Kenwood head unit not dimming at night [SOLVED]
Discussion in 'Audio & Video' started by BrakeDust, Apr 14, 2021.
  1. Apr 14, 2021 at 7:42 PM
    BrakeDust
    BrakeDust [OP] New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Got my DMX1057XR install completed today! Everything works... except dimming at night (of course.)
    Anyone seen this before? Of course I can open it all up again and examine the harness but I'm 99.9% sure it's wired correctly.
    Thanks
    Reference, Orange wire pair
  2. Apr 14, 2021 at 7:51 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Lol you need a megathread for your stereo install...
    But you’ll either need to pull out the HU and verify the wiring, or check your settings for dimmer-related options. @1lowlife will probably know since he’s got a Kenwood and is really helpful for audio stuff.
  3. Apr 14, 2021 at 8:16 PM
    BrakeDust
    Hill Country, TX
    Ok I figured it out! (No need to pull the HU) There was a Reddit thread that explains the Kenwood thinking behind the dimmer control. Rather than taking a queue from the dash light sensor Toyota provided Kenwood looks merely at the headlight status. Lights off, screen bright; lights on, screen dim.
    By default of course both night & day brightness are the same - for whatever reason.
    The recipe:
    - Set dimmer control to SYNC
    - Turn on the lights
    - Press the volume control button (it doubles as a context-sensitive Menu button)
    - A strip of icons will appears, the far left is the brightness control
    - Set your desired screen brightness, ie. how Dim you want the display to be
    - Press back
    Now turn your lights off. You should see the display get back to full brightness. Turn lights on, it should dim.
    Done!
  4. Apr 15, 2021 at 12:06 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Dammit, I need to try this on my DMX906S.
    My HU dims down with the lights on, but nearly enough.
    There is a setting that will dim it up or down 4 settings, but it's really bright at night even dimmed down.
    I'll see if that works.
    But you've got fancy big HU, it probably has more options for lighting.:eek2::thumbsup:
    That's one thing Pioneer exceeds at on HUs is screen control.
    Colors, dimness, ease of adding your own startup screen, etc...
  5. Apr 15, 2021 at 4:34 AM
    BrakeDust
    Hill Country, TX
    Yeah the DMX1057 might be fancy but it's not very customizable. Want a clock on your screen? Sure you can have one but the only choice is a large analog model that looks like my dad's old skool alarm clock :rolleyes: Can't shrink it, change the face, pick a digital model, no options whatsoever.
    nags and 1lowlife[QUOTED] like this.
  6. Dec 19, 2021 at 1:13 PM
    liddown
    liddown New Member
    You have been moved to hero status! I have the DNR1007XR and this worked GREAT! Nothing in the manual about this, nor the other hidden option for controlling Nav and CarPlay / Google Maps volume balance....
    Thank You!
  7. Jan 27, 2023 at 3:18 AM
    nags
    nags New Member
    Anyone ever figure out a way to turn off the clock that's always on the bottom right while displaying videos? I can't find a setting anywhere.
  8. Feb 12, 2023 at 9:18 AM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    Glad you figured this out, I sure couldn't. Just what I needed. Thanks
  9. Dec 9, 2024 at 11:45 AM
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 BktSeats
    Thread Revival for my Kenwood HU shopping knowledge.
    Sort of related to the topic:
    Can a manual over-ride switch [SP-ST type rocker] be installed to Disable the HEADLIGHT trigger.?
    IE: I dont want to have to turn headlights ON or OFF to DIM or Brighten HU Display; to me more convenient to have control switch over triggers like 'Reverse DIM', etc...
    Seems like one of 'Big 5' has a dedicated or assignable shortcut [long press button] to turn DIM ON or OFF, no matter what headlights or Reverse, etc?
  10. Jan 8, 2025 at 8:34 PM
    ps8820
    ps8820 New Member
    joe
    Its a few years now...wonder how you like the KW now?
    I see it was a few menus to navigate to end up w/ 2 levels of Brightness, based on Lights ON or OFF. I guess Im trying to find a HU that lets me decide how BRIGHT and WHEN; and it should only be a single LONG PRESS key to scroll betwn the 2 levels [or however many the end user wants programmed].
    This shouldnt be a heavy lift for these companies, especially not at the +$1K level.
  11. Feb 8, 2025 at 8:11 PM
    20manny1996
    20manny1996 New Member
    Manuel (Manny)
    2017 Limited Super White CrewMax
    Dude!!! I apologize for reviving this old thread, but thank you so much for posting this! I have the exact same HU & I always wondered if the screen could be darker when the headlights were on, & I just happen to stumble into this thread. Legendary!
