Recourse on rim damages?
Discussion in '2.5 Gen Tundras (2014-2021)' started by HidetownRed, Mar 14, 2021.
  1. Mar 14, 2021 at 2:46 PM
    HidetownRed
    HidetownRed [OP] Buffalo Hunter
    Top O Texas
    2020 Sky Silver Limited 4x4
    3/1 285/60/20 RG tint and red toes
    Had a new set of tires put on a couple weeks ago. Fist new set and never even had the factory ones off for a flat repair. After doing some cleaning this weekend I discovered they scratched the shit out of all four. Any experiences with this?
    Roborob70 likes this.
  2. Mar 14, 2021 at 2:52 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Contact your installer. That is your only recourse.
    If I had to guess....you are on your own, once you drive off their lot.
    I'd you don't get anywhere with the shop level, escalate it to corporate, if they have one.
    Saltyhero13 likes this.
  3. Mar 25, 2021 at 9:34 PM
    HONEYBADGER
    HONEYBADGER New Member
    Fox Coils Camburk Kinetik Uppers Stealth Customs Cooper AT3
    They will most likely say if you didnt notice when you picked the truck up then it is not our mistake.....something else caused it.
  4. Mar 25, 2021 at 10:46 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Yeah, you'll likely end up like that scene in Liar Liar when Jim Carrey goes to pick up his Mercedes from the impound lot.
    You may be able to use use something to smooth it out a little so its not so noticeable, but you might just make it worse.
    Maybe check with a wheel repair shop and see what they can do.
    Sucks man, sorry that happened.
    MS22 likes this.
  5. Mar 25, 2021 at 10:59 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Yeah back in 1992 sears failed to use a nylon protector and gouged the lips on 3 of 4 rims on my brand new car. I found out it was the mop boy from the employee number on the work order. Sears paid for the rims. Be persistent.
  6. Mar 26, 2021 at 4:05 AM
    Tire shops have insurance for this very issue. Take it back and have wheels repaired or replaced.
    Alex38 and Black Wolf like this.
  7. Mar 26, 2021 at 5:12 PM
    Shamrock92
    Shamrock92 New Member
    Not sure that could be refinished. If it were smooth im sure it could be - but replicating the machined lines would like not be possible. Refinishing cost $100-125 a rim in general.
    As to "blame the installer - make them make it right" - good luck. Personally, i doubt there is any success trying this. Not that OP is wrong or blaming the wrong person here - but wanna guess how many people blame the installer/towing company for rim/tire damage a week ? Every shop gets at least 1.
    Best option may be filing under your own insurance and asking them to chase the installer for both their payments and your deductible. Your insurance covers YOU regardless of fault..you pay for coverage - use it.
    Or small claims - will cost you $50-85, and you might get lucky. But its easy to defend as an installer...vehicle has been in service for some time - the burden of proof is on the complaining party to show the damage could ONLY have occurred in the shop. Its reasonable to say it did - but not impossible it happened elsewhere either.
    HidetownRed[OP] likes this.
  8. Mar 26, 2021 at 5:17 PM
    Shamrock92
    Yes - they have insurance alright...insurance that DEFENDS THEM. If you think the other guys insurance is gonna side with YOU in a disputed fault situation...you won't like the likely outcome.
    Insurance is the best option - but gotta go with yours. YOU pay them to defend YOUR side of the case...and they have a duty to do so (provided it is reasonably supported...for example- you rear end someone...they will pay the other party regardless of your wishes. But when either version is reasonable and can be supported- then they will defend you.)
  9. Mar 26, 2021 at 6:02 PM
    Every time a wheel and tire store has damaged a wheel or didn’t install a center cap correctly (and came off) they have replaced it without an issue.
    Works for me.
  10. Mar 26, 2021 at 6:04 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    @HidetownRed it's been two weeks.....what did the shop say or so for you?
  11. Mar 26, 2021 at 6:05 PM
    HidetownRed
    Top O Texas
    Sorry for no update. They took ownership and are sending me to a shop to get them refinished. Problem is it all 3.5 hrs away so I have yet had time to go down there.
  12. Mar 26, 2021 at 6:28 PM
    HidetownRed
    Top O Texas
    They are taller than most curbs and wider that the rim. Not many curbs in this part of TX either.
    Send me that 5 cuz your full oh shit
    Kung, batman900, landphil and 2 others like this.
  13. Apr 7, 2021 at 8:03 AM
    Bigsense78
    Bigsense78 New Member
    Columbia Gorge, OR
    2018 Tundra Platinum
    For anyone reading this thread and ones like it, may this be a lesson to you. Never, ever, EVER, under any circumstances leave the installer without first inspecting each wheel thoroughly. Been there done that and ended up being shit outta luck a couple 4Runners ago. Glad it worked out OP.
    Astom22 likes this.
