  1. Apr 9, 2021 at 5:43 AM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    Looks good!!!
    mgm16trdpro[QUOTED] likes this.
  2. Apr 9, 2021 at 5:43 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Tnx
    Ltaco17[QUOTED] likes this.
  3. Apr 9, 2021 at 6:46 AM
    Derf77
    Derf77 New Member
    Fred
    South Chesterfield VA
    2020 Crewmax SB SR5 TRD Off Road
    TRD rear sway bar, Ready lift 3/1, 4 window auto up/ down.
    I've had it a little over 80mph and no flapping.... it is very secure
    wawa.la.unika[QUOTED] likes this.
  4. Apr 9, 2021 at 6:55 AM
    2020TundraVooDooBlue
    2020TundraVooDooBlue New Member
    This looks great! Doing mine this weekend and this gets me more stoked about it. I like the look...
    carsonhudson[QUOTED] and Astom22 like this.
  5. Apr 9, 2021 at 7:00 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    Man, tell me about it...always a battle
  6. Apr 9, 2021 at 7:09 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    jonclark96[QUOTED] and Astom22 like this.
  7. Apr 9, 2021 at 7:47 AM
  8. Apr 9, 2021 at 8:02 AM
    Nice. What part of FL again? You should install the aluminum oil filter housing as well if you don't have one already.
  9. Apr 9, 2021 at 8:21 AM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    Yes, I have the aluminum housing, fumoto valve and that other thing to drain the filter for easy oil changes. Forgot to add Pro Head lights, and @iHacker harness.
    I have a lot of work to do. PSL FL across the state.
    iHacker and Tundra234[QUOTED] like this.
  10. Apr 9, 2021 at 8:48 AM
    Yeah I need to find that filter drain kit myself.
  11. Apr 9, 2021 at 9:00 AM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    I got all my stuff on Amazon. Already had the wrench but I love that funnel and drain plug
  12. Apr 9, 2021 at 9:01 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Factory did it, can't take any credit. I think the whole flares would look better bullet lined black.
  13. Apr 9, 2021 at 9:07 AM
    Thanks!
  14. Apr 9, 2021 at 9:09 AM
    I have mine Line-X'ed. Love it!
    Occidentalis[QUOTED] likes this.
  15. Apr 9, 2021 at 9:12 AM
    Tundra14Platinum
  16. Apr 9, 2021 at 9:12 AM
    TrenThom86
    TrenThom86 New Member
    Trent
    NW Louisiana
    2021 TRD Pro Lunar Rock
    I had that one on my 12 Ram. The only problem was the rubber strip that sits over the tailgate came loose. It’s just glued on but opening and closing the tailgate tore it off.
  17. Apr 9, 2021 at 9:19 AM
    wawa.la.unika
    wawa.la.unika New Member
    Laura
    San Antonio, Texas
    2021 Tundra CrewMax
    was there a fix to that or you have to just replace? did it cause it to flap with the wind? i don't mess with my bed...rarely haul anything in there, i would like to just cover a compressor
  18. Apr 9, 2021 at 9:29 AM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    2021 SR5 Tundra Crewmax 4x4
    Bakflip G2 Tonneau Cover
    Mine has held up well for 3 years now. I did have one gasket piece on a side come loose, but some double sided 3m tape fixed it easy enough.
    wawa.la.unika likes this.
  19. Apr 9, 2021 at 9:50 AM
  20. Apr 9, 2021 at 9:50 AM
    carsonhudson
    carsonhudson New Member
    Front is on. Took 6 hours :sick: Couldn’t get the passenger sway bar link bolt back in. The back half of it just wouldn’t come down. Going to try again this weekend on it. Any tips? Edit- found some good threads with advice. Loosen sway bar from frame it sounds like. Will attempt
  21. Apr 9, 2021 at 9:55 AM
    If I remember, I think I used a bottle jack to raise it up to get the bolt in. You may have to change your UCAs to get a good alignment. They are highly recommended by Toytec for the Aluma series coilovers.
  22. Apr 9, 2021 at 10:29 AM
    carsonhudson
    Thanks, we tried the bottle jack. alignment tomorrow. Will do firestone's lifetime and see what they can do and consider the UCA's. Currently seems toed in. tires squeak with a tight turn at lower speeds
  23. Apr 9, 2021 at 10:32 AM
    carsonhudson
    Also, currently have a little over 4" after installing the boss 2.0s at the preset height. Is that expected to settle? 26" mid hub to fender
  24. Apr 9, 2021 at 10:33 AM
    It may settle a hair, but not enough that you will notice. I have the 2.0's as well.
    carsonhudson[QUOTED] likes this.
  25. Apr 9, 2021 at 10:54 AM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    It's a shame they don't have bigger sizes.
  26. Apr 9, 2021 at 11:19 AM
    YotaTundy
    YotaTundy New Member
    joshua
    2016 Tundra TRD Pro
    Put on some new shoes. BFG All Terrain K02s (285/65/18).
  27. Apr 9, 2021 at 12:15 PM
    heyacker
    heyacker New Member
    I ordered two of the GearPod XL V.2 today. :kona:
  28. Apr 9, 2021 at 1:56 PM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    Under drivers seat maglite storage
  29. Apr 9, 2021 at 2:21 PM
    FLdub
    FLdub New Member
    24 Limited 4x4 Nightshade
    Installed Husky X-act Contours front and rear.
  30. Apr 9, 2021 at 2:22 PM
    FLdub
    FLdub New Member
    Leitner? I thought they were eternally back ordered. Haha
