Stereo adapter for touchscreen system
Discussion in '1st Gen Tundras (2000-2006)' started by Beefnbread, Apr 18, 2021.
  1. Apr 18, 2021 at 9:21 PM
    Beefnbread
    Beefnbread [OP] Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Whatsup guys!!!
    So I bought this pretty snazzy pioneer touchscreen radio with all the fancy Bluetooth and apple car play stuff, but I encountered an issue with the stereo connector I bought. It says on the box that it works for pretty much everything Toyota 1980+, including my specific model. Apparently I have a different headset connection than some of the other tundras.
    Down below is the stereo connection that DIDNT work.
    Basically I’m looking for a 20 pin adapter and I’m wondering if any of you guys out there know where to buy one. I already tried rummaging through the internet to find one, but it seems I’m out of luck.
    Edit:
    I should of snapped a picture of the actual 20 pin connection from my truck, but I had to rap things up pretty quick. I’m assuming you guys know what I’m talking about anyway.
  2. Apr 18, 2021 at 9:36 PM
    Freeezen
    Freeezen New Member
    metraonline.com
    Beefnbread[OP] likes this.
  3. Apr 18, 2021 at 9:41 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Close, but no dice.
    Here’s the plug that I need the adapter for.
  4. Apr 18, 2021 at 9:54 PM
    Freeezen
    Freeezen New Member
  5. Apr 18, 2021 at 10:09 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    70-8113 is definitely the right connection, but I think I need to go back a step. Here’s what I’m trying to connect. Seems like the first connector I got had the right wiring at the end of it, but just the wrong adapter.
    By the way, idk if I’m even going about this right. First radio install
  6. Apr 18, 2021 at 10:13 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Many of our trucks came with a separate amp that uses the old style connectors.
    Below your radio and hvac controls, is there an amp mounted under the dash? If yes, remove it and use your current adapter.
    See here:
    https://caraudiotips.blogspot.com/2013/01/toyota-tundra-factory-amp-bypass.html?m=1
    This is the case for earlier models. Later years they moved the amp to behind the rear seat and used a different connector.
    TRDFerguson likes this.
  7. Apr 18, 2021 at 10:18 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    70-8113
  8. Apr 18, 2021 at 10:26 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    I’ll follow up with you on it tomorrow since it’s about time to sleep. first thing tomorrow after work.
    But from what you showed me on that link..
    Just remove the amp and use the plug-in from the amp onto the adapter I currently have? I can do that. If it fits :fingerscrossed:
  9. Apr 19, 2021 at 9:08 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Worked out great! Did everything you said and was pretty simple pimple from there. Thanks
    RPR and bmf4069 like this.
  10. Apr 20, 2021 at 8:46 AM
    :yes:
