TSS lug nut help
Discussion in 'Wheels & Tires' started by carsonhudson, Apr 7, 2021.
  1. Apr 7, 2021 at 2:31 PM
    carsonhudson
    carsonhudson [OP] New Member
    Help.. trying to put the boss coil overs on today but can’t break the lug on the wheels. Stock tss wheels. I have a key for the locked lug but doesn’t seem I have a direct fit for the others. Is it a long 23 mm? Anyone with these wheels that can chime in
  2. Apr 7, 2021 at 2:38 PM
    Aught16TSS
    Aught16TSS New Member
    J
    Tuckasee
    2016 TSS - Magnetic Gray Metallic
    Dual Flowmasters, hidden LEDs in hood bulge, 3.5" lift and Ridge Graps
    I used a 7/8” because I didn’t have anything metric that big. I think it is actually a 22mm though.
  3. Apr 7, 2021 at 2:39 PM
    carsonhudson
    Thank you. Just left discount. They said 7/8 also
  4. Apr 7, 2021 at 2:41 PM
    RobertD
    Robert
    DFW, Texas
    If that doesn't work, I can check in about 7 hours. I have a set a metric sockets I can check to see which size fits. Bought the set from HarborFrieght for $25 just so I'd have most the metric sizes but have barely used them yet.
  5. Apr 7, 2021 at 10:56 PM
    carsonhudson
    Thank you. The tech said the lugs are two parts- one metal and one plastic so they expand especially in the heat and that’s why my original lug wrench wouldn’t fit. 22mm long socket fit snug just needed a tap to get her on good.
