Trans Fluid Level Check
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kywildman, Apr 16, 2021.
  1. Apr 16, 2021 at 6:37 PM
    Kywildman
    Kywildman [OP] New Member
    Joshua
    21 Tundra Silver SR 4x4
    So I have an idea for doing the fluid level check on our trucks. Per TIS, the truck must be level. Rather than jacking up/shimming the tires to level the truck out...how about playing with tire pressures? Thoughts?
    Thanks
  2. Apr 16, 2021 at 6:45 PM
    timsp8
    NY
    Where are you doing it? Fairly level driveway/garage or on a hill? As long as it’s close to level you’ll be good.
    Are you changing your 21? How many miles do you have?
  3. Apr 16, 2021 at 7:01 PM
    Kywildman
    Joshua
    1500 ish on the miles. I’m living in Florida, in a condo until it sales. Don’t really have anywhere to do it, as my job is kind of weird about us working on our own junk.
  4. Apr 16, 2021 at 7:02 PM
    Kywildman
    Joshua
    It’s pretty flat, but everything has a grade for flood drainage as I’m at about 15’ above sea level lol
  5. Apr 17, 2021 at 5:14 AM
    timsp8
    NY
  6. Apr 19, 2021 at 7:10 AM
    lakedrum03
    lakedrum03 New Member
    Seth
    2021 Tundra Platinum
    Working on it.
    Doing some research, the WS fluid is not synthetic, but rather a conventional fluid made by Mobil, from everything I can find.
    A buddy of mine is in love with Transynd transmission fluid. It is a synthetic fluid that claims to increase change intervals by 300% in big trucks.
    Has anybody changed out the WS and went with Transynd?
  7. Apr 19, 2021 at 9:21 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    There are a few threads on here about using alternatives to WS fluid but no other ATF is approved for use in our transmissions.
    I had a neighbor that was talked into changing the ATF on his BMW by a local oil change house. Well, he made it from the oil change location to the bottom of our street but no further. I don't think that I have to mention that they used a "recommended" ATF instead of an "approved" fluid.
    Piki likes this.
