Tundra Common Problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by Saltyhero13, Apr 8, 2021.
  1. Apr 8, 2021 at 9:27 PM
    Saltyhero13
    Saltyhero13 [OP] Throbbing Member
  2. Apr 9, 2021 at 6:44 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Very informative....thanks.
    SPP
    Saltyhero13[OP] likes this.
  3. Apr 14, 2021 at 7:10 AM
    AverageJoe
    AverageJoe New Member
    DFW TX
    21 DC SR 4WD
    Saltyhero13, looking to buy my first Tundra and this was much appreciated
  4. Apr 14, 2021 at 7:41 AM
    bwh
    bwh New Member
    Is there a TL;DR for a 30 min video?
    Cpl_Punishment and FadeToBlack22 like this.
  5. Apr 14, 2021 at 7:47 AM
    Saltyhero13
    Well hopefully we didn't scare you away!
    If you look at the forums most people here are complaining about radios, MPGs and Trans Coolers on 2019+. One of our members sells a kit made of mostly OEM pars to fix this last issue.
    Kywildman likes this.
  6. Apr 14, 2021 at 7:48 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    The biggest problem with Tundras is people buying them without doing research and then complaining because it doesn’t have this or it does that.
  7. Apr 14, 2021 at 7:49 AM
    Saltyhero13
    I play it at double speed to cut it down to 15.
    From the video description:
    1- Engine Category: The Tundra came with many engine options including the 1GR-FE 4.0L V6 the 2UZ-FE 4.7L V8 and the 4.6 and 5.7 UR-FE engines. Most notable issue on the 5.7 is the broken valve springs and the leaking cam towers. 2- Transmission and 4WD : The transmission is relatively problem free however many have voiced their concerns over the lack of an external transmission cooler which is addressed in this video. 3- Chassis : I address common brake issues including the scraping noise from the rear brakes. 4- Electrical issues including radio issues and issues with aftermarket remote starters. 5- I cover common issues with the frame rusting on this model tundra. 6- I also go over the best year to buy recommendations.
  8. Apr 14, 2021 at 7:50 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    buy 2010 and up, check for cam tower leaks before you buy, don't worry about the missing transmission cooler, make sure the tranny has been serviced every 50K Mi.
    Enjoy.
  9. Apr 14, 2021 at 9:02 AM
    AverageJoe
    DFW TX
    21 DC SR 4WD
    [sarcasm]A $2K shop repair bill :) [/sarcasm]
    Absolutely not. Did a bunch of reading on forums for multiple brands and Toyota forums are pretty quiet as to issues what I'd consider serious issues in relation to other makes. Just want to prevent buying that one lemon that is floating around at dealerships/CL and becoming "that guy" so this was great timing.
    I'd say that video would merit being placed in sticky threads for the 2nd and 3rd gens but I'm new here and the mods on this forum can better discern that need.
  10. Apr 14, 2021 at 9:11 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    I love this guy. He is right on the points and honest.
  11. Apr 14, 2021 at 9:55 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    @Saltyhero13
    Is there a remedy for the brake scraping. I went up yonder search bar and one attempt yielded 0.0% efficacy.
    You have been set to task, sir. Deliver a spectacular result as I've come to expect from you.
  12. Apr 14, 2021 at 10:46 AM
    Saltyhero13
    Brake removal is the recommended action. This also requires the "Flintstone" floor panel mod.
    Ceramic slippers when towing or toeing.
  13. Apr 14, 2021 at 11:53 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Is it the pads dragging on the rotor or the rotor contacting the splash shield?
  14. Apr 14, 2021 at 5:34 PM
    eagleguy
    eagleguy New Member
    That was an excellent video!
  15. Apr 19, 2021 at 6:00 PM
    offroad_yoyo
    offroad_yoyo New Member
    Kyle
    2020 White 4x4 SR
    Why on earth are there conversations of the Tundra not being a “real” truck? I’m not yet fluent in all the brand rivalries.
  16. Apr 19, 2021 at 6:55 PM
    Did he talk about the front differential needle bearing going out? I may have missed it since I was getting ready to go out.
    Good video, but it made the Tundra sound like a total POS, which it definitely is not.
