2nd gen Switchback headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by Shanet421, Apr 14, 2021.
  1. Apr 14, 2021 at 10:08 AM
    Shanet421
    Shanet421 [OP] (Semi) New Member
    San Diego,CA
    Spec-D Tuning Black LED Sequential Projector Headlights Signal for 2007-2013 Toyota Tundra Sequoia Head Light Assembly Left + Right Pair https://www.amazon.com/dp/B081FL2FSF/ref=cm_sw_r_cp_api_glt_fabc_JD5MB3T417Y82HPMAE3B
    Have any of you guys tried these out? I’m looking for a decent set thats budget friendly. Can’t find any reviews for these anywhere
    Thanks!
  2. Apr 14, 2021 at 10:13 AM
    2turbz
    2turbz New Member
    2011 Tundra Trd 4x4
    They look nice. From experience lighting is a definite "get what you pay for" situation though. Hopefully another member has tried them.
    TheBeast likes this.
  3. Apr 14, 2021 at 12:52 PM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    I have them. Not bad. My wife got them for me for Christmas, not realizing I wanted the Morimoto XB LED Headlights. I would upgrade the bulbs they come with. I didn't go led but just put some better ones in and they work fine. Realize they are cheap, and I would get some lens protectors for them. They help them from yellowing out and protect the cheap lens from rocks.
  4. Apr 14, 2021 at 2:13 PM
    Shanet421
    San Diego,CA
    Ya I want the Morimotos also but I can’t spend 1k. If you get a chance can you post a few photos of them installed on your rig? Was this last x-mas?
  5. Apr 14, 2021 at 2:54 PM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
  6. Apr 14, 2021 at 3:17 PM
    If you are setting Alpharex, get the Pros. The regular ones are junk.
  7. Apr 14, 2021 at 6:43 PM
    Shanet421
    San Diego,CA
    AlphaRex PRO-Series For 07-13 Tundra/08-17 Sequoia Alpha-Black TRD-PRO look Projector Headlights Left/Right Replacement Assembly with Activation Light With Level adjuster https://www.amazon.com/dp/B08ML88SZ6/ref=cm_sw_r_cp_api_glt_fabc_C4FRQDS6MJ471FBBFEJA
    I do see these as an option now. They do have the level adjuster which is a nice feature. Like the look of the Spec-D better still
  8. Apr 15, 2021 at 5:37 AM
    MXPCUS
    MXPCUS New Member
    Ken
    Southern IL
    2007 Tundra SR5
    Push bar and bed rails
    Those look cool AF
  9. Apr 15, 2021 at 10:06 AM
    idiggplants
    idiggplants New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    whats the term for these new style lights with the drl that are the lines and zig zags?
    im guessing this will be an unpopular opinion but i feel like they are going to quickly go the same way as the halo lights of 5-10 years ago. they started on the high end cars and looked decent, and then showed up on some mid range cars, but they quickly became available as aftermarket options on vehicles they didnt come stock on, at which point they became tacky and dated on even vehicles that they came stock on. at first i liked them but now as i see more and more, they are already starting to look like a fad. JMHO and no offense meant..
  10. Apr 15, 2021 at 5:41 PM
    Shanet421
    San Diego,CA
    Hold onto things when you pull em off.
    My guess is most of these aftermarket headlights will only last 5 years if your lucky and get a decent set
