Engine Ticking
Discussion in '2.5 Gen Tundras (2014-2021)' started by tt18, Apr 8, 2021.
  1. Apr 8, 2021 at 12:23 PM
    tt18
    tt18 [OP] New Member
    2018 tundra ltd
    Have a 2018 Limited. Engine tick drove me crazy. Thought it was fuel injectors. Just changed my oil and used Rotella 0W20 Synthetic for gas engines. Tick is gone !!!
  2. Apr 8, 2021 at 1:07 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    i did my first oil change and went with 5w-30 synch oil. Truck sounds WAY quieter now.
  3. Apr 8, 2021 at 1:09 PM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    What oil brand and weight were you running before?
  4. Apr 8, 2021 at 3:58 PM
    blanchard7684
    blanchard7684 New Member
    what is molybdenum content of Rotella?
  5. Apr 9, 2021 at 8:53 AM
    tt18
    2018 tundra ltd
    I was using Mobil 1 0W20 full synthetic. I don't know the molybdenum content of Rotella. My Tundra only has 18600 miles and the tick is definitely gone!!!
  6. Apr 9, 2021 at 8:56 AM
    blanchard7684
    I ask because I've been using the Toyota branded synthetic because it has higher zinc and moly content than Mobil 1. When I switched I noticed a big difference in engine noise.
    WILLINH likes this.
  7. Apr 9, 2021 at 9:04 AM
    tt18
    2018 tundra ltd
    Did your noise get worse or better ?
  8. Apr 9, 2021 at 9:06 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I have also been using Toyota oil also and it has the tick is gone.
  9. Apr 9, 2021 at 9:10 AM
    tt18
    2018 tundra ltd
    Glad to hear it. Stick with what works for you. Just for information: The Rotella is $5/quart at my local Tractor Supply.
  10. Apr 9, 2021 at 9:13 AM
    blanchard7684
  11. Apr 9, 2021 at 9:19 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    To bad the Rotella is being discontinued.
  12. Apr 9, 2021 at 9:22 AM
    tt18
    2018 tundra ltd
    The Rotella 0W20 for gas engines is a new product. Where did you hear about it being discontinued ?
  13. Apr 9, 2021 at 9:25 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    It has been out for at least a 1 1/2 years, several members have stated it did not sell good enough. Pep boys just had a big rebate on it. I can only find it at Tractor supply.
  14. Apr 9, 2021 at 9:26 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Do a search on the forums about it.
  15. Apr 9, 2021 at 9:28 AM
    tt18
    2018 tundra ltd
    Will do, thanks.
  16. Apr 9, 2021 at 10:25 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I just switched to Schaeffers 5w30, was running their 0w20, engine is much much quieter now! And the additive package is great as is expected from them
    blanchard7684 likes this.
  17. Apr 10, 2021 at 2:06 AM
    blanchard7684
    That looks great.
    Sumo91[QUOTED] likes this.
  18. Apr 10, 2021 at 5:36 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I also went with Shell Rotella 0w20 Synthetic for my first oil change at 3000 miles, truck now has 5800 miles and I will say the engine is quieter now than it was before the Shell oil. I plan to change my oil again probably in June and I certainly hope the rumor's of being discontinued are not true.
    It's so disheartening to find something you like only to find it will no longer be available.
  19. Apr 10, 2021 at 6:42 AM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    I would also would not be shocked to see the Toyota Service dept not using Toyota oil either?
    The Dealers where I have been have big barrels of generic branded oil for the oil change monkey and I think you have to ask and pay for branded oils a lot of times.
    Some advertise a brand with the coupons they offer but I am not at all convinced that this is what you get in there either.
