Shimmy on braking
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Apr 12, 2021.
  1. Apr 12, 2021 at 9:22 PM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I had this for a while. I replaced the rotors and new pads. That fixed it.
    Now it’s shimmy on braking again. Bought (I thought decent rotors)
    Is it something else? Truck has 90K total miles.
  2. Apr 12, 2021 at 11:54 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Sounds like rotors
    Elduder and GNTundra like this.
  3. Apr 13, 2021 at 6:52 AM
    Tmd_mn
    Tmd_mn New Member
    Did you check the caliper to ensure they were not "sticking" any where? Guide pins? This can cause uneven pressure and cause issues.
    In addition did you torque your wheels evenly, heard this could cause the rotors to warp prematurely.
    tvpierce, Tundratoofun and Glock 40 like this.
  4. Apr 13, 2021 at 9:39 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    Ok,
    Should I be looking at Lower Ball joints for replacement also with this mileage?
    I tow a few times. Usually just getting a riding mower. Nothing heavy.
    Glock 40 likes this.
  5. Apr 13, 2021 at 9:42 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Always keep an eye on those lowers. These trucks eat em up, especially if aftermarket.
  6. Apr 13, 2021 at 12:37 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    Check the calipers I just had to replace everything on my truck because the calipers were hanging once they got hot truck shook like hell.
  7. Apr 13, 2021 at 2:16 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    How do I check Lower Ball joints?
    If they need replacing, what brand should I use?
  8. Apr 13, 2021 at 5:55 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Toyota lower ball joints are best. At 90k miles I would replace for peace of mind if they are the originals... but that’s just me who’s afraid of early 2000 Toyota LBJ as I had a wheel fall off my Lexus GS300 once.
  9. Apr 16, 2021 at 5:33 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I looked up my purchase. It was R1 concepts brake rotors.
    5 stars. All Tundra drivers. No idea why mine suck.
    BTW Lower Ball joint was replaced via recall
  10. Apr 17, 2021 at 4:17 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Your rotors don’t necessarily suck.
    Have you checked calipers as @GavinG83 suggested?
    Has the brake fluid ever been flushed?
    If the calipers are sticking, even the best rotors will get hot and warp.
  11. Apr 17, 2021 at 5:41 AM
    Like others said, I'd replace the calipers. I went with this kit from rockauto.
    Note that if you get this kit on a 13we truck, you have to trim the dust shield a tad.
  12. Apr 17, 2021 at 9:21 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    When I did the brakes, I checked the calipers out and checked and lubed the guide pins.I will pull the tire and check for something askew.
