Broken Sway Bar
Discussion in '1st Gen Tundras (2000-2006)' started by Ray21125150, Apr 12, 2021.
  1. Apr 12, 2021 at 12:17 PM
    Ray21125150
    Ray21125150 [OP] New Member
    I have an ‘04 Tundra that I purchased last June. Took it to Toyota for an inspection and found out that the Sway Bar broke off from the frame. Dealer said I shouldn’t drive the truck. Is this truck salvageable or am I looking at at loss here. Thanks
  2. Apr 12, 2021 at 12:21 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Unfortunately it sounds like you have some frame damage due to rust. There's lots of good info in this thread about frame replacements. Maybe check with your dealer to see if your truck is a candidate for frame replacement.
  3. Apr 12, 2021 at 4:22 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Have a pic of what’s broken?
  4. Apr 12, 2021 at 4:25 PM
    Captain Tenneal
    Captain Tenneal New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
    Depends what's broken. If only the bushing mounts or links are broken, it's "driveable" if you remove the sway bar. If it's rusty attachment points, it's a different story. We need to see pics.
    Voss likes this.
  5. Apr 12, 2021 at 4:25 PM
    You can drive all day without a sway bar, but if rust is eating the frame, that might be a concern
    Voss likes this.
