How much grease in cv boot?
Discussion in '1st Gen Tundras (2000-2006)' started by Beefnbread, Apr 16, 2021.
  1. Apr 16, 2021 at 9:27 PM
    Beefnbread
    Beefnbread [OP] Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Just noticed today that my driver side cv boot has been leaking quite a considerable amount. One of the clamps got loose and allowed grease to splash out everywhere. I could probably say the majority of it already spewed out, so I just quick fixed it for now and put a hose clamp around the existing clamp for the time being. The existing clamp is flat enough so when I put the hose clamp around it it won’t damage the boot.
    I don’t have too much time until work tomorrow to fill it up with grease so I’m just leaving it like that until tomorrow.
    So my question to you guys is how I remove the existing cv clamp without damaging the boot and how much grease should I put in it to compensate what was lost? Or is it even worth trying to put more in?
    Existing clamp looks like the one down below.
    Thanks guys
  2. Apr 16, 2021 at 10:54 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    DarkMint, Glock 40 and Beefnbread[OP] like this.
  3. Apr 16, 2021 at 11:17 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Hi, Tilly, thanks for the message.
    I was inspecting the boots and axle earlier and they look like they are in pretty decent shape. I feel like they must’ve been replaced within the last 5 years. Boot itself isn’t showing any signs of excessive wear. Doesn’t look brittle or aged.
    I’ll probably just end up prying off that clamp and shoving some grease in there.
  4. Apr 16, 2021 at 11:22 PM
    TILLY
    Massachusetts
    That's good news. You'll be fine if that's the case. :thumbsup:
  5. Apr 17, 2021 at 6:00 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Use a Dremel with cut-off wheel to remove that strap.
    Beefnbread[OP] likes this.
  6. Apr 17, 2021 at 6:01 AM
    Professional Hand Model
    Fred
    Hand Protectors
    @FrenchToasty and @Glock 40 just rebuild theirs. You could check with them. FrenchToasty even measured his Precise Grease Weights on his Coffee Scales.
  7. Apr 17, 2021 at 6:04 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    My replacement boot came with a pre-measured grease pack.
  8. Apr 17, 2021 at 6:04 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There's just a couple of OZ. of grease in them. They can be had at the auto parts stores for a buck or two.
  9. Apr 17, 2021 at 6:53 AM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Sounds like a good idea to me. I Just bought a cordless Makita fine tool couple months ago and I’ve been fixin’ To use it
  10. Apr 17, 2021 at 6:57 AM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Grease is grease right? All does the same job
    Just bought this at autozone and I’ll be packing it in later tonight
  11. Apr 17, 2021 at 7:31 AM
    To a certain extent, yes, grease is grease. None is bad, any is good, and properly spec'd and measured is probably best. The properties of wheel bearing grease are likely not ideal for CV application, the "slingability" vs stickiness, metal content etc. differs by application. Get CV grease and be done.
    Glock 40 likes this.
  12. Apr 17, 2021 at 7:47 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    He won't get an accurate measurement since there's no way of knowing how much old grease is still in the bearing assembly. Probably doesn't matter, too much is better than not enough. I'd be more concerned with contamination. Best procedure would be to pull the axle, scoop and wash out ALL of the grease from the bearing assembly, dry, and pack with pre-measured grease pack that comes with replacement boot... or (easier and faster) just slap in a new or reman CV axle altogether.
  13. Apr 17, 2021 at 11:16 AM
    Fred
    Hand Protectors
    French Toasty used some super synthetic type Race Grease made for CV Joints and built a cone with it to slip over the boot.
    FrenchToasty and Beefnbread[OP] like this.
  14. Apr 17, 2021 at 12:59 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
  15. Apr 17, 2021 at 1:58 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    I got off early today and visited my local auto part stores to see if they have cv boot grease... and they don’t have any.
    So I think I’m just going to throw in that wheel bearing grease for now and hope for the best. I don’t think using a different kind of grease is worse than leaving it as it is right now.
    But on the bright side, I bought some throttle body cleaner when I was there so I’ll be doing a bit of maid work on my truck today.
  16. Apr 17, 2021 at 2:06 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Maybe this would work as well? :D
  17. Apr 17, 2021 at 2:07 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    I was thinking about making that joke already. Lol
  18. Apr 17, 2021 at 4:41 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Great success.
    des2mtn, bmf4069, Filthyphil and 5 others like this.
  19. Apr 17, 2021 at 5:13 PM
    Any grease is better than none. It'll lube
    Filthyphil likes this.
  20. Apr 18, 2021 at 3:16 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    How did you get the old clamp off and did you just pry the boot up and squirt a couple oz of grease in?
  21. Apr 18, 2021 at 4:46 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    I used this guy below in the picture to cut off the little nipples off the clamp. After cutting them off I stuck a flathead in between the two layers of the clamp and it popped right off with ease. All without damaging the boot.
    As for the grease, I just slid the boot back to get enough space To put some in. There was actually quite a bit left. I just estimated how much I needed to put in and called it good tbh. Just enough, but not too much.
  22. Apr 18, 2021 at 4:51 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Did all that in like 10 minutes. Right after that I cleaned my throttle body out and took it for a test drive. Felt audacious enough to drive back to autozone and buy some spark plugs. Slapped those in and now I’m a happy camper. Happy truck is a happy beef :dancingbacon:
  23. Apr 18, 2021 at 4:57 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Not sure what others think on the forum, but I’d be a little concerned about the clamp you used. The CV boot clamps close that at for a reaso , and that hose clamp might come loose over time due to vibration and force. And CV grease is a much different consistency than wheel bearings grease. But, having something in their beats nothing at all.
  24. Apr 18, 2021 at 5:01 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Agree with you on the grease part, but I’ve been looking on the internet about using hose clamps instead of the actual clamps. To my understanding it appears that the majority of people who switched clamps haven’t experienced any problems for years. Also, I might of used an actual cv clamp but I don’t own one of the crimping pliers.
  25. Apr 18, 2021 at 5:34 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
  26. Apr 18, 2021 at 6:42 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When modifying the 1st Gen Tundra CVs for use in the long travel 1st Gen Tacomas we always used hose clamps on the boots and never had a single issue. Ran them up to 100 mph and all was good.
