Battery Disconnect/Reconnect Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dsptundra, Apr 8, 2021.
  1. Apr 8, 2021 at 7:59 PM
    Dsptundra
    Dsptundra [OP] Still a new member...
    Austin TX Area
    2021 Silver Limited CM
    I searched for this but didn’t find it...
    I’ll soon install the wireless charger and the power tailgate lock mods so I need to disconnect the battery and then reconnect when finished. On my former vehicles I had to reset all radio stations, etc. after reconnecting. Should I expect the same with the Tundra or has technology improved since 2008 where it will retain settings for a certain amount of time?
  2. Apr 8, 2021 at 8:00 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I have never had to reset anything when disconnecting the battery. I did it a lot when changing to interior LED.
    Just don't freak out if your miles to empty goes wonky. It takes a few miles for that to recalibrate.
    No issues.
  3. Apr 8, 2021 at 8:09 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm going to go with, you're going to lose all your stuff... it's a soft reset.. best way to troubleshoot certain things and eliminate that pesky CEL.
  4. Apr 8, 2021 at 9:10 PM
    French Avocado
    Utah / Wyo
    Be careful and do not disconnect. I had no problem when I did mine.
  5. Apr 8, 2021 at 9:16 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I don't think you'll lose your settings and presets if you disconnect the battery, but I'll agree with @French Avocado
    I've installed the wireless charger and tailgate lock on separate occasions on my 2014 and I didn't disconnect the battery..
    Although it doesn't hurt to be cautious...:eek2:
    Only issue I see is tapping into the wrong wires to trigger the tailgate lock and you have the doors open..
    But I had no issues installing mine.
    The wireless charger is a no brainer, no power to that circuit (12volt plugs) when the key is off.
    Good luck...:thumbsup:
