Camburg UCAs (2020 Tundra)
Discussion in 'Suspension' started by Ckatz53, Dec 24, 2019.
  1. Dec 24, 2019 at 8:01 AM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    www.fouroneodetailing.com
    Was going to go with JBA UCAs from a positive prior experience coming from the Jeep world. However, these popped up on Facebook marketplace today. The guy installed and then removed and is now selling for a price of $800 (New from Camburg website is ~$1400).
    Link for Camburg UCAs: https://camburg.com/shop/suspension...wd4wd-07-20-kinetik-series-billet-upper-arms/
    Here's the reasoning they were removed from this guys truck verbatim:
    "Like new. Installed but didn’t fit my 2016 tundra because of my 5 inch Zone off-road lift kit. Was uninstalled without being driven. I found out after I bought it that any arm designed for a 3" kit will not be good for a cross member lift kit which is what I have. as they are designed for stock upper arm ball joint locations. All of the 3" arms add caster and are shorter to compensate for camber change at that height. So if you want this you need a 3 inch or smaller lift kit."
    Anyone run them and have any experience? Even at the listed FB price they're still almost double the price of JBAs. Just looking for experience from folks with 3" lifts with Camburgs. Currently deciding between the Boss4x4 Radflo 2.5 and Toytec Aluma 2.5 lifts, both giving 3".
  2. Dec 24, 2019 at 8:12 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I've been running the SPC UCAs and I love them. Gained a lot of travel, very serviceable, fixed my alignment issues, and the ball joints are easily replaced.
    I only mention these because they are close to the price of the JBAs
    AggiePhil likes this.
  3. Dec 24, 2019 at 8:13 AM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Yeah I've heard of them just never ran them. Just curious on the Camburgs if their insanely higher retail price translates to a superior UCA or not.
    Rica25 and Mwray8909[QUOTED] like this.
  4. Dec 24, 2019 at 8:18 AM
    Mwray8909
    Chino Valley
    I've done suspension on dozens of Toyotas.
    The most common UCAs I install in order are the Icon (billet or Tubular), then the SPC, then total chaos, then camburg.
    Rica25 and Ckatz53[QUOTED][OP] like this.
  5. Dec 24, 2019 at 7:19 PM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    They are insanely expensive because they are Billet Aluminum.
    Rica25, 14burrito and snivilous like this.
  6. Dec 24, 2019 at 7:27 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I'd get new camburg ball joint arms. All the benefits without the annoyance of a uniball squeaking away when it gets dirty, plus are like $600 new.
    tundra_20, Bakelite and Rica25 like this.
  7. Dec 24, 2019 at 7:35 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    dont listen to these guys, those camburg are great and will work fine for what you got. you cant go wrong with camburgs.
  8. Dec 24, 2019 at 7:44 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Where you live, go with SPC. Uniball’s are not good in winter climates. Salt and brine eat away at them causing premature squeaking. That’s what a few mechanics told me. I had SPC’s on my 2018 and they worked great.
    AggiePhil, Rica25 and Mwray8909 like this.
  9. Dec 24, 2019 at 8:55 PM
    Mwray8909
    Chino Valley
    I'm not saying camburg is in any way bad. I'm giving my experience.
    There are times that having a sealed balljoint vs an open uniball can be the wrong choice such as environment, use or even budget.
    I'm also not trying to discredit anyone because I don't know what experience others may have.
  10. Dec 26, 2019 at 4:50 PM
    Carlos@Camburg
    Carlos@Camburg Carlos @ Camburg Vendor
    Carlos
    Huntington Beach
    2015 Tundra DC
    Camburg UCA Bilstein 6112 KMC Wheels General Tires Rigid Lights
    $800.00 for a set of billet arms is a killer deal.
    agunday21, drobb, Voyagermike and 2 others like this.
  11. Dec 27, 2019 at 7:47 AM
    GreyMatter_4x4
    GreyMatter_4x4 New Member
    Randy
    2020 CrewMax SR5 4x4
    Anything from Camburg is great!!! Those UCA's are badass.
    Ckatz53[OP] likes this.
  12. Dec 27, 2019 at 8:25 AM
    Midway
    Midway New Member
    I love mine! I just make sure to keep them clean and maintained.
  13. Dec 27, 2019 at 8:31 AM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Looks great but with Maryland winters, I was afraid they'd need too much maintenance. Winters arent that bad, except road crews throw 1400 tons of salt on the road at the earliest sign of precipitation and I didnt want to deal with that.
  14. Dec 27, 2019 at 8:35 AM
    Midway
    Midway New Member
    Totally understand that., Salt is a pain to keep off. However, that deal is insane. $800 for Camberg Billet uppers, someone will scoop those up!
  15. Dec 27, 2019 at 8:41 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    I have a a set of tubular camburg uniball UCAs on my truck. Had them for about 4 years with 40k miles. I Do about 4-5 snow trips a year. Never had an issue with noise/corrosion. Just make sure you maintain them.
    831Tun, Carlos@Camburg and Midway like this.
  16. Dec 27, 2019 at 8:45 AM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Yeah. He was nice enough to hold my "spot" while others were interested but I had to pass. I've ran JBA on my jeeps for a decade with no issues and easy ball replacement. Going to just run them again.
  17. Dec 27, 2019 at 8:46 AM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Yeah no doubt they're great. I just wouldnt want to get them and these roadways tear them up in the winter unnecessarily. Someone else can enjoy them and I'm okay with that :)
  18. Dec 27, 2019 at 8:47 AM
    Midway
    Midway New Member
    :thumbsup:
    Ckatz53[QUOTED][OP] likes this.
  19. Dec 27, 2019 at 1:35 PM
    WestexSBK
    Give me the contact info. I’ll buy them for $800!
  20. Dec 27, 2019 at 1:36 PM
    Carlos@Camburg
    Carlos
    Huntington Beach
    2015 Tundra DC
    haha I was thinking the same thing!
  21. Dec 27, 2019 at 2:36 PM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Hah theyve been sold
  22. Apr 15, 2021 at 6:23 PM
    a_double
    a_double New Member
    Hi,
    I have the Camburg Billet UCAs but don't plan an extreme lift, only 1, maybe 2". At 1-2", would these arms add too much caster, resulting in higher chance for needing a BMC?
    Thank you.
  23. Apr 15, 2021 at 8:10 PM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    It’s a double edge sword. You’ll most likely clear the body mount, but rub on the front fender at full lock or near full lock. The uca’s will get you anywhere from 4* to 6* castor. Positive castor moves the axle forward.
    The wheel offset/ backspacing and width will determine fitment rather than lift height.
  24. Apr 15, 2021 at 9:04 PM
    a_double
    a_double New Member
    Thanks! My wheels specs are 18x9.5 +20 and deciding between 305/65, 295/70, 33x12.5 and a modest lift. I don't want to chop and would like to retain my mud guard. I don't mind removing the front guard and pushing plastic forward though.
