  1. Apr 17, 2021 at 11:03 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah. Nothing like a Pro Job for great results. Around here it be over a $1k for that side doink repair and without truck for days. I think I had about less than $200 total with the Bondo, Sand Paper (found on street), 4 cans of paint, 3 Clear Coat, Tape, etc.
    She passes the 15’ test so I’m happy. :rofl:
    Voss, NUDRAT, abcinv and 1 other person like this.
  2. Apr 17, 2021 at 12:54 PM
    Fred
    Hand Protectors
    Nice. You can do the PHM Jumper Mod. Check my build page. One push turns on both lights. I discovered this as an after thought when adding Aluminum Foil Tape inside the Map Light Cavity for better reflectivity (after removing those metal bezels like you’ve done). I sizzled the switch on one side (accidental short with a bad Hand Move:rolleyes:) and it stopped working so I added a jumper wire over to that side so its a one push scenario now.
    Works differently when both switches are operational so you’ll only operate one side (one push on one side). If one of the switches is sizzled it doesn’t matter what side you push.
    Voss[QUOTED] likes this.
  3. Apr 17, 2021 at 1:34 PM
    Fred
    Hand Protectors
    Added some BT to Stream my favorite channel on XM App.
    Darkness and alb1k like this.
  4. Apr 17, 2021 at 1:40 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  5. Apr 17, 2021 at 2:21 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Today I’m frustrated yet again with work I had a mechanic do in the past. Steering rack bushing have play so changing out with Total Chaos poly bushings. Turns out my mechanic put one of the bolts in from the wrong end when they changed my steering rack and sway bar. Gotta take the sway bar off just to remove this bolt.
  6. Apr 17, 2021 at 2:32 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I'm almost certain that's how mine was too. I think they just come that way.
  7. Apr 17, 2021 at 2:35 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Maybe, what do I know but the YouTube video I watched changing out the original bushings had the bolt the other way... where there’s plenty of room for the bolt to come out.
  8. Apr 17, 2021 at 2:43 PM
    Fred
    Hand Protectors
    They do not. Factory is opposite at least on 2002.
    Tundra2 and Voss like this.
  9. Apr 17, 2021 at 2:45 PM
    Fred
    Hand Protectors
    Yeah. I’ve corrected quite a bit of Goofy Mechanics repairs on my truck, as well. Its highly frustrating to say the least.
    speedtre and Voss[QUOTED] like this.
  10. Apr 17, 2021 at 2:47 PM
    Fred
    Hand Protectors
  11. Apr 17, 2021 at 2:54 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Atleast this one isn’t as damaging as the slip yoke incident
  12. Apr 17, 2021 at 2:56 PM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    TPMS light came on a week ago. Mine is a 2006 DC, I decided to try and disable it by cutting the pink/silver wire and grounding it. Worked like a champ. I cut the wire and ran it thru a 3 way switch then to ground. The other leg of the switch, I ran the wire back up to the harness, completing the circuit like it was factory. Now in bypass mode, no light. In the mode that completes the circuit, I have a flashing TPMS light. In the "center" switch position (open circuit)I have a steady on TPMS light.
    I have a tire pressure gauge, I rotate and inspect my own tires and I look at my tires every time I get in/out of the truck. I'm not going thru the hassle and expense of fixing this on a 15 year old truck. Just like the check engine light for the secondary air injection pump. Sometimes delete is the best option.
    I had to pull the radio, I couldn't get my fat hands thru the glove box side. A little tight and awkward but well worth the effort.
    I don't trust much of what I read on the internet, especially when it comes to cutting a wire and grounding it. I put a 2 amp fuse in the wire I grounded. I hate the smell of hot electrical smoke.
  13. Apr 17, 2021 at 3:00 PM
    daveeasa
    It’s possibly just the batteries in the sensors. I don’t know that they are expected to last much longer than 15 years.
  14. Apr 17, 2021 at 3:01 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Spark plugs & air filter (to get free shipping) arrived. Wanted to verify gap on plugs, got out owners manual & it says my truck uses the double top plugs, not traditional single. So I ordered the wrong plugs for my truck. looked at rusty bolts on my ignition coils & said - nope. Aint gonna be the one to snap off one of those bolt heads.
    So I changed my air filter. Opened up the case & looked at the filter & saw it was purdy & clean. Thought I - great, didn't need it, another fail. Took it out anyway realizing I was looking at the engine side of the filter. Joy - filter was dirty. Can't see it in the picture, but it's got leaves caught up in it plus the dirt. So - all in all, changed my air filter. Small victories. :(
    for naught?
    nah - fresh air side
    pine needles - yes, acorns & other signs of nesting - no!
    Used the shop vac to blow out the engine bay since I was having 'successes'. LOL.
    Darkness, hammeron, Voss and 4 others like this.
  15. Apr 17, 2021 at 4:12 PM
    kenadavis
    kenadavis New Member
    Ken
    South Florida
    2006 Tundra Limited Access Cab
    Not exactly what you were talking about but here’s what I did to mine. I only got the first coat laid down and then had to stop. There’s some areas in the grey that need to be blended before I go too far. Plus I gotta outline around the graphic to hide some of that I white primer overspray. Wasn’t the best tape job.
    oscardog86, Darkness, NUDRAT and 4 others like this.
  16. Apr 17, 2021 at 4:24 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Wait the double? That’s for the v6
    Darkness and NUDRAT[QUOTED] like this.
  17. Apr 17, 2021 at 4:26 PM
    empty_lord
    05 rollover special
  18. Apr 17, 2021 at 4:56 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Finally got me a tailgate on. :yay: Huge shout out to @lsaami for selling me the tailgate guts. That helped out a bunch :thumbsup: 20210411_182712.jpg
    Darkness, lsaami, bmf4069 and 4 others like this.
  19. Apr 17, 2021 at 5:27 PM
    aRabidChicken
    aRabidChicken New Member
    Stuart
    2001 SR5 4x4 V8
    What brand are your covers?
  20. Apr 17, 2021 at 6:29 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    PO lived on gravel. I did the bed rails last year but the bumper was forever dirty. The dust was about 3/4" thick under here.
    Pulled the shell to clean the winter firewood mess out. The black glass has salt on it from the trip to CO.
    The springs have settled to 23 1/4" now.
    The shell is hanging from the rack in the garage. I will report back if it is on the floor in the morning.
  21. Apr 18, 2021 at 11:16 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
  22. Apr 18, 2021 at 2:27 PM
    You should be able to take off you front bumper in 15 minutes to work behind it. IIRC it’s something like 4 bolts. I also remember some bumper shock mounts I had to loosen or remove.
    NUDRAT likes this.
  23. Apr 18, 2021 at 2:48 PM
    empty_lord
    05 rollover special
    Used it and the Tacoma today on the farm... fun stuff coming Tuesday (new tractor and my uncles 04 tundra)
    hammeron, NWPirate, MS22 and 6 others like this.
  24. Apr 18, 2021 at 3:16 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Applied Solution Finish to the plastic trim around the bed and bumpers. Wow, this stuff works.
    abcinv, NUDRAT and FrenchToasty like this.
  25. Apr 18, 2021 at 3:30 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Changed my transmission fluid... 4 times. Drained my 2wd trans pan and it measured as 3.1 quarts.
    Used a total 4 quarts of WS and two gallon bottles of the Valvoline Maxlife ATF.
    Also used my homebrew pressurized fluid filler setup I built this week. Worked great.
    hammeron, bmf4069, CodyP and 11 others like this.
  26. Apr 18, 2021 at 4:15 PM
    kenadavis
    Ken
    South Florida
    Glock 40[QUOTED] likes this.
  27. Apr 18, 2021 at 5:20 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    So I do have the right ones - cool. Will have to re-read owners manual, I was speed reading in the wind.
    Thanks @empty_lord
  28. Apr 18, 2021 at 5:21 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Thanks! I can't take credit for the miles. The previous owner was the original purchaser and just had Grease Monkey perform routine maint. I picked it up with 346K on the clock and it needed a lot of help.
    This is what it looked like the day I picked it up.
    [​IMG]2020-11-19_02-45-42 by GhostCreekMine, on Flickr
    Now...
    [​IMG]2021-02-17_06-11-58 by GhostCreekMine, on Flickr
    alb1k, RUSTYNUTS, Beefnbread and 10 others like this.
  29. Apr 18, 2021 at 5:22 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Washed the truck today. Then took it on the highway to dry it off.
    Got my insurance bills the other day. Same coverage, the Tundra costs $30/year more than the 1 year older Tacoma. Huh. Tundra is so much bigger & heavier.
    Jack McCarthy likes this.
  30. Apr 18, 2021 at 5:31 PM
    Tell me about it. My insurance has been the same with full collision and comprehensive since 2008-2009. I think with the Tacoma (if it’s newer) it’s all the extra safety features that bring down the cost.
    NUDRAT[QUOTED] likes this.
