2007 Tundra - P0705 Error Code
Discussion in 'General Tundra Discussion' started by kenc68, Dec 6, 2018.
  1. Dec 6, 2018 at 7:36 PM
    kenc68
    kenc68 [OP] New Member
    I know this can be caused by a variety of things. I see a fair number of references to a blown fuse. Where's the fuse located? Thank you.
  2. Dec 6, 2018 at 8:04 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The fuses you want to check are under the dash on the far driver’s side. You’ll want to check the 10A BK/UP LP, the 7.5A ACC, and the 7.5A LH-IG fuses.
    Are your back-up lights working when you shift to reverse?
  3. Dec 6, 2018 at 8:31 PM
    kenc68
    Just checked, no, they aren't working. Too dark to check the fuses but will do it in the AM. Also got C1201 and C1247 error codes.
  4. Apr 15, 2021 at 4:52 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    has your problem happened again? I've had my BK/UP LP fuse go out twice now. once last month an once this month both ironically on the 15th first time I was going into reverse an my lights went out then my dash lit up like a Xmas tree , PRND (out) engine light (solid) VSC and 4lo flashing throw codes PO705 PO456 C1201 replaced the fuse an today going into reverse it did it again reverse lights went out PRND went out but 0 codes or lights.
