They came out with a 2.0 ball joint that mine did not have. I had the old style ball joint (1.0) and it was apparently problematic.
    David from @ToyTec Lifts hooked me up with the new ones.
    T-Rex266 and renlo[QUOTED][OP] like this.
  14. Jul 25, 2017 at 8:03 AM
    renlo
    Rene
    Any way to find out what version I have (labeling' serial number) I bought mine last month.
    When wouls you hear the clunck? Driving normal, turning slowly?
  15. Jul 25, 2017 at 8:04 AM
    renlo
    Rene
    No block or shackles in the rear.
  16. Jul 30, 2017 at 12:11 PM
    renlo
    Rene
    Well, it appears the clunk disappeared after I added a sway bar drop kit. I no longer have any clunking noises when reversing out of a parking spot. Hopefully the clunk does not return. I will update in the future.
    T-Rex266, AxelsHumanDad and gosolo like this.
  17. Aug 8, 2017 at 8:36 AM
    renlo
    Rene
    Sway bar kit was not the answer, torqueing down the LCA was the real answer.
    Throwwire and The Juice like this.
  18. Aug 8, 2017 at 8:45 AM
    The Juice
    The Juice THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    Thank you for this post!!!
  19. Apr 19, 2021 at 8:28 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    I am thinking this might be my problem. Was this the permanent solution?
