Transmission clunking sound
Discussion in '1st Gen Tundras (2000-2006)' started by Noely1130, Feb 28, 2020.
  1. Feb 28, 2020 at 11:43 AM
    Noely1130
    Noely1130 [OP] New Member
    2005 Tundra SR5
    2005 Tundra SR5, 2WD, V8 Auto tranny. Sometimes when I release the brakes after a full stop, I hear a clunking sound - feel it in the seat. The other day while stopped at a light, in gear, with foot on brakes, I heard a loud clunk. What the hell is going on?!
  2. Feb 28, 2020 at 11:55 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Sounds like the driveshaft slip joint is sticking and needs greasing.
  3. Feb 28, 2020 at 12:50 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Could be your shaft zerks need greasing OR another problem may exist.
    The 05-06 transmission bolts for 2wd trucks were subject to fall off. There should be 4 bolts connected to the crossmember. The missing bolts cause a clunking sound.
    onesojourner and FrenchToasty like this.
  4. Feb 28, 2020 at 1:46 PM
    Noely1130
    2005 Tundra SR5
    All 4 bolts are in place, and I checked the carrier bearing between the 2 sections of drive shaft, and found no grease nipple. Where is the "slip joint" and or "zerks" ?
  5. Feb 28, 2020 at 2:10 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    If you have a 2 wheel drive,you won’t have grease fittings for your slip yoke
    You’ll have to drop the driveshaft,clean and lube the splines and reinstall
    On my 06, I had the exact same symptoms for quite a while.
    Over time I did the following:
    Inspected leaf spring silencer pads
    Inspected axle u bolt torque specs
    Inspected carrier bearing and u joints
    Inspected transmission mount and bolts
    Inspected parking brake and rear drums
    Had a shop install new carrier bearing and i joints,plus lube yoke
    I did all of the above and it was still present.
    Finally one day I did a transmission drain and fill. I added about a 1/2 quart extra fluid,as someone else on the forum suggested it cured theirs.
    It never happened again. The slip yoke internals are kept lubed by ATF. If you’re a touch low,or even dead on, you can exhibit the symptoms you describe. The “driveshaft clunk” you feel is the slip yoke moving.
  6. Feb 28, 2020 at 4:43 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Our transmissions are "sealed" so it's a little more complicated than usual....especially checking the fluid level....great tutorial here...
  7. Feb 29, 2020 at 11:08 AM
    Noely1130
    2005 Tundra SR5
    Hmmm. Think I'll let the Toyota shop do the drain and fill.:thumbsup:
  8. Apr 15, 2021 at 5:46 AM
    KreamDC
    KreamDC New Member
    2006 Tundra DC Limited 4wd
    Did a transmission drain and fill hoping to fix my clunk issues but it still exists :( - although I think it's better / less frequent. Next I guess I'll have the driftshaft / slip yoke checked
  9. Apr 15, 2021 at 6:30 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
  10. Apr 15, 2021 at 6:32 PM
    SouthWestGA
    Check that you have a good center carrier bearing, good u joints,and greased slip joint. Check your leaf springs for missing silencer pads on the end of the bends,and check your spring pack/axle mount u bolts to be torqued properly
    As a last resort if you have inspected everything else,add an additional 1/2-1qt transmission fluid and see what happens. This is what made mine quit
