  1. Apr 10, 2021 at 5:07 PM
    #6061
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Yup! That’s one of 20ish crawl space / foundation vents. It’s drying out a bit at this stage but it’s still very soft and squishy even right up against the foundation. For sure a problem. Will have to continue to monitor because if this happens every time my neighbor waters his grass or it rains, then totally not acceptable. I don’t expect the hear from warranty rep till Monday. They will need to address this somehow.
    6891DDCA-7399-4013-AA42-289BA6468019.jpg 39427C36-8B81-4F7A-80F0-22259D607887.jpg BAF1FA0A-3297-45F1-A693-D692376DA9E2.jpg F6E69B4C-F82B-43AC-BD47-A8BF37A48B92.jpg
    On the plus side....I got the fire pit table put in place
  2. Apr 10, 2021 at 5:13 PM
    #6062
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Man, you don’t want that crap soup building up under the house. I’d definitely hold your ground with the builder. Groundwork is not my strong suit but I’d image a drain or retaining wall like you said would help mitigate things.
    kparrow[QUOTED] likes this.
  3. Apr 10, 2021 at 5:48 PM
    #6063
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    A few things strike me as odd...
    the biggest one is that you should have foundation walls down below frost level (at 3-4’ in ID) and the exterior of those walls should have perf pipe and river rock (french drain) to collect water away from the foundation, which should be routed to some sort of diversion or swale or storm sewer to prevent water from collecting against the foundation.
    The second is that your backfill is so close to the bottom of your siding and crawl space vents. Normally you want 6” clear or to the bottom of the vents to prevent water damage to your siding/trim from splatter or standing water.
    and third is where the hell is that much water coming from? Unless your neighbor’s soil is solid hard pan (and yours too) and he still chooses to run his sprinklers for hours or you had several inches of rain in the last day, you shouldn’t be seeing ponding like that anyway.
  4. Apr 10, 2021 at 5:57 PM
    #6064
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Really neglected yard clean-up last Fall, now its time to pay the piper. :annoyed: My piece of sh*t Ryobi leaf blower has been dripping gas for the last few years, really hasn't bothered me that much. Today I came in and the wife smelled gas and saw a wet spot on my back, and insisted I go out and buy a new blower because it was too dangerous. :rofl: Picked up this nice Echo today, and wow what a huge difference in power V/S the Ryobi. Highly recommend if you're in the market.
    GODZILLA, Fotnot, CodyP and 5 others like this.
  5. Apr 10, 2021 at 6:19 PM
    #6065
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Went to Living Spaces and bought/ordered an L-shape sectional couch. Reclining seats with headrest adjustment, all powered of course. Got a coffee table and throw rug with it too. There goes the tax return.
    TaquitoBandito and ToyoMafia like this.
  6. Apr 10, 2021 at 7:05 PM
    #6066
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I honestly have no idea if there is perf pipe but I highly doubt it. The soil is clay and gets very sticky and soupy when wet. I agree the backfill seems a bit high but all the houses here are like that so idk what to do about that. Lastly, I agree where the hell did all that water come from, particularly that high up the slope of the hill too! It has been completely dry since I moved in with the exception of the one day of rain we had and it dissipated within 1 day. It has not rained in over a week. I have been watering but just twice a day by hand with a hose since irrigation is not turned on yet. Enough water to get the ground under the sod moist but no more than that. The front yard and all other areas of the yard are perfect! So yes, this amount of water “out of nowhere” is very concerning to me and so I’ve filed a formal warranty claim with the builder and sent the rep all of these pictures and videos illustrating the softness. I sunk down 3-4”. Also the walls of the foundation do go down about 4+ feet from what I can tell from all the other poured foundations going in down the street
  7. Apr 10, 2021 at 7:11 PM
    #6067
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Nice!!!!
  8. Apr 10, 2021 at 7:12 PM
    #6068
    RainMan_PNW
    Casey
    Clark County, WA
    Is it possible they just turned it on and the system has a massive leak?
    clay soil is brutal and makes drainage and sloping much more critical. Once you get down about 6” below surface at my house it’s solid red clay so I feel your pain there. Good sloping away from the foundation, good drainage at the bottom of the foundation, and some well thought out French drains are the only defense.
  9. Apr 10, 2021 at 7:31 PM
    #6069
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Yeah, I don’t think the drainage is up to par and so I’m going to push for French drain heavily for sure. Irrigation on my property is for sure not on yet though, made sure to check that first. Sprinkler controller is off, as is the ball valve at the street to supply the system. Thanks for mentioning to check though for sure! I knew from the second I saw the back of the house and the “trough” they created that it was gonna hold water but of course they wouldn’t listen until there was a problem and now it’s going to be warranty’s problem. I would have addressed it during the build but I bought it as a spec house that was almost done. Didn’t get to pick anything or make sure things were included in contract to address this kind of stuff to prevent the problem. Cause of this....they’ve thrown it on their warranty department to rectify something that should have been preventable and that honestly irks me a lot. Trying to still be nice and not jump to full a-hole mode
  10. Apr 10, 2021 at 8:35 PM
    #6070
    TaquitoBandito
    Joel (AKA Bif)
    When we had a Pulte home, I always started with the "I know it's not your fault because you weren't the supervisor /worker/whatever but..." and then proceeded to talk shit about whatever thing they screwed up. Then I get mean if they don't give me what I want. Those warranty people/customer liaisons rarely get anybody calling to compliment them on the build quality of their homes.
  11. Apr 10, 2021 at 8:38 PM
    #6071
    TaquitoBandito
    Joel (AKA Bif)
    I've learned that it's best to lift with your legs, not your back and if all else fails, just blame it on the dog.
    kparrow and ToyoMafia[QUOTED] like this.
  12. Apr 10, 2021 at 8:38 PM
    #6072
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    “Fuhking dog”
  13. Apr 10, 2021 at 8:39 PM
    #6073
    TaquitoBandito
    Joel (AKA Bif)
    and "ewwwwwwwwwwwwww, what the hell did he eat?!"
    ToyoMafia[QUOTED] likes this.
  14. Apr 10, 2021 at 9:06 PM
    #6074
    ToyoMafia
    Magic carpet.
    So the master bathroom is getting close to being finished. Tile guys need to finish the shower next week then doors. We still need to find the right lights and mirrors. 204BA639-12AE-48A0-A0C7-62F33DCBCAB6.jpg
    The Dude, JH5370, Fotnot and 12 others like this.
  15. Apr 11, 2021 at 6:48 AM
    #6075
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Sorry to hear about your recent water drainage or leak problems. Here are a few things I would start with first.
    I would make sure everything inside the house is turned off and go take a look at your water meter. Make sure your water meter isn’t rotating or moving. If the meter is still moving, this can indicate you have a leak somewhere.
    Do you have any irrigation lines that run in that area? I doubt this is the issue but I would still double check.
    I like seeing that the builder put drains from your downspouts to divert the rain water. The question I have is, where did they run the drain lines to?
    Sometimes seeing a site from an aerial prospective can also answer a lot more unknown indicators. I’m wondering how the grades and flow lines for drainage are flowing from your neighbors properties. We can’t tell how the grades are flowing behind your fence line. I would take a laser level and shoot some grade marks from the bottom of your fence to the side of your house. This will give you a reference of how much slop from the fence to the foundation you have or may not have. You can also run a string line from one side to the other. I would prefer to see this area with a slight low spot in the mid point of the fence and house. This will help water flow between the fence and house. I believe you mentioned you have clay in your area. If you do have clay and a weed barrier down this may also be causing an issue. All though weed barrier is made to allow water to pass through it sometimes weed barrier will slow the drainage process down if it’s get clogged from dirt or bad soil conditions below the weed barrier.
    Next time your ground is wet like this I would do some investigational digging test with a shovel. I would start checking the gravel next to the fence line and the house to see where the water is coming from. This may help you determine the source of the water.
    have you asked your neighbor if they were using their irrigation on their lawn?
    Hopefully this information helps you find the source of the issue.
    70A21BA5-1F49-4BE2-8ECA-F1D7F52FFFBA.jpg 9777AC45-5C70-4673-8C2A-830CD7356D41.jpg C0654C84-F5B2-4C8E-844D-A3E00D5B3CA1.jpg
  16. Apr 11, 2021 at 9:40 AM
    #6076
    Wahayes
    Will
    2017 tundra limited *sold*
    Decided to install french drains for gutter runoff
    After install (not the same one obviously but you get the idea
  17. Apr 11, 2021 at 2:29 PM
    #6077
    Hung up the paddle board. Wife has been asking for one since last year so I caved. This has been an expensive year. #YOLO
  18. Apr 11, 2021 at 2:47 PM
    #6078
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Wow, I really dig the tiled walls. :thumbsup:
    AZTundra likes this.
  19. Apr 11, 2021 at 5:28 PM
    #6079
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    Finally got around to hanging one of the wife's Christmas presents lol. I'm not a woodworker by any means, but it turned out pretty good. Used hurricane joists and tack plates so I really don't think it's going anywhere. 8" lags through the 4x4s and lags / SDS screws for all the other hardware. Kinda overbuilt...like everything I do when I have no real clue what I'm doing.
  20. Apr 12, 2021 at 8:22 AM
    #6080
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Replaced the front storm door. The old one was very heavy and falling apart. Plus, I’m not a fan of wrought iron over doors or windows. Gives off a pawn shop vibe.
    Old door and frame:
    New door (Andersen with the self-storing pull-down screen). It looks so much better. I still need to tidy up the trim around the frame and fill in where I took the doorbell out:
  21. Apr 12, 2021 at 9:08 AM
    #6081
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Front storm door is next for me. Doesn't have one currently. Heard good things about the Larson storm door from Lowe's.
  22. Apr 12, 2021 at 9:21 AM
    #6082
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've liked the Larson ones we've had. It's worth the money to go to the all aluminum doors.
  23. Apr 12, 2021 at 9:35 AM
    #6083
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Like the other poster I went with the Anderson 3000 available at Home Depot. Has the built in screen and seems very well made!
    had to special order mine because of the color, and they didn’t screw it up either!
    -t
  24. Apr 12, 2021 at 9:46 AM
    #6084
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    We’re wrapping up a bathroom project and I just installed a fake beam on the end of a wall. I used hard maple, the same stain as the Kraftmaid vanity then polished it with wood wax.
    The Dude, Fotnot, OV-1794 and 12 others like this.
  25. Apr 12, 2021 at 10:27 AM
    #6085
    Terndrerrr
    Music City
    6UR-FE
    Agreed. This aluminum Andersen is so much lighter than the wrought iron beast I pulled off the house. The self storing screen that rolls out of the top of the door is a nice touch too.
  26. Apr 12, 2021 at 10:57 AM
    #6086
    Kung
    KG, VA
    Same. Pro tip - if you write down the model/serial # on the door when you buy it, you can pretty much build a whole new door from all the available parts you can buy for it. Our shocks on our door crapped out this last winter; a few days later I had a new one installed.
    TaquitoBandito and Terndrerrr like this.
  27. Apr 12, 2021 at 11:12 AM
    #6087
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    I love this! :thumbsup:
  28. Apr 12, 2021 at 12:13 PM
    #6088
    JohnH
    JohnH From PA
    Pennsylvania
    Thanks a lot!
  29. Apr 12, 2021 at 2:34 PM
    #6089
    Ckatz53
    Ckatz53 Newish
    MD
    Twins. Did mine a few days ago.
  30. Apr 12, 2021 at 3:05 PM
    #6090
    TaquitoBandito
    Joel (AKA Bif)
    Is that a beer I spy on the bathroom counter to the right? I also like to drink in the tub. That way I don't have to get up to pee.
    Fotnot, CodyP, Yzed608 and 4 others like this.
