  1. Apr 9, 2021 at 2:24 PM
    heyacker
    heyacker New Member
    Yea. It says 6 weeks. I have one XL already but when I went to order the second I saw they improved them so obviously I had to get two. :frusty:
  2. Apr 9, 2021 at 2:24 PM
    El Two
    El Two I’m only talking to my dog today.
    Lisa
    2018 SR5 Crewmax TRD Off Road
    How much time do you have? . . . . . . . . . . . . . . . . . . . . .......... Eaton rear eLocker, Camburg 1.5” shackles, Rear Seat Delete, S&B CAI, sPOD, Air Bag Helpers w/ Daystar Cradles, RCI engine & fuel tank skid plates, ABS Guards, Job Box Storage, Tailgate Power Lock, Desert Eagle Offroad tranny/cat security skid plate, Added Driver’s Side Grab Handle, VLEDS Footwell & Step Lighting, Anytime Front Camera, Illuminated Ignition Ring, Console Molle Panel, Sound Dampening in Ceiling/Doors/Floor, Yakima Rack, Paracord Grab Handle Wraps, BD Underhood Light, Tuffy Console Safe Insert, WeBoost System, Midland GMRS Radio, Console Interior Lighting, Power Inverter, Custom Center Switch Panel, and Dual Air Compressors
    Installed a new switch plate insert below the A/C controls. Corey George from BlackCatWorks.com was awesome to work with. He was willing to modify his original panel design (https://www.blackcatworks.com/Third-Gen-Tundra-Switch-Panels_p_26.html) to accommodate an air pressure gauge for me. I sent him the gauge and he figured out how to make it fit along with six switch positions. :yes:
    The gauge is the 1.5” model from Viair (https://www.viaircorp.com/air-gauges/in-dash-gauges/1_5_single_gauge). I’m still working to install the air system so the gauge isn’t functioning yet.
    Changes include:
    - swapped out the two cigarette charge ports for USB ports (https://smile.amazon.com/gp/product/B077P7GYG6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8)
    - added the Anytime Camera switch (https://www.anytimebackupcamera.com...ucts/anytime-backup-and-front-camera-full-kit)
    - relocated the rear window switch so someone in the passenger seat can work the window. Used a relocation wire harness from 12Volt Solutions (https://www.12volt.solutions/produc...elocation-harness?_pos=1&_sid=ce6850e32&_ss=r)
    - added a little humor for those long road trips (Hope my husband’s not reading this thread) (https://www.aironboard.com/online/push-switch-9b85nb-12volt-toyota-oem-passenger-eject.html)
    - and the final switch position is reusing the AUX port.
    If interested, more pics and details can be found in my build thread, post #48. Link in signature line.
  3. Apr 9, 2021 at 2:31 PM
    daveeasa
    I have the passenger eject as well. I'm too scared to install it (so far). I assume I'd be the one getting ejected if it were in and got noticed...
  4. Apr 9, 2021 at 2:36 PM
    El Two
    Lisa
    I know what you mean. My husband hasn’t seen it yet. :laughing:
  5. Apr 9, 2021 at 2:38 PM
    daveeasa
    What is the planned function for it, out of curiosity?
    Mine was going to be for disabling the rear window controls at the doors b/c my kids are punks but I just permanently shut them down (I can control from the driver seat just fine) by removing a jumper on my bowl light kit.
  6. Apr 9, 2021 at 3:26 PM
    BUCS_KID88
    BUCS_KID88 New Member
    Fuel ammo 20x9 +20 Nitto Ridge Grapplers 35x12.5 20
  7. Apr 9, 2021 at 3:31 PM
    El Two
    Lisa
    No plans as of yet. There was a spare spot and I didn’t want to use a blank cover. It is wired into the dash illumination circuit. As an aside, many thanks to @RainMan_PNW for the wiring diagrams. They’ve been a big help.
    RainMan_PNW likes this.
  8. Apr 9, 2021 at 3:33 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    AggiePhil and GODZILLA like this.
  9. Apr 9, 2021 at 3:36 PM
    Lisa, I assume the purpose of the panel is to move the switches closer to you for a better reach? That would be sweet on my 2020 once I get around to installing my horns.
  10. Apr 9, 2021 at 3:49 PM
    BeachBaum107
    BeachBaum107 New Member
    Thomas
    2021 Magnetic Gray Metallic
    Tool Box Floor Mats Pistol Mount Running Boards 20” Fuel Wheels Tinted Front Windows
    Installed a toolbox, new floor mats and a pistol mount.
    WFD473 and Username Kyle like this.
  11. Apr 9, 2021 at 4:04 PM
    El Two
    Lisa
    Moving the switches closer was a by-product to accommodate the gauge though I’m happy with the finished product. The switches are much easier to see and access. The primary purpose was a desire for more switch locations and a spot for the gauge to keep the cab as uncluttered and OEM-like as possible. Because of the depth of the gauge, the face of the panel had to be brought forward so there would be room to connect the air line in the back.
  12. Apr 9, 2021 at 4:09 PM
    Gotcha. I'll contact him to see what it would be like for mine. The panel on the 2020 is different than the 2018-2019 models.
  13. Apr 9, 2021 at 4:19 PM
    El Two
    Lisa
    Here’s his email address: corey.george@gmail.com
    CappyKD likes this.
  14. Apr 9, 2021 at 4:20 PM
    El Two[QUOTED] likes this.
  15. Apr 9, 2021 at 4:29 PM
    TrenThom86
    TrenThom86 New Member
    Trent
    NW Louisiana
    2021 TRD Pro Lunar Rock
    It was the seal between the tailgate and bed cover. You have to open or close the tailgate with the cover closed to get to the latches and it just pushed the seal off over time. I just glued it back down with some high strength glue I got from work. It doesn’t flap in the wind because it has cross bars on the bottom that make the cover pretty tight when latched down.
  16. Apr 9, 2021 at 5:53 PM
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    CappyKD likes this.
  17. Apr 9, 2021 at 6:13 PM
    Teegee
    Teegee Around
    Grouch
    21 MAX
    First oil change at 1960 miles. Did the factory oil cap swap. Pretty uneventful
    9C83AE7F-5E95-4291-A62D-009C45E86C48.jpg C42E1A83-008E-4CF8-B219-48ECE1BFCB2B.jpg 1BC07E0A-B3C9-4546-B176-43D53D14F076.jpg
  18. Apr 9, 2021 at 6:26 PM
    Username Kyle
    Username Kyle ...
    Kyle
    Chesapeake, VA
    2019 Tundra
    ReadyLift 2.4” Level Fuel Off-road Wheels Wrangler Duratrac Tires Predator Steps ARE Z Series Cap ARE Ascend Basket BedRug Bed Liner Debadged
    Pictures?
  19. Apr 9, 2021 at 7:41 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    I finished installing the TRD Pro headlights. I used @iHacker harness. I wanted the ambers to remain as the drl. It’s the best mod that I’ve done. IMG_9815.jpg IMG_9820.jpg IMG_9805.jpg
    WFD473, Glennjermin, Ostrich and 13 others like this.
  20. Apr 9, 2021 at 7:46 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    My goodness, are they that much brighter down the road compared to the halogens?!
  21. Apr 9, 2021 at 7:51 PM
    jdg1982
    jdg1982 New Member
    :yes: that was my biggest decision factor. I couldn’t see with the halogens. Plus they look amazing without the chrome housing.
    a522467 and Wallygator like this.
  22. Apr 9, 2021 at 7:54 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Just dropped a shiny penny on WKO sliders... maybe soon... but it is aesthetics... for now...
    BlueRibbon4x4 and CappyKD like this.
  23. Apr 9, 2021 at 8:19 PM
    BeachBaum107
    Thomas
    Will post pics tomorrow.
  24. Apr 9, 2021 at 8:21 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    :worthless:
    And welcome and stuff.:wave:
    BlueRibbon4x4 likes this.
  25. Apr 9, 2021 at 8:34 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    Bad ass. Nice work.
    CappyKD likes this.
  26. Apr 9, 2021 at 8:43 PM
    El Two
    Lisa
    Yes, shouldn’t be a problem. Just be aware these are the shorter version of the Toyota sizes. Also, these particular USB chargers have a blue voltmeter display that you may or may not want.
  27. Apr 9, 2021 at 8:44 PM
    El Two
    Lisa
    Thanks!
  28. Apr 9, 2021 at 8:53 PM
    French Avocado
    Utah / Wyo
  29. Apr 9, 2021 at 9:01 PM
    BeachBaum107
    Thomas
    I am trying to figure this forum stuff out. Like how to respond to a post and it show the previous comments. Hope this works.
  30. Apr 9, 2021 at 9:04 PM
    Hightide
    Abalama
    Magic School Bus
    Use the upload a file tab, then select chose file, and then select a photo from your device.
    Hope this helps.
    6C477871-6AB8-4A75-B31E-533DDAACD304.jpg 0E6C2286-6B02-48E2-98AF-9CC37B88C835.jpg
    pvn.beluga and GODZILLA like this.
