Creak when turning steering wheel - coming from front axle
Discussion in '2.5 Gen Tundras (2014-2021)' started by greg8765, Apr 17, 2021.
  1. Apr 17, 2021 at 6:36 PM
    greg8765
    greg8765 [OP] New Member
    Grant
    Utah
    2021 Cement Tundra
    Does anyone else get creaks when turning the steering wheel? If so, do you have a fix?
    This damn thing is four months old and I've had nothing but annoying ass sounds coming from every which way. It's been in the shop at least six times and can't make anything sound like the way a new truck should sound. I honestly wish I had my Tacoma back. Not a single problem with it.
  2. Apr 17, 2021 at 7:10 PM
    Kywildman
    Kywildman New Member
    Joshua
    21 Tundra Silver SR 4x4
    Creak inside or like outside suspension?
  3. Apr 18, 2021 at 8:42 AM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    outside
  4. Apr 18, 2021 at 9:17 AM
    Kywildman
    Joshua
    I would just get it into the dealer, I have a hard enough time diag some noises inside the truck lol. Nice rig btw, hope you are able to resolve your issues.
    greg8765[OP] likes this.
  5. Apr 18, 2021 at 9:34 AM
    Kanobi13
    Kanobi13 New Member
    Sway bar
  6. Apr 18, 2021 at 9:41 AM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    do you have any skid plates on the truck?
    15whtrd likes this.
  7. Apr 18, 2021 at 10:51 AM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    factory
  8. Apr 18, 2021 at 10:51 AM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    needs to be tightened up?
  9. Apr 18, 2021 at 11:00 AM
    glowblue
    glowblue From time to time
    VA
    Are the creaks through full travel of the steering wheel both left and right? When vehicle is in motion or still? Does sound like metal to metal, or some other sound?
    Maybe post a video of it... others have mentioned the skid plate and sway bar and LCA bushings.
  10. Apr 18, 2021 at 11:33 AM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    doesn't matter if it's full travel or slight turns of the wheel. it happens when moving and parked. I'll try and grab a video later today
  11. Apr 18, 2021 at 12:05 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Why would you get rid of something that has never had a problem????
    Kywildman likes this.
  12. Apr 18, 2021 at 3:10 PM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    right? needed something bigger
  13. Apr 18, 2021 at 3:14 PM
    Roborob70
    Robert
    Makes sense, I'll just go back in my hole....
    greg8765[QUOTED][OP] likes this.
  14. Apr 18, 2021 at 3:23 PM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    I can't figure out how to upload a damn video. None of the file formats are working for me. I think my solution is to be a big boy, buy a grease gun and literally coat everything that has a metal on metal contact and is supposed to move.
  15. Apr 18, 2021 at 5:33 PM
    glowblue
    VA
    You have to post elsewhere like YouTube and then post the link, can’t post videos directly here.
  16. Apr 19, 2021 at 3:01 PM
    mike175gr
    mike175gr New Member
    Michael
    Skid plate probably. Or if you are going lock to lock put a little grease in the turn stop surface...
  17. Apr 19, 2021 at 3:03 PM
    realprotundra
    realprotundra Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock TRD Pro DC
    I have these creaks/clicks too. I’ll be going in for my 5000 mile service shortly and will be adding it to the list of things to check out.
  18. Apr 19, 2021 at 4:10 PM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    well, i crawled my fat ass under there and had my son wrench back and forth on the steering wheel and it seems to be coming from the front axle when the rod moves back and forth. how do you lube that bad boy? it looks all sealed up
  19. Apr 19, 2021 at 4:25 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    Stock suspension?
  20. Apr 19, 2021 at 4:28 PM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    yes
  21. Apr 19, 2021 at 4:31 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    :notsure: I got nothing.... if it’s that new def let Toyota look at it
  22. Apr 19, 2021 at 6:42 PM
    glowblue
    VA
    Yeah... if it was me I’d take it to the dealer and tell them don’t call me until it’s fixed.
