Transmission filter replaced or no?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rw429, Apr 4, 2021.
  1. Apr 4, 2021 at 4:08 AM
    Rw429
    Rw429 [OP] New Member
    Rob
    2017 Black Toyota Tundra SR5 Crewmax TRD Off Road
    Does anyone know if Toyota recommends that the filter be replaced or just drains and fills with new fluid, leaving the pan intact and not removing it? It’s my understanding that this filter is unlike a typical oil filter and is more like a “strainer” that catches large chunks and at that point the trans is toast anyway. This would be for newer 2017 and up models if that makes a difference. Thanks
  2. Apr 4, 2021 at 4:42 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Here's a fresh one on your desired topic. Started March 16, 2021. Caution: As with many topics, there is both wisdom and bs in this thread. You decide. At least you can read different viewpoints.
    Search will yield many other such threads, on this and other more common automotive maintenance subjects.
    https://www.tundras.com/threads/transmission-filter-change.85408/
    WILLINH likes this.
  3. Apr 4, 2021 at 4:57 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    No
    mtucker likes this.
  4. Apr 10, 2021 at 10:04 AM
    Rw429
    Rob
    Update 4/9 for anyone that is debating on a pan removal and filter change on the trans fluid. I contacted Toyota and they stated not to remove the filter, as it is a strainer and will not be contaminated unless the trans is going out or showing signs of shifting issues, in which case it would need to be removed as well as the pan for inspection. Just drain and fill needed.
    SShooterZ likes this.
  5. Apr 10, 2021 at 11:43 AM
    Black
    2014 Tundra Limited CrewMax
    I am of the idea that they are inexpensive so you may as well swap it out. Here is a nice video of likely the best process to do the job.
    https://youtu.be/cutlJH5KR2Y
  6. Apr 10, 2021 at 1:52 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Everyone said least one pan bolt will break. Don't do it.
