Techstream Help
Discussion in '2.5 Gen Tundras (2014-2021)' started by AMO_Tundra, Apr 10, 2021.
  1. Apr 10, 2021 at 5:12 PM
    AMO_Tundra
    AMO_Tundra [OP] New Member
    TJ
    Hernando, MS
    2017 Super White Tundra Crewmax
    SDHQ Dual Battery System FRAC Harness Tacoma TRD Manual Shifter Mod w/Boot Diamondback SE Cover Front Runner Bed Rack Engine Mounted ARB Compressor Raptor Grille Light Mod 3wlines Power Window Mod Color Matched Door Handles Color Matched Mirror Caps
    Hey, I’ve used the search bar and I don’t see any new threads on tech stream. I’ve got a 2017 Tundra and I want to program some keys and seat belt chime disable. I need a download for tech stream for windows 10. I can’t seem to find a reliable source or maybe I’m not downloading it correctly. I’ve got a mini cable but I don’t have the disk for it. Can anyone help me out? Thanks in advance.
  2. Apr 10, 2021 at 7:40 PM
    afrank250
    afrank250 New Member
    2021 CM 4x4
    I am in the same boat as you. Got a cable but can't get it to work.
  3. Apr 10, 2021 at 7:44 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    If you aren’t getting it from Toyota, then you’re getting pirated software. It’s against forum rules to provide links to illegal software. That being said, you could theoretically search Amazon and eBay and maybe have some luck with offerings there.
  4. Apr 11, 2021 at 7:07 AM
    AMO_Tundra
    TJ
    Hernando, MS
    It’s fine, I got it to work it programmed my key I just need to know how to program the fob
  5. Apr 11, 2021 at 7:08 AM
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    I never could get it to run on 10. I had a buddy give me an old Dell Windows 7 32bit laptop that I finally got it to run on. I do IT for a living and still had to jump through some hoops to get it to run; yes, pirated software.
    I did a quick youtube search and here's how to do it on a 2015 Tacoma. I would think it's the similar process for the tundra fob:
    https://www.youtube.com/watch?v=BYd6ayq-Ivs
  6. Apr 11, 2021 at 7:17 AM
    AMO_Tundra
    TJ
    Hernando, MS
    Lol, I watched your video last night but unfortunately that sequence doesn’t work for the tundra I have I could never get the locks to cycle.
  7. Apr 11, 2021 at 7:54 AM
    AMO_Tundra
    TJ
    Hernando, MS
    No worries, I got it figured out. Got both the key and fob programmed and it was a 4Runner key
