1st Gen 2WD DC
Discussion in '1st Gen Builds (2000-2006)' started by alb1k, Apr 5, 2021.
  1. Apr 11, 2021 at 11:49 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    If you're just using a rag, definitely add some heat with a heatgun or hair dryer... and chemicals. Automotive grease/wax remover is mild enough not to damage the clear coat and works fairly well. Heat is the biggest help with that hardened goo though.
  2. Apr 11, 2021 at 3:43 PM
    alb1k
    alb1k [OP] Always Coming From Take Me Down
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Better, still kinda rough....
    Tundra2 likes this.
  3. Apr 11, 2021 at 5:51 PM
    alb1k
    Left Coast
    It's good
    Well, per normal, grille needs more work, looks way better in picture. And, hood release clips are toast. But all is not lost, just a set back as should be expected. Here’s a sneak peak, and the boy’s 05 4R that he’s never driven...yet.
  4. Apr 12, 2021 at 4:17 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
  5. Apr 12, 2021 at 3:39 PM
    alb1k
    Left Coast
    It's good
    I’m gonna go against the grain here and not recommend plasti-dip on the grille. But if you do, don’t primer because that will be the hard part to get off. I was not happy with the finish on the inset surfaces. The faces were fine, but my attempt to clean up those hard to reach places led to instant failure in general. And, all day getting the primer off :)
    I do have a set of new safety latch bar retainer clips, however...
    fighthedude likes this.
  6. Apr 12, 2021 at 4:25 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Since you are coating on plastic, I wouldn't recommend any primer. Instead use a good "adhesion promoter" prior to coating, no primer. I'd scuff up the surface prior then use grease/wax remover to clean before adhesion promoter.
    This is my choice for adhesion promoter: https://www.amazon.com/gp/product/B07MP1D3KZ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8
    This is my choice for bedliner but there are many good ones to choose from, has a relatively mild texture: https://www.amazon.com/Seymour-20-041-Truck-Bed-Coating/dp/B018Y3JRBC/ref=sr_1_1?crid=2ZWAAET33DGSA&dchild=1&keywords=seymour+bedliner&qid=1618269860&sprefix=seymour+bedliner%2Caps%2C275&sr=8-1
  7. Apr 12, 2021 at 9:31 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I think anytime you plastic dip a grill, it is mandatory you fuck up the first time
    FirstGenVol likes this.
  8. Apr 14, 2021 at 11:02 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Is that liner on the 4runner? It looks great! Is it pretty gritty to the touch?
  9. Apr 14, 2021 at 12:45 PM
    alb1k
    Left Coast
    It's good
    it is liner. The truck was completely trashed and repaint was cost prohibitive. I had a reference to a shop my buddy used for his 80’s blazer, so I got to see it before pulling the trigger. This stuff is like heavy orange peel. UV resistant and looks new with a pressure wash. Not for everyone to go full truck. But it worked great in this case.
    edited for a couple of pics of the 4R this am.
    Glock 40 likes this.
  10. Apr 18, 2021 at 1:14 PM
    alb1k
    Left Coast
    It's good
    Taking a break from the wild world of suspension and the such. Carpet cleaning.
  11. Apr 18, 2021 at 5:18 PM
    alb1k
    Left Coast
    It's good
    While carpet dries not fast enough, detail on the plastic.
  12. Apr 18, 2021 at 5:23 PM
    alb1k
    Left Coast
    It's good
    I’m not sure who jumped on it back in the day, but that bazooka drop in has been awesome.
    abcinv likes this.
  13. Apr 18, 2021 at 6:29 PM
    alb1k
    Left Coast
    It's good
    Didn’t like the gap so cot the tabs out until replaced or not
  14. Apr 18, 2021 at 6:47 PM
    alb1k
    Left Coast
    It's good
    Let’s see what happens....
  15. Apr 18, 2021 at 7:01 PM
    alb1k
    Left Coast
    It's good
    I would get both. The CG Plastic Restorer is bulletproof on the exterior. Like a wax but not. The CG super cleaner is just that. Super good.
  16. Apr 18, 2021 at 9:34 PM
    alb1k
    Left Coast
    It's good
    Maybe and likely out of production, but this sub plug and play is an awesome addition to JBL setups.
    RustyShackle323 and abcinv like this.
  17. Apr 19, 2021 at 9:11 AM
    rock climber
    Still loving this thread!
    How hard was it to get the carpet clean? My Sequoia is pretty bad and I'm debating just replacing it.
  18. Apr 19, 2021 at 12:14 PM
    alb1k
    Left Coast
    It's good
    With carpet cleaner soap and a pressure washer, maybe 90% good for 16yrs old. It's not new, but seems that way because it was bad before. Lots of brown water running down the drive at first. Definitely worth it if you have access to a pressure washer.
  19. Apr 19, 2021 at 3:05 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Your first gen is cleaner than my 3rd gen! Great work
    toyofan87 and alb1k[OP] like this.
  20. Apr 20, 2021 at 1:10 PM
    #50
    alb1k
    Left Coast
    It's good
    Thanks @300BLK. It has its little dings here and there and the tonneau cover decided to start failing with it's clear coat, but I like it.
    300BLK[QUOTED] likes this.
  21. Apr 21, 2021 at 1:13 AM
    #51
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    I too believe this is a good fit with the factory setup. Nothing to blow anyone away but updates the sound quality quiet well, more so using BT than the radio.
    Something I did to eliminate the rattle coming from the seat bottom (packing from my bed cover) -
    Wedges came with Extang packing.jpg Wedges used to stop plastic vibration.jpg
    Riverdale21 likes this.
  22. Apr 21, 2021 at 2:18 AM
    #52
    Mixb7
    Mixb7 New Member
    Napa Valley California
    2010 4x4 Tundra Platinum Crew Cab
    Bilsteins all around,110v and 12v in the bed, Rocklights, Dual Batteries, Trailer Brake Controller Mod, Lots of DIY Mods
    Really nice thread. Love what you’re doing and all the pics. Keep it coming!
    alb1k[OP] and jerryallday like this.
  23. Apr 24, 2021 at 9:27 AM
    #53
    alb1k
    Left Coast
    It's good
    I did the same thing, my foam is not as pretty, but it took care of that rattle.
    abcinv[QUOTED] likes this.
  24. Apr 25, 2021 at 8:44 AM
    #54
    alb1k
    Left Coast
    It's good
    I learned the hard way that this stuff sprays like an airless commercial sprayer, so expect a shit ton of volume and over spray and pull back.
    EDIT: don't use this shit.
    not done and half the spray is in the atmosphere, but haven’t farmed it yet...
    RustyShackle323 likes this.
  25. Apr 25, 2021 at 11:21 AM
    #55
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Not sure if you have a spare rim, but someone on offerup is selling a method 701 for $125, he wants $200 but got him down to $125
  26. Apr 25, 2021 at 11:22 AM
    #56
    flyfisher
    flyfisher Member
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    A TRD Off-Road sticker adds a lot to the look. Plus you get an extra 30 hp.264B8D23-5952-4EB6-9FAA-007BAF5E3D48.jpg
    RoninGSX, abcinv and alb1k[OP] like this.
  27. Apr 25, 2021 at 12:53 PM
    #57
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Link below, I just bought one from someone on offer up today for 125$. Two different sellers came thru.
    Check out this item on OfferUp.
    I just couldn’t spend 280$ on a rim (rim + tax) to just have it under the truck. They get trashed down there.
  28. Apr 25, 2021 at 12:59 PM
    #58
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Link to sticker? Looks good.
  29. Apr 25, 2021 at 1:12 PM
    #59
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Shit, sorry about that. I thought it was 17 inch. That what the buyer had said he was sourcing for me. I would have bought it like an idiot
  30. Apr 27, 2021 at 11:21 AM
    #60
    alb1k
    Left Coast
    It's good
    Looks like an hour to extend the OEMs if no rebuild -75. Hat: gratis.
    jerryallday and des2mtn like this.
